why is my ICE starting???
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by rockerdan, Nov 9, 2012.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Got the Andriod version myself, the scangaugeII mounts above my rear view mirror tho
    LG-MS910 ? 2
  2. Big Dude
    Big Dude Member
    207
    76
    Wisconsin
    This morning it was 21 degrees (So. Wi). Charged yesterday . I drove 9 miles. No Ice. Had 5.8 miles left on charge indicator when done. I dove between 25-45 MPH). When I go to the exact same location using a 60MPH highway, the ICE always comes on after about 1/8 mile @ 60 mph. I think it is a combination of TEMP and Draw. Low temp and high draw, the ICE will come on--no matter when you charge.
    52,863
    tell us a little more about your accident. you may also want to check your 12 volt battery, although, i'm not sure the ice keeps it charged?
    52,863
    that's very interesting, you could be on to something.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    make's sense, b/c if the battery doesn't have enough juice then ICE has no choice but to come on.
  6. bisco
    52,863
    or if it's too cold, it may not want you to pull over a certain amount of amps?
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    The battery is not able to, it's like when you start a conventional car, battery capacity is there but due to colder temps, less amperage is given up by the battery.
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    which could explain why my ICE never comes on, I drive 25 MPH or slower to work.
  9. bisco
    52,863
    aha! so even stepping on the pedal too hard might start the ice even if you're not in the power zone.
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yup
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Bisco, do you have a ScanGaugeII? If so, the monitor your battery amps.
  12. blmoore
    blmoore Threadfinder
    31
    Pennsylvania
    Lots of front end repairs :( - I know they had to disconnect the battery to do some welding. I don't know enough to guess what the problem is, except to know that the ICE always comes on now (when it didn't before) and when it does, the idle sounds really high. Maybe something needs to be adjusted, ICE-wise?? On the upside - all replacement parts were new, Toyota parts, as there are no after-market parts available yet. The car looks great... just can't get the mileage I got before!
  13. bisco
    52,863
    i don't, but my ice hasn't come on yet for any unknown reason.
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    bummer!:cry:
  15. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    might come in handy when it gets colder
  16. bisco
    52,863
    mine revs really high too, when it first starts, i think that's normal. and you're sure your temp is set to 'low'? they could have damaged the 12v buy running it down too often while in repair. in the non pip, that can cause the ice to run more.
  17. bisco
    52,863
    agreed, every time i think about getting one, someone comes along and says they are working on a better mousetrap. first it was peef, then he bailed, now it's firstflight, but i haven't heard from him in a while.:(
  18. blmoore
    31
    Pennsylvania
    I'll have them check that when I take it in for its 10,000 check - I just never heard it before. I'll let you all know if I learn anything important!! (And yes, temp is on "low.")
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    lol, (not to be funny but) ScangaugeII has a voltmeter readout. Mine reads 12.8 volts when car turns off. 14.6 when in EV mode.
  20. lensovet
    2,615
    496
    Burlington, NJ
    What's the outside temperature overnight? When does your charge finish compared to when you drive off?
