Why is the oil change interval so different GEN 3vs4
Discussion in 'Gen 4 Prius Main Forum' started by shadow4478, Dec 5, 2019.
  1. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    Only synthetic oils are available in 0W-xx weights; conventional oils can't reach that low a viscosity at cold temperatures without adding so much viscosity index improvers that it becomes cheaper to just use a synthetic base (which, most "synthetic" bases are actually highly-refined conventional oil anyway). So, by specifying 0W-20, Toyota effectively specifies synthetic oil. Because synthetics don't use as much VII, which break down in the high-temperature, high-pressure engine, their viscosity characteristics don't change as much over a long oil change interval as a conventional oil, and consequently the interval can be longer.
    pjksr02 likes this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Mine says "0W-20"
  3. alanclarkeau
    7,045
    7,593
    Australian manual has a range of oils - despite 0W-20 on the oil filler
  4. alanclarkeau
    7,045
    7,593
    In your case, would you be like TAXIs who often stretch the changes, as their engines never cool down and particularly on hybrids where the engine isn't running all the time anyway. One driver I was talking to used to get an oil analysis for every 3rd or 5th change - which made him confident to extend change frequency.
    But I'd still do the first change as recommended.
  5. Mendel Leisk
    42,310
    Canadian interval for third gen is 8000 kms or 6 months, and the oil spec is 0W20.
    And for that matter, any grade can come in synthetic.
    Australia specs a mix of weights, with 0W20 the preference, and an interval similar to Canadian, I believe 10K kms or 6 months.
    If Toyota's longer interval in the states (and 4th gen now, in Canada) is due to the oil being synth, why don't they just say so?
    Ultimately, it's up the owner to pick their interval.
    #25 Mendel Leisk, Dec 7, 2019
  6. alanclarkeau
    7,045
    7,593
    Just to show up TOYOTA's randomness - new Corolla Sedan released this week - same drivetrain as PRIUS. PRIUS 10,000km/6mth, COROLLA 15,000km/12 month.
    And much cheaper - for first 3 years, COROLLA $175 each - PRIUS $140 each, but twice as many.
  7. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,804
    1,170
    Auburdale FL
    Common problem with the younger generation. They drive the car until the light comes on. Kid across the street went through two engine rebuilds before he got smart.
    Or better yet, " is there something wrong with the tires or sensor since the light is coming on?" :ROFLMAO::LOL:
    Put air I the tires and call me in the morning. "Oh the light went out". Did you have an oil change recently? Oh yeah! The dealer let air out of your tires while it was hot.
    Mendel Leisk and alanclarkeau like this.
  8. douglasjre
    douglasjre Senior Member
    2,249
    751
    Null, NL
    Wow is that what they're robbing you these days?
    alanclarkeau likes this.
  9. alanclarkeau
    7,045
    7,593
    Yep - and with "Check Engine Lights" on a lot of cars instead of temp gauges etc. I've heard the story many times of someone asking about the red light which has been on for the last 6 weeks. Most new cars are getting more intelligent - some have a Yellow caution and a Red catastrophic "check engine" light. And many go into limp home mode for long enough to park safely - that gives a good hint - "fix it".
  10. alanclarkeau
    7,045
    7,593
    Yes, most cars here now have fixed price service published by the Manufacturer. Most are for 3 or 5 years. And are something which you might be able to negotiate with the dealer at sale to have them included - sometimes it works.
  11. douglasjre
    2,249
    751
    Null, NL
    Mobil 1 regularly has $12 rebate on 5qt jugs. So an oem filter on eBay $4 and oil $13 are a grand total of $17.
  12. douglasjre
    2,249
    751
    Null, NL
    PS, change the oil cold and another quart comes out. Argue against it if you wish. Enjoy. Just stay away from the stealership
  13. alanclarkeau
    7,045
    7,593
    Only thing - warranty is voided if it's not serviced according to the book - doesn't have to be by a dealer, but needs to be certified to be a full service as per the service book, not just oil and filter.
    Plus - I generally turn my cars over every 3-4 years, and the first thing a buyer looks at (well, after they check general condition) is the service book.
    I've priced the TOYOTA service items from non-dealership, and they've been considerably dearer in some cases, others only slightly cheaper. I thought FORD was quite expensive with my 60,000km service on my FIESTA - so I checked with 2 non-dealerships, they were both within $50.
  14. Tideland Prius
    16,677
    Toyota Canada has stopped including the service interval section of the "Owner's Supplementary Manual". I guess neither the dealers nor the owners have been filling them out? I've filled out my Gen 3's one by myself as the dealers don't (but when I had my smart fortwo, the Mercedes dealers will fill them out for you).
    I suppose asking the dealer to print the service history when you sell is good enough?
    alanclarkeau and Mendel Leisk like this.
  15. Mendel Leisk
    42,310
    I thought you were going to finish that sentence that first thought with "...has stopped including the service schedule...", which is also the case, and puzzling. Now the schedule's only online, and the spoonfeeding event-by-event format, so you have to translate it, create your own table, to have any hope of seeing the patterns.
    They were doing so good for a while, the 2014 model year for example. (attached)
  16. Tideland Prius
    16,677
    Ohh, good point. I missed that. I usually refer to the online one. (Or on both occasions when I bought the car new, the product advisor printed out the service schedule for me to store in the owner's manual pouch.)
  17. Mendel Leisk
    42,310
    Our 06 Civic Hybrid had blank pages for the service department to stamp and sign. When we first had it I was thinking to have dealership service, and at the first service I asked if they could stamp it. It seemed a novel concept to them, lol.
    After 3 or 4 oil changes where they routinely dumped in 4 liters of oil (spec was 3.2, with oil filter change), I gave up on that notion, went back to DIY. I hated sitting in that lounge too, the lose-all-hope lounge...
  18. Tideland Prius
    16,677
    Could be worse. You could be sitting in a different manufacturer's lounge called the empty-your-wallet lounge.
  19. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    Same car, same experience with the overfill. Also purchased the lifetime free oil change. Was nice until I found out they put recycled oil in there. Wondering what the viscosity of the recycled was?
    I don't want to even imagine where the oil filters came from.
    The waiting room had 6 presidential service awards on the wall.
    The steelership got a new name a few years ago. One of these days I'm gonna stop in just to see if those awards are still on the wall.
  20. alanclarkeau
    7,045
    7,593
    I'm not sure if some oils include recycled. The stuff which comes from the ground is crude - awful looking stuff, which is refined, and becomes a base which they then make into various retail products. I vaguely remember reading in New Scientist or Scientific American (??) years ago that recycled oils get included in that mix somehow.
