why is my ICE starting???
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by rockerdan, Nov 9, 2012.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I'm a little suspicious of the "low temp" setting. I leave climate control off.
    52,863
    i do too. but i also keep the temp on low unless i want heat.
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    with climate control off there is no "Temp low" setting
    52,863
    right, but when you turn the fan on, there is. so, with the fan on, i turn the temp to low and then fan off.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    that's a lot of extra work doing that, turning climate control off is so much simpler
  6. lensovet
    2,615
    496
    Burlington, NJ
    i mean you only do this once lol
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I set my temp to 70 degrees ONCE. leave my climate control off. When I drive the next two months I will be using ICE b/c of the 6 month fuel replenishment requirement. Then I turn climate control on, already set at 70 degrees
  8. bisco
    52,863
    simpler, but if you leave the temp higher than outside, the ice will fire, even if the fan is off.
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    don't care b/c I gotta use 5 gallons of gas in two months and I'm only 2.7 miles from work going twice a week
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    If your engine is starting every time you go 30 feet are you telling us you have zero EV range to use? You did not mention how many miles of EV the battery says you can go?
  11. retired4999
    2,652
    627
    Eau Claire, Wi.
    If you have Heat set to lo and defrost set to on, engine will fire! and go thru warm up.
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yup, agreed, no argument there
  13. bisco
    52,863
    oh poor kitty.
  14. bisco
    52,863
    he said he tried a fresh charge.
  15. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    it was a good run, lol
  16. bisco
    52,863
    ya think? i have to move closer to work.(n)
  17. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Where I used to work, it was 16 miles one way, then the store closed, they moved me to a store that was closer to home.:D
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    same seniority, bumped a lot of employees down the ladder, there is only three employees with more seniority than me, at old store there was eight
  19. retired4999
    2,652
    627
    Eau Claire, Wi.
    Go on a vacation and burn up all that bad gas.
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    can't, used up all my vacation time, and even if I could, I couldn't (car payments):cry::notworthy::sleep::unsure:
