why no prius diesel hybrid?!
Discussion in 'Gen 3 Prius Main Forum' started by arnoutterschure, Jun 22, 2008.
  1. thepolarcrew
    thepolarcrew Senior Member
    4,426
    271
    North Dakota
    "I was commenting on earlier posts that seemed to make mountains out of molehills. Agrandizing technical issues as unsurmountable impediments is pessimistic, IMO."
    DaveS, you aren't alone when it comes to these thoughts. It seems like the site has a one sided approach to almost all issues. The enviroment, Ford, GM, price of fuel, etc. Nothing wrong with having pride in what you believe in.
    Not trying to be a troll, rant or spew diatribe is almost imossible if you dissagree. You have people whose cars are being shot. Could it possibly have something to do with how you act or something you say. I am not condoning this sort of behavior, but when you berate and belittle people and try to cram your ideas down every-ones throat it seems to happen in the real world.
    We need to face the facts, this is kill our way of life. We need use the best information, technology and resources available to date and take action NOW!
  2. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    I'm not even going to touch on the argument that a comparable sized gas engine has more torque than the same displacement diesel engine. That's just false and ridiculous. Now some may be tuned for less torque by optimizing them for more horsepower.
    Remember, torque is power. Horsepower isn't really measured. Horsepower is a calculation based on torque. This is why a faster revving motor will naturally have more horsepower. Horsepower and torque are equal at 5252 RPM (assuming the engine spins that fast). Because of this, a relatively low RPM diesel engine is at a disadvantage.
    As was said by another poster, a system in which the diesel engine just charges batteries or provides power generation for an electric motor could work. In a hybrid system like the Prius I don't see the diesel as being an alternative. First off, the Prius requires a engine that can vary RPM quickly. The diesel engine doesn't do this. In fact a diesel is very efficient at lower RPM's, but when run at higher RPM's the fuel economy drops quickly. For example, I can pull my 12,000lb toy hauler with my '01 Dodge Cummins dually and get 14mpg. I've actually gone on a road trip WITHOUT my trailer and gotten 12mpg. When I got 12mpg, the engine was running about 3,000 RPM most of the way because I was driving fast. Yeah, part of that was wind resistance, but the point is the percentage of mpg drop on my diesel truck was far greater than it would have been if I was driving that fast with the V10 version of my truck.
    The second reason why I don't believe the diesel is a good fit for a "Prius type" vehicle is diesel engines need to stay warm to be efficient. They're a compression engine and need this heat to run. Having them turn on and off at the drop of a dime isn't a good fit.... particularly in colder climates. Not only will restarting not be very smooth (a result from them being cold and the higher compression), but may potentially lead to problems such as cylinder wash where unburned fuel is forced past the piston rings and into the oil. This is a common problem with people that let their diesels idle and the reason why over the road truckers typically have their exhaust brake rigged to be able to be partially closed while idling and/or they high idle their trucks. Keeping their post turbo exhaust gas temperature above 300 degrees while idling prevents this.... This is the reason why many owners manuals for diesel powered vehicles have a idle limit of usually around 10 mins...
  3. Flying White Dutchman
    4,376
    313
    the modern diesel your talking about is a commen rail variable turbo charged injected diesel and there is a lot more electronics going on then a simple todays petrol car engine.
  4. Dozzer
    Dozzer Prius Noob
    189
    Swansea, UK
    Deisel maybe more efficient than petrol... but here are some facts about oil production...
    For every 100 barrels of oil (North Sea crude) you get about 47 barrels of petroleum (gasoline) and only 28 barrels of deisel... the rest is jet fuel, heating oil etc.
    In order of most profit for the oil producer:
    Jet fuel (kerosene derivetives)
    deisel
    heating oil
    Apparently the company who runs North Sea Oil production here in the UK aim for a per barrel profit of 100USD
    It costs around 15USD to get the barrel out of the ground.
    The price of deisel will go up faster than gasoline as it's used for a lot more than just driving a family car about.
    Doz
  5. SZ92
    SZ92 Junior Member
    43
    Wow you dont know anything about cars do you. My 2008 Mercedes Sprinter has a 3.0 Liter 6 Cylinder diesel turbo charged and it puts out 270-285 lbs of torque whereas my Chevy Express 4.8 Liter 300 HP only put out 250 at the most so your statement about diesels is completely wrong
  6. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    I don't believe you noticed my phrase "for the same technology level".
