Why is P (parking brake button) not illuminated at night?
Discussion in 'Gen 4 Prius Main Forum' started by alexprius22, Apr 18, 2022.
  1. alexprius22
    alexprius22 Junior Member
    englewood florida
    2022 Prius
    It is during the day when I don't need the illumination as much.
  2. BiomedO1
    BiomedO1 Senior Member
    4,624
    2,422
    Left Coast
    Your dash illumination must be at least two bars - one bar or less all buttons will go dark.
    If your other buttons are illuminated, you may have an issue the that button only - burn out bulb.
    alanclarkeau likes this.
  3. Mendel Leisk
    42,354
    Just editorial: do you mean this button:
    That's for shifting the transaxle to "P" gear (likely short for "Park"), but not related to "Parking Brake".
    Doug McC and fuzzy1 like this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    The Parking Brake is on the floor - and yes, it's fairly dark down there - but I don't know a car with an illuminated Foot Park Brake Pedal.
  5. alexprius22
    englewood florida
    2022 Prius
    Thanks but as I said it is illuminated in daytime and brightness control is maxed out.
    For comment about parking brake being dark we are discussing the parking brake button! Not the pedal.
  6. BiomedO1
    4,624
    2,422
    Left Coast
    I'd go back to the dealer in the dark and show them - that's some strange behavior. It may have gotten cross wired somehow.
    Try turning-on the headlights during the daytime, when it's illuminated - see if it goes out... It should actually work opposite, out during the daytime, on with the headlamps.
    Good Luck...
    Doug McC likes this.
  7. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    Let’s start over: Are you referring to the button on the center console that says “P”?
    fuzzy1 and Mendel Leisk like this.
  8. fuzzy1
    10,713
    What those above have said ... there is no "parking brake button".
    There is a parking brake pedal:
    and a separate 'transmission' Park button:
    So, for clarification, which one of these two separate items are you referring to?
  9. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    alexprius22 did say that the button he was referring to WAS lit during the day, but not at night. That means something doesn’t seem right. Right now it seems we are all making assumptions as to what he is referring to. I, for one, would like to have clarification from him.
  10. TucsonPrius
    TucsonPrius Member
    167
    16
    Tucson, AZ
    2020 Prius
    Rather than nitpick about a simple English mistake, I'll provide my observations for a 2020 Prius LE model.
    On my car I believe I saw that the green LED in the middle of the button is lit when the car is in park. This is true day or night and only when the car is in park. The button is illuminated in blue when the headlamps are on regardless of whether the car is in park or not.
    Hope this is a helpful reply.
    Wonder and Salamander_King like this.
  11. dacoobob
    dacoobob Member
    83
    46
    Kansas City, MO
    Four Touring
    Thanks for cutting through the bullshit. This forum can be downright pedantic at times.
    To add another datapoint, my 2016 Prius Five Touring has the same behavior: the green indicator light is on when the car is in "Park", off when it's not; the white "P-in-a-box" button label lights up in blue when the vehicle headlights are turned on, and is unilluminated when the headlights are off. If the headlights are set to "Auto" mode, the blue illumination matches the actual status of the headlights-- off when they're off, on when they come on.
  12. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Not a regular Prius but my 2021 PP behaves the same way as @TucsonPrius described. Here is a pictorial version of his description.
    PaulDM and alanclarkeau like this.
  13. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    So those are all GREAT answers IF that is what his question is referring to. However, there is another switch with a P on it, and another possibility beyond a switch with a P on it that both are possibilities in a 2022 XLE.
    I have learned a few lessons in my life and one of them is “if you are not absolutely sure what the question is, ask for clarification”.
  14. Salamander_King
    11,024
    8,980
    New England
    What is the other switch with a P on it? I looked for it in my PP, but I could not find it... Is it in a regular Prius but not in Prius Prime?
  15. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    I don’t know, what I do know is that it is there in the 2022 PRIUS XLE. I try not to answer questions about other models unless I am fairly certain that I know the answer to the question.
    Salamander_King likes this.
  16. Salamander_King
    11,024
    8,980
    New England
    I thought you have a 2022 Prius XLE? That's what is on your profile. I am not asking about my PP. I can't find another button with "P" on my PP. That's why I asked what the other "P" button is on the 2022 Prius XLE.
  17. PaulDM
    PaulDM Active Member
    616
    320
    UK
    2022 Prius
    Excel
  18. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    It’s there, you just have to open your mind to it, and perhaps look outside the box your thinking in at the moment ;)
  19. dacoobob
    dacoobob Member
    83
    46
    Kansas City, MO
    Four Touring
    :rolleyes::rolleyes::rolleyes:
  20. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    At the risk of making the forum “be downright pedantic at times”, what’s your point?
    From your (not so polite) response, it’s apparent you couldn’t find it.
    I don’t know much (in reality, very little) about the Prius 4 Touring, but from the few pictures I was able to find, you probably wouldn’t be able to find it, since the system I am referring to may not be included on that model. But then it would be beyond this discussion then, wouldn’t it?
    #20 Doug McC, Apr 20, 2022
