Why isn't the eco line stickier?
Discussion in 'Gen 3 Prius Technical Discussion' started by anon_prius, Apr 6, 2024.
  1. anon_prius
    anon_prius Junior Member
    32
    I hate when I'm riding along at full battery just under the eco line with the engine off getting 100+ mpge and I hit a small dip and it crosses the eco line and engages the engine. Why doesn't this transition point provide more resistance or work in ev mode for a bit longer before engaging the engine (including in eco mode)? Is there any timing software that can update the ECU to add these resistance points to the hybrid system so the eco line is not so easy to accidentally cross? Or is it best to just engage EV mode during long flat stretches that I know I won't need gas power?
  2. Mendel Leisk
    42,387
    ^ You're referring to this median line?
    This isn't a plug-in, just a regular gen 3?
    I wouldn't go chasing electric-only propulsion too hard. It'll eat up the charge especially fast if your're almost at that line.
    Extricator, Khezekiah and fuzzy1 like this.
  3. PriusCamper
    PriusCamper Senior Member
    13,479
    5,446
    Pacific Northwest, USA
    It's a hybrid... The engine compliments the Electric parts... They depend on each other for maximum MPG. However in coming years there's been lots of R&D in aftermarket battery packs that can improve your MPG with way more battery power, but it's still in an early stage of development.
  4. Leadfoot J. McCoalroller
    8,295
    7,814
    Pennsylvania
    2018 Prius c
    Think about it: if there were a deadband at this transition point, they'd be getting a lot of complaints about how the car always seemed to run out of breath at a certain point, THEN the engine fires and acceleration continues.
    Brian1954 and fuzzy1 like this.
  5. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    Probably doing it wrong. I get better mpg doing pulse and glide engine off under 45mph, and using the battery to shut engine off, and scoot up at stop lights.
    Running in EV too much just makes the engine run more.
    Roccobro and Extricator like this.
  6. bisco
    52,927
    a long time ago, someone wanted to know why there couldn't be a detent in the gas peddle before the ice fires
  7. Paladain55
    414
    172
    The South
    The halfway mark on the display works pretty good for me.
  8. bisco
    52,927
    hitting a small dip doesn't trigger the ice?