    Yes - you can make a turbo-diesel have more torque than a naturally aspirated gasoline engine but if you put the same level of technology into a gasoline engine you could get even more torque than the diesel.
    Now some of the recent developments by companies such as BMW and VW are doing incredible things with diesel engines and less into very high-power gasoline engines but in general a gasoline engine can give you more torque and much more power than an equivalent diesel engine for less cost.
    It boils down to the fact that it is difficult to atomize the fuel well enough in a diesel engine to run it as rich as a gasoline engine - a diesel engine will smoke excessively before it gets near to stoichiometric ratio, whereas a gasoline engine can even run slightly rich. So you can get more fuel into the cylinder and thus more torque, combine that with the ability to run much faster and you get much more power.
    Now a turbo-charger can help pack in the air into the cyclinder and let you put in more fuel to get more torque but it is only recently that the high inlet pressure ratios are becoming practical for everyday use. At these high pressures diesel engines don't suffer from pre-ignition that plagues turbo-charged gasoline engines so at some point they get the advantage.
    kevin
  7. RonH
    RonH Member
    556
    Well I remember from my freshman physics that torque is force x lever arm length. Work is down by a torque moving the lever through an angle, thus power is torque times rpm, give or take a conversion factor or two. To say that hp = torque @ some rpm is just a coincidence of the units chosen and engine capacity and has no real meaning. Model airplane engines rev at 10K's rpms. I'm too lazy to surf the SAE site, but I'd guess hp measurement is done by measuring force via a strain gauge on the output shaft corrected to some standard diameter and multiplied by the rotation rate.
  8. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    I think thinking outside the box is good, whether its a gasoline-electric hybrid, diesel-electric hybrid, electric only, electric with gasoline or diesel generator, natural gas only, hydrogen, or whatever. As long as they're clean, efficient and affordable.
    Then we all just need to coexist. Sure we can have our Windows/Mac/Linux discussions, but... different strokes for different people is a good thing!
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    work = force * distance
    power = work / time
    torque is a measurement of twisting force.
    It doesn't matter how you measure the force, work, or power, as long as the methods are accurate.
    Car people love to argue about which is more important: torque or power. Since the two are interrelated, it may seem like a silly discussion. In some ways the discussion is silly, in others it's not. Here are the facts:
    1) At any given RPM, torque and power are equivalent.
    2) For a given torque, if you double the RPMs, you double the power.
    3) For a given RPM, if you double the torque, you double the power.
    (Please don't beat me up for playing fast and loose with the term equivalent. I'm trying to make a point for the non-physicists among us.)
    The above three facts are simply a restatement of the equations at the top of the page. From either, it's easy to see that there are two ways to get more power out of an engine: 1) make it bigger, so you get more torque, or 2) make it faster, so you get more RPMs.
    Bigger engines are larger and weigh more, which is a disadvantage in size and weight constrained applications. High speed engines wear faster, present more frictional losses, require complex valving, and require more gearing to match the engine to the load. It's a trade off.
    The whole torque vs. power thing comes down to gearing. Any engine can be geared to produce massive amounts of torque, but gears consume energy, take up space, add weight, and increase cost. This is why bicycles use a very simple and efficient gearing system.
    Since we are talking about bicycles, let's look at bicycle gearing and what it does to the rider. Our human rider is able to generate a certain maximum force on the pedals. This is the maximum torque of the rider (since the pedal arms are fixed, and torque = force * distance). Our rider is also able to pedal at different speeds. These are his RPMs. Our rider can generate more power by pressing harder or pedaling faster.
    Let's look at the first case: pressing harder. Going up a hill, our rider needs more power. He presses harder on the pedals. The hill gets steeper, so our rider presses even harder. As the hill steepens, he stands and puts all of his weight on the pedals. The hill steepens more, the bicycle slows and falls over. What went wrong? The rider ran out of torque. He was pressing as hard as he could, but it wasn't enough to keep the bicycle moving.
    Now let's try the same hill using gears. As the hill steepens, the rider presses harder. Eventually the rider says "I need to shift", and drops to a lower gear. His feet spin faster, but he doesn't have to press as hard.
    In both cases the rider increases his power output as he goes up the hill. In the first case it is done by increasing only the torque (force). In the second, he increases the RPMs. In practice you usually do both.
