Why is my car too small for my son?
Discussion in 'Gen 3 Prius Main Forum' started by nudriver, May 26, 2023.
  1. nudriver
    nudriver Member
    283
    32
    los angeles
    My son is learning to drive and we are using my 2012 Prius. He is 6'2". His head almost touches the ceiling and his legs are hitting the steering wheel, even with the seat pulled all the way back. Am I missing something here? How can there be a height limit for a major car maker?
  2. Mendel Leisk
    42,325
    Maybe tilt the seat back backwards a click or two? Our son's driven ours, and he's 6'-7". Everytime I get in the driver's seat after he's driven, it's like falling into a pit.
  3. PriusCamper
    PriusCamper Senior Member
    13,450
    5,430
    Pacific Northwest, USA
    Everything about the Prius C is super small... It's designed for people who live in crowded cities where space limitations are a huge hassle... You might be able to get these universal seat extension brackets to work for $40: https://www.ebay.com/itm/264485189144
    They do make ones specific to Prius but spending $300 on some chunks of metal seems like a waste of money: Toyota Prius C (2012-Present) Seat Brackets - Extend My Seat Store
  4. PriusCamper
    13,450
    5,430
    Lol, sound like the proportions of a 6' 7" Canadian are way different than the proportion of a 6' 2" Southern Californian...
  5. ASRDogman
    ASRDogman Senior Member
    8,057
    4,085
    I believe there is a lever on the left side to adjust the heighth of the seat.
    That should help. I'm 6'1 and have plenty of room from the roof, and I don't need
    the seat all the way back.
    Mine is a 2010, but the should both be the same. Unless yours are electric seats???
    Montgomery likes this.
  6. Leadfoot J. McCoalroller
    8,283
    7,794
    Pennsylvania
    2018 Prius c
    Just change the seat height. That's what the other-other lever does.
    nudriver, Montgomery and PriusCamper like this.
  7. PriusCamper
    13,450
    5,430
    Wish we had that in Gen2...
    Isaac Zachary likes this.
  8. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    The tilt and telescopic adjustments for the steering wheel can also help:
  9. fuzzy1
    10,705
    I'm only a half inch shorter (or was, back when acquiring my 2012, before age-related height loss became measurable), and don't have these problems, after driver adjustments are made.
    On all modern cars, this and previous, I've needed to adjust the tilt steering wheel all the way up to avoid knee collision.
    On the head clearance problem, this car actually has better clearance than my previous cars (excluding a current SUV, which replaced a previous wagon). I do drop the seat to its lowest possible position. Though that age-related height loss (mostly in the spine) has now given more than an extra half inch of clearance. And age-related hair loss also eliminates that feeling of hair brushing against the ceiling.
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Because car makers are targeting average height humans. If they targeted 6ft or taller for vehicle layout standard then a lot of vehicles will be unsold and there will millions of post being like how come the Prius is too big for my son. Toyota sales won’t dint of a few people are too tall and not buy
  11. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    I'm 6' 1" and I fit just fine in both my 2010 and 2017. Play around with the seat and steering wheel adjustments, he'll find his sweet spot.
  12. bisco
    52,824
    I’m 5’-7”, and sometimes bump my head getting in or out of my gen 3
  13. ASRDogman
    8,057
    4,085
    then lower the seat...
  14. PriusCamper
    13,450
    5,430
    I'm trying so hard to not say something funny about this comment....
  15. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    I'm 6.2" and have never bumped my head....I can wear a ball cap and still have a few inches from the top when sitting in the driver's seat.
    PriusCamper likes this.
  16. bisco
    52,824
    if i do, i can't see over the steering wheel
  17. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Then get a booster seat!
  18. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Lower the steering wheel.
  19. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Like stated earlier, there is a height adjustment lever that lowers the "height" NOT the lever that makes you feel like your leaning back.
  20. PriusCamper
    13,450
    5,430
    Maybe if you had 100K+ comments on PriusChat like @bisco you'd know what it's like to bump your head way more often?
