why is my ICE starting???
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by rockerdan, Nov 9, 2012.
  1. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    This has happened twice now.....
    cool mornings, approx 30f.
    Leave my house, EV mode full charge....heater OFF with foot and defrost icon showing.
    I press peddle slightly about 1000ft from my house, HSI rises to approx 40% only.
    ICE STARTS!
    If the heater is OFF, but settings are left at foot/defrost and fresh air(not recirc) is this triggering ICE?
    Only happened two times, when coldest out. any milder temps no issue.
    thanks
    Dan
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    have you reached the 125 mile EV limit? ICE comes on every 125 miles of EV only miles.
  3. rockerdan
    427
    83
    Wheatfield NY
    no not even close....i run the ICE every drive pretty much...
    I was wondering, I have the heater set to 85 degrees before i turn it off....do we have to turn TEMP down to LO in addition to turning entire climate control OFF? That would seem odd.
    Dan
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    did you have front windshield defrost on (defrost light on)?
  5. rockerdan
    427
    83
    Wheatfield NY
    no, no light on def.....just the ICON of feet and DEF on screen but no light.
    I thought maybe the fact the DEF/FOOT icon was on it had something to do with it.
    I think the two times this happened, it was showing foot and DEF. on image. with fresh air. I wonder if it thinks i need def due to this and starts ICE cause its cold out? but if heater is OFF i dont think this matters.
    very odd
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    you could be on to something there, any request for defrost will trigger ICE if it's cold inside the cabin. When it's hot inside the cabin the air conditioning kicks in automatically because of humidity is eliminated with air conditioning. since it's cold now, heat eliminates humidity.
  7. rockerdan
    427
    83
    Wheatfield NY
    what is the difference between DEF with light on(button)......
    OR
    DEF on the icon screen,where foot, face ect is.
    Dan
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    dono....but any request for DEF is going to trigger ICE if it's cold enough IMHO
  9. rockerdan
    427
    83
    Wheatfield NY
    why would it wait til im 1000ft down my road? and why would it wait til i accelerate to approx 40% HSI? very odd. It has never happened right away when i leave, it happens 3-4 mins into the drive.
    Dan
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I have used windshield wonder to "defrost" with ALL defrost requests OFF. ice has stayed off for me
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    probably the PIP is calculating temperatures of the cabin during that 1000ft
  12. rockerdan
    427
    83
    Wheatfield NY
    My car is in a garage, it was not frosted at all....I just happen to always leave my icon set to foot and DEF from previous drive.
    It seems to me, if heater is OFF, no matter what its OFF...but is it really off? odd
  13. rockerdan
    427
    83
    Wheatfield NY
    If it is OFF why would it calculate inside temps?
    I wonder if the previous setting(85f) is somehow calling for heat, even though heater is totall OFF.
    when you guys turn your heater off, do you turn temp down first, then off?
    Dan
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    the fact it's in the garage should be a indicator, when you go outside the temperature changes
  15. rockerdan
    427
    83
    Wheatfield NY
    unheated garage, typically same as outside temp or colder if sun is out like today....
    I wonder if the heater is OFF entirely or do we also need to turn temp down to LO also? that does not make sense though
  16. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    dono, for me, because I haven't used my def. or A/C since july. my fan settings are at the lowest settings tho
  17. rockerdan
    427
    83
    Wheatfield NY
    once fan is on, even lowest, the system is ON....i keep mine OFF entirely until i want heat, then i am ready for ice to run.
    i just hate that is started twice now right when i leave...when i want to drive EV for 13miles first!
    Dan
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    well........I'm stumped:cry:
  19. rockerdan
    427
    83
    Wheatfield NY
    Is there a possibility the cold temps, take a toll on 12v battery and it starts ICE to charge it?
    I guess ill have to try it with just foot icon showing in OFF mode.....
    then If it still does it Ill turn temp down to LO before going into OFF mode. that is pain in nice person though cause when you want heat then you gotta tap temp button all the way back up to 85.
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    not cold enough to take a toll on 12 volt battery, besides charging EV also charges 12 volt battery