    We already looked at the limiting case with torque, when the rider could press no harder. How about the limiting case with speed (RPMs). In this case let us look at the example of riding a bicycle down a hill. Our rider is heading downhill, and wants to ride as fast as possible. As he heads down the hill, the resistance of the pedals becomes lighter, and our rider begins to pedal faster. Eventually the pedalling speed becomes uncomfortably fast, so the rider shifts to a higer gear. This reduces the pedaling speed. Our rider presses harder and speeds up some more. Once again the pedaling speed becomes too fast, and the rider shifts again. Our hill is long and steep. Eventually the rider runs out of gears. He pedals as fast as he can, but can't make the bicycle go any faster. The pedals turn easily, but he just can't make his feet go any faster. He is pretty sure if he just had more gears he could go faster. Why couldn't he go any faster? The rider had reached his maximum speed or RPMs.
    Just like an engine, our rider can develop varying amounts of torque and power at differnt speeds (RPMs). At the low end of the scale, our rider can develop maximum torque (force) at zero RPM, simply by standing on the pedal. At this point he is developing zero power, since there is no movement (power = work/time, work = force*distance, and distance=0), but maximum torque.
    On the other end of the scale, our rider can pedal so fast that no force is left for moving the bicycle. In other words, it takes all of the rider's power to spin his feet, as would happen if you put him on an exercise bicycle with no drag and said "pedal as fast as you can". Once again our rider is delivering zero power. In this case the RPMs are maximum, but the force is zero.
    In between these two limiting cases are the torque and power curves, which show torque and power as a function of speed. In the case of our human rider, as well as with many electric motors, the torque will be highest at zero RPM and will fall off with speed, while power will curve up to a maximum somewhere in the middle RPM range and curve back down at higher speeds, evtually reaching zero at the maximum unloaded speed. Internal combustion engines require some speed before they reach maximum torque, but that point will still be below the maximum horsepower point.
    What does all this mean? It means that torque and horsepower are interrelated. All torque or all speed results in zero power. Maximum power is somewhere in between, but you need enough torque to accerate up to the maximum power point. Gearing helps with this, but also consumes power through frictional losses.
    The Prius avoids most of the normal mechanical gearing by using the electric motors to provide virtual electronic gearing. The virtual gearing provides for a nearly infinite number of gears. While the virtual gearing avoids most of the normal frictional losses of mechanical gears, it does introduce electrical losses.
    Tom
  10. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Locomotives are a good example, however, we need cleaner (low sulfur) diesel fuel. Diesel fuel is a carcinogen (not that NOx from gasoline is inert). Locomotives use diesel to support an electric motor and are actually "electric" locomotives. The current Prius uses an ICE supplemented by an electric motor.
  11. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    diesel as general technology, make a lot of sense ... problem is:
    - dirty
    - noisy
    - shakey
    - pricey
    - complicated/less reliable
    -pricey fuel in the usa
    Add all of those to an hybrid vehicle and most of advantages of hybrid vehicles cancel out with diesel engine...
    Thats why no European manufacturer produced one massivly, and first tests from German magazines always said that "there is a lot work to be done".
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    This thread reminds me of the saying, "There is no replacement for displacement".
    Well, there is now a replacement for displacement. It is called electric motor.
  13. qbee42
    18,058
    3,079
    Northern Michigan
    "There is no motor without a rotor." No, that doesn't really work well.
    How about: "There is no omph without EMF"? That's even worse.
    We can't switch to electric motors until we find a replacement phrase!
    Tom
  14. qbee42
    18,058
    3,079
    Northern Michigan
    Since we are talking about diesel engines, let's talk about some real diesel engines, like the one we have in our sailboat. Nothing fancy, just 500 pounds of steel for 10 horsepower. It was made in Bergen Norway by Sabb, not the Swedish company Saab.
    Our engine is a Sabb Model G 10hp marine engine. It has a single cylinder with a displacement of about 45 cubic inches. Redline is 1800 RPM.
    I have included links to several youtube videos. Our engine looks and sounds exactly like the ones in the videos. The only difference is that ours is blue and clean. It was one of the very last ones made by Sabb before production was discontinued. We imported our engine directly from the manufacturer. They built it to order, machining the parts and assembling only after receipt of the order.
    There are a lot of videos below. If you don't look at any others, play the first one to get a good feel for the sound of a big one-lunger.
