Why is our MPG so different?
Discussion in 'Gen 3 Prius Main Forum' started by TheLos, Aug 19, 2013.
  1. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Uh, not so quick. You might save $1000 if you really got a difference of 11 mpg. IMO, at best you are going to get 2-3 mpg difference from tires. You can probably get another 2-3 mpg by increasing the pressure from a low of ~34 psi to 42/40 psi. The other 5-6 mpg loss is still a mystery
    Mike
    fuzzy1 and jnet like this.
  2. 3PriusMike
    3,101
    2,421
    Silicon Valley
    If only a tire change caused mpg to go from 51 to 65 don't you think:
    a. the tire companies would be advertising this left and right?
    b. a scientific analysis would be able to replicate this?
    c. pigs could fly?
    Mike
    fuzzy1 and TheLos like this.
  3. TheLos
    TheLos Member
    113
    Corona, California
    Hahaha so true! Most of August was unusually humid this year. I'm glad its almost over. I use "almost" loosely!
  4. TheLos
    TheLos Member
    113
    Corona, California
    Certainly something to consider! I've never traded in tires before, what kind of deal could I expect to get on the tires I'm trading in?
  5. TheLos
    TheLos Member
    113
    Corona, California
  6. terry brecheen
    139
    30
    houston, texas
    Discount gave me 120 dollars for them. They had about 2800 miles on them.
    TheLos likes this.
  7. TheLos
    TheLos Member
    113
    Corona, California
    Thanks Terry!
  8. terry brecheen
    139
    30
    houston, texas
    My trip from work to home, 22 miles, i used to get 45 to 46 mpg. Five o'clock traffic is horrible here in houston. Today first trip home with new tires display showed 57mpg. I drove the same route, same driving style and same time of day. I didn't have any scientists waiting for me when I got home nor did I see any pigs flying but I know what kind of mpg I got with the old tires and what I have gotten so far with these new ones. I will take a 200 mile trip to Austin this weekend and post results. The best I've done previously was 49.1 & 50.0 on two previous trips. Have a nice day.
  9. TheLos
    TheLos Member
    113
    Corona, California
    Thats a fantastic outcome Terry! Great to hear it. Hope you enjoy that trip to Austin, I've never been but I hear its a great place. Looking forward to see your results.
  10. terry brecheen
    139
    30
    houston, texas
    You are welcome.
  11. vskid3
    vskid3 Active Member
    773
    228
    I would still do what Vincent said and swap the tires between the cars to see what kind of impact the tires are actually having. Wouldn't want to buy new tires just to find out that there is another issue causing the lower mileage.
  12. TheLos
    TheLos Member
    113
    Corona, California
    Gonna do that this weekend!
  13. fuzzy1
    10,706
    Yesterday, OP wrote:
    Have you done so yet? This is essential, don't be making tire comparisons until the pressures are verified as at or above the door label, and matched.
    What size and width are those Westlakes?
    Also, browse through the following questionnaire. This was not intended for your particular situation of two cars that ought to produce identical results, but it may help guide you to other mpg-related differences between them. Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new
    TheLos likes this.
  14. TheLos
    TheLos Member
    113
    Corona, California
    I just got done checking the pressure. The tire pressure was different on each tire. I set them all to 40 and went for a 33.1 mile sample. 14 miles were on the freeway at 65-70 mph. Zero traffic. The rest was surface streets so nothing over 45 mph. Before adjusting the pressure my mpg's were at 45.1. At the end of the 33.1 miles I was at 55.7 mpg. What a difference!
    I ordered a tire gauge this morning and will be checking the pressure once a week. We've had our prius 2 for a month and this prius 3 for less than a week. I've learned a lot from this site already and appreciate everyone's knowledge. Even though this was solved by something which is probably obvious to most prius owners a lot of good brain storming was created and hopefully others will benefit from it.
    fuzzy1 likes this.
  15. TheLos
    TheLos Member
    113
    Corona, California
    Oh and the westlake tires are 195/65/15
  16. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Hope you've controlled for other variables like starting with a cold engine because jacking up the air pressure alone does not cause a 10 mpg boost.
  17. TheLos
    TheLos Member
    113
    Corona, California
    The car had been sitting for about 7 hours in the garage. The gas station where I added air is less than half a mile away. I started the 33 mile drive from there. It was probably about 83 degrees out at the time.
  18. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    I always find myself getting 5+ more mpg if I start with a warm or semi-warm engine so this is actually a large variable that must be accurately controlled for.
  19. TheLos
    TheLos Member
    113
    Corona, California
    Im still very new to prius so I'm learning every day. I'll keep a close eye on the tire pressure and mpg's and see how it changes. I'll update info here.
  20. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    No problem. Here's an excellent thread on the Gen III warming up stages on which to educate yourself.