    Tom
  15. Tchou
    Tchou Member
    161
    Having Higher mileage doesn't mean pollute less...
  16. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    I'm not sure the added cost and complexity of adding a diesel to what many already consider (rightly or not) an overly complex and costly vehicle would be a good move. Diesels have their advantages and disadvantages, but I'm not sure adding a hybrid system to a diesel plays to its strengths and compensates for its weaknesses the way adding one to a gas engine (particularly Atkinson cycle) does.
    Take the previously mentioned Peugeot 307-308/Citroen C4 diesel hybrid concept as an example.
    In 2006, the concept was touted as 3.4L/100km:
    Green Car Congress: PSA Peugeot Citroën Unveils 69MPG Diesel Hybrid Prototypes
    In 2007, they are moving toward 2008 production but claim has dropped to 4L/100km:
    Peugeot to release a diesel hybrid in 2008 Envirofuel - Promoting sustainable mobility
    On a similar European combined cycle, the Prius achieves 4.3L/100km:
    VCAcarfueldata.org.uk - Search Results - Further Information
    Its worth noting that the C4 is also smaller and slower than the Prius. It has about 10% less passenger volume, and about 20% less cargo volume. The diesel and hybrid versions were both projected at 12.4s above, but specs below put the non-hybrid at 13.9s.
    Citroen C4 1.6 HDi VTR Coupe 2007. Pictures. Specs.
    Toyota Prius Hybrid 1.5 2007. Pictures. Specs.
    So, lets say they are able to get the diesel hybrid out and they are able to hit their latest 4L/100km target. That would put it at 7.5% better than the Prius (ignoring the speed/size difference). Right off the bat diesel puts out 15% more CO2, and currently costs 12.5% more so there is no advantage in terms of carbon footprint or fuel costs. On top of that, while the latest diesels with DPF are almost as good as the dirtier of the gas cars they still aren't nearly as clean on emissions as the latest hybrids. And of course we also have to keep in mind that next year's Prius will be even bigger, faster, lower in emissions, and 10-15% better in FE further widening the gap. It also seems slightly suspicious that I can't really find any info on the Peugeot/Citroen effort after mid-2007.
    Where I can see diesels potentially coming into play is in serial plug-in hybrids. This puts the diesel in its ideal rpm/load steady state operating region to maximize its efficiency. It also moves most of the diesel emissions out of urban centers, as you would not normally need the engine at all around town. The 80-90% reduction in fuel consumption achievable in the LDV fleet with longish range PHEVs (say 40 mile EV range) might also be a key enabler to making bio-diesel practical on a large scale.
    Rob
  17. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    If hybridizing diesel eliminate the need for expensive emission control hardware then you could see a diesel HSD.
  18. JSH
    JSH Senior Member
    2,605
    140
    PDX
    Emissions:
    To say that gasoline engines have lower emissions than diesel engines is just plan wrong. It was true 10 years ago but not today. Gasoline and diesel engines have different emissions. It is a “pick your poison” situation. Diesels have high NOx emissions while gasoline engines have high CO emissions. Diesel’s used to have high particulate emission but that has been fixed by particulate filters. (Note: this applies to on-highway engines not off-road, stationary, or marine diesels which were still largely unregulated until 2007)
    Consider VW’s newest diesel engine the TDI CR (Turbo-charged, direct-injection, common rail) vs their newest gasoline engine the TSI “twincharger” (Turbo-charged, supercharged, direct-injection)
    This is data from the UK equivalent of the EPA found here: VCAcarfueldata.org.uk - Home Page
    The performance data is from Volkswagen UK.
    Vehicle -------------------------Golf----------Golf-----------Golf---------Golf----------Passat---------Passat
    Performance:
    Engine ------------------------1.4L TSI --- 2.0L TDI ----- 1.4L TSI ------ 2.0L TDI ----- 2.0L TSI ------ 2.0L TDI
    Power (PS) ----------------------140----------140 ----------170 ----------- 170 --------- 200 ---------- 170
    Torque (Nm) -------------------- 220 -------- 320 --------- 240 ----------- 350 ---------- 280 ---------- 350
    Interior Noise (dB. ) ------------- 73 ---------- 72 ---------- 74 ------------- 73 ---------- 73 ------------ 69
    0-60 mph (s) ------------------- 8.8 --------- 9.3 --------- 7.9 ------------ 8.2 ---------- 7.6 ----------- 8.6
    Fuel Economy (l/100km) -------- 7.1----------- 5.5 ---------- 7.3 ----------- 5.9 ---------- 8.1 ---------- 6.1
    Emissions:
    CO2 (g/km) -------------------- 169 --------- 145 --------- 174 ----------- 156 --------- 193 ---------- 159
    CO (g/km) --------------------- 0.343 ------- 0.103 ------- 0.283 -------- 0.033 ------- 0.512 -------- 0.093
    HC + NOx (g/km) -------------- 0.085 ------- 0.261 ------- 0.074 -------- 0.222 ------- 0.064 -------- 0.177
    Particulates ------------------- 0.042 -------- 0.000 ------ 0.034 -------- 0.000 ------- 0.053 -------- 0.000
    Total Emissions (less CO2) --- 0.470 -------- 0.364 ------- 0.391 -------- 0.255 ------ 0.629 -------- 0.270
    Note: The UK TDI engines have the Particulate Filters but not the NOx Catalyst used in the US version. The US version with the NOx Catalyst produces 0.05 g/mile or 0.0805 g/km of NOx. This is a 66% reduction from the UK version though the test cycle is slightly different.
    Notice that the diesel engines are quieter, get better fuel economy, and have lower emissions than their gasoline equivalents. The gasoline versions accelerate faster 0-60 due to higher redlines that allow for fewer shifts. I would expect that the diesel would accelerate faster 50-70 in top gear due to the much higher torque output.
    Hybrids such as the Prius have lower emissions than any of these engines but that is due to the hybrid system not the superiority of gasoline engines over diesel engine. I expect that a diesel hybrid would have similar reductions in emission as a gasoline hybrid.
    Diesel Idling:
    Modern diesel engines do not have to idle, they can stop/start just like a gasoline engine. In fact BMW and VW are fitting stop/start technology to all of their diesel engines with manual transmissions. When you come to a stop the engine turns off and restarts when you start to let out the clutch.
    Also consider UPS, the largest logistics company in the world, and a company that operates a huge fleet of diesel engined vehicles. UPS has a strict no idle policy. When the UPS man comes to your door his truck is off. If repeated starts damaged engines do you really think UPS would make their drivers turn off their trucks for a 1-2 minute stop?
  19. Flying White Dutchman
    4,376
    313
    dont get the 0 Particulates\
    a Particulates filter is not filtering out al the Particulates.
    only part of the Particulates. and the rest is burnt into even smaller Particulates that go's out the exhaust
  20. miscrms
    2,079
    526
    Phoenix, AZ
    I can't agree with that statement. The latest diesels are certainly a big improvement and they are now comparable with some gas cars. However the state of the art in low emissions gasoline engines are still way ahead of the latest diesel. I did a pretty exhaustive comparison a little while back when the new numbers came out for the '09 Jetta TDI:
    http://priuschat.com/forums/prius-hybrid-news/49909-2009-vw-jetta-tdi-emissions-results.html
    Using your example of CO:
    CO: (g/mi)--- FTP75
    '03 TDI: ----- 0.2
    '09 TDI: ----- 0.4
    '08 5 cyl: --- 0.3
    '08 Fit: ----- 0.2
    Camry Hybrid:- 0.1
    '04 Prius: --- 0.1
    Based on those numbers and the rest from the link, the '09 TDI was well beaten in every onboard measurement by either a gasoline ICE or HEV or both. When you look at these results you have to bear in mind that as impressive as the Prius' numbers are its old technology now. The Camry hybrid and Lexus hybrids all have lower numbers than the Prius despite their higher fuel consumption. Given that, one would expect the '10 Prius to be even better.
    I also think the notion of summing up "total" emissions is useless. That presumes that every compound coming out of your tailpipe is of equal concern. This is clearly not the case. Some are toxins, some carcinogens, some contribute to smog, some to greenhouse effect. The relative importance of those separate issues, and the concentrations in which they are important vary by many orders of magnitude. I realize I sort of did the same thing with my score card, I've already taken my licks for that on the tdiclub.
    I find the '09 Jetta TDI a much less objectionable choice than I did the '06 and earlier, but I still don't see it in the same league as the best of the Hybrids. If a diesel hybrid can give similar or better emissions to a Prius, and be competitive on cost I'm all for it. We've yet to see any proof of that in the market though.
    Rob
