Why "plug in" versus "hybrid?"
Discussion in 'Environmental Discussion' started by qdllc, Aug 28, 2013.
  1. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    OK. He is in the FL Power and Light schedule so his rate is between 9 to 11 cents/kWh.
  2. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    PS Watch out for the taxes, those are not included in any rate and really affect the final bill.
    52,805
    that is the final bill, $80. for 876 kwh. sounds like .09 compared to my .17.:(
  4. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ...alrighty then his place is a bit cheaper than average and Boston is a little above average cost...
  5. qdllc
    qdllc Senior Member
    1,377
    400
    In the USA, power only comes in 110V. Your house has two 110V lines to it. For 220V outlets, both lines are hooked in at the breaker box. If you ever have a power issue to your house with a faulty line connection, about half your house won't work because the line providing power that feeds those circuits has failed (seen this happen). So, 330v and 440v is just a matter of more supply lines and a properly set up breaker box.
  6. icarus
    icarus Senior Member
    4,884
    976
    earth
    ^this is not quite right. Power to (most) N. American homes comes of the transformer as 240 SPLIT PHASE. What happens is, they take the higher voltge pole line, of say 14.4kv, hand a transformer on the pole. (or in the underground vault) this transformer steps the voltage down to line voltge. Using a center tap neutral, two feeds come off the transformer, each 120 vac, 180 degrees out of phase with one another. So you are right, there is two "independent" 120 vac lines, but if you combine the two with a common neutral you get...240 single, split phase.
    You can't simply tap another , and another, and another 120 vac off the same transformer and get, say 330 or 440. You would need a higher root voltage transformer. 3 phase wiring requires 3 separate feed lines from the utility, each 120 degrees out of phase with one another.m if yu look up at your utility pole, a simple 240 split phase only requires a single HV conductor on the poles, (plus a grounded neutral) a 3'phase system has three conductors plus the neutral. You can pull split phase simply off one of those conductors, so you may have 3 phase available (or not) but are using single phase. 3 phase is much more expensive to install on the poles, and is not available in most location. It is very useful however in industrial applications for motor loads, s the motors run much more efficiently on three phase power.
    But back to the original statement. It really doesn't matter wht the root voltage is for charging an EV, as power is the product of Volts X Amps! If it takes 6 kws to charge a leaf or. Volt for example, you can get there with 50 amps of 120 vc, or 25 amps of 240 vac
    Icarus
  7. qdllc
    qdllc Senior Member
    1,377
    400
    Another question....
    The plug-in is basically a Prius with an extra battery and "tuning" so the EV mode runs under more load and higher speeds before the ICE kicks in.
    So, for those who aren't living in a place where they can go exclusively EV all the time they drive, how much better MPG are you getting because of the extra battery and extended EV performance compared to the standard Prius?
  8. bwilson4web
    16,519
    I do not have a plug-in so this is something I learned from John1701a.
    • If by happy accident, your daily driving can be EV supported say close to work and/or plug-in at work, you can drive without burning any gas.
    • If your daily trip is longer than the ~11 mile range of the traction battery, you can warm-up the engine at "idle" fuel consumption while driving the first 1-2 miles. Then you can 'bank' the rest of the traction battery energy and be driving a Prius at +60 MPH.
      • For planning purposes, use 30 MPG for the first 1-2 miles, and 50-60 MPG depending upon the mix of City and Highway driving.
    You might consider searching first and then posting your question in the Plug-In forum.
    GOOD LUCK!
  9. John H
    John H Senior Member
    2,208
    558
    just so that you don't make another common mistake ... the Plug In Prius is a Plug In Hybrid (PHEV). The Tesla is a Plug In Battery Electric Vehicle (BEV), and the Volt is a Extended Range Electric Vehicle (EREV). The three different approaches have significant differences resulting in drastically different gasoline consumptions depending on your driving profile.
  10. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    The short answer is the current PiP does not seem give any MPG advantage (over HEV hybrid Prius Gen3) when run in hybrid gaso mode without charging up. In other words, the regular Prius battery size is already pretty much optimized to maximize MPG, without much further MPG gain if the battery is bigger (keeping in mind that adds weight).
    I don't own a PiP either but I believe a number of owners do not charge it up, just use it as a hybrid. For one reason, in CA, for example, you get HOV access with the PiP.
  11. austingreen
    austingreen Senior Member
    13,713
    4,231
    Austin, TX, USA
    lol. Resistance heating is extremely efficient. Arc welding, if you are doing work (want it welded) is a good dual use, as the heat is free. Arc welding is extremely inefficient if you don't want to weld anything.
    a heat pump is not more efficient than resistance heating, it is doing less work. Something gets colder so the air inside the house can get warmer (or when used as ac something gets warmer so the air inside the house can get colder). This requires less electricity than resistance heating because you are doing less work with the energy.
    Burning natural is more efficient than electric resistance heating, if the electricity comes from natural gas or coal, simply because of the in efficiency of the power plant and transmission. For dollar efficiency, solar panels to electric resistance will be cheaper than other schemes for solar heating. Green building to require less heating is ofcourse the cheapest if it is new construction.
    Which brings us back to arc welding versus say an electrical heat pump in a bev like the leaf. The ice is more efficient for heating, because it is waste heat generated by ice. Its free heat once the ice warms up. Other things in a bev will be more efficient, but not heating it.;)
  12. austingreen
    13,713
    4,231
    Austin, TX, USA
  13. Mendel Leisk
    42,302
    I would think the number one reason is money: it'll cost you less to fuel the car, gas and electricity, in virtually all scenarios, month to month.
    I agree the electrical supply may not be all the green, but...
    austingreen likes this.
  14. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
  15. austingreen
    13,713
    4,231
    Austin, TX, USA
    The problem here is they use old figures. For example in ercot, they state a renewable goal of 5.5GW by 2020, ercot now has 9.6 GW of wind alone, and new goals set. Coal is at 45% in that report for the country, it was down to 37% last year, it may go up to around 40% this year, but long term it should get much lower than last years 37%. These things don't really affect california, but greatly reduces electricity impact for charging cars in states like texas.
    Most plug-in drivers care more about reduced oil consumption than ghg pollution. In fact in polls ghg (CO2) emissions were not high on the list of priorities. In california 39% of plug-in owners have installed solar, so that they have less reliance not only on OPEC and big oil companies, but also less reliance on their utilities that are also unpopular (I hated PG&E when I lived there).
  16. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Sure, I agree that most people's first thought is to just use less gas.
    I don't think you could ever get a report like the one above that was exhaustive enough to cover the entire country, yet get everyone to agree on every number, or for the numbers to be totally relevant for any period of time. It merely provides a baseline for people to go on - as there are obviously states whose electrical grids are generally much cleaner than others.
  17. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Sure it does. Once the electricity is delivered, resistance heat is near 100% efficient. Doesn't get much better than that! Sure heat pumps look like they are getting 300-400% efficient, but that is only because they are getting heat from somewhere else (i.e. you aren't accounting for ALL the energy in). The advantage of heat pumps is that likely don't have to PAY for that heat.
    FL_Prius_Driver likes this.
  18. Corwyn
    2,171
    659
    23
    Maine
    Actually Watt-hours. That is Watts * Hours, not Watts / Hours.
  19. icarus
    4,884
    976
    earth
    ^True dat! Question is, when is a slash NOT an indication of a arithmetic process? Which is the proper symbol, forward or back slash to connote division?
    We often use AC to define Alternting current, and use A\C to define air conditioning, even when it is not air DIVIDED by conditioning.
    In any case WH would be the proper example of Watts*hour.
    Icarus
  20. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Here in Ohio, PIP does not make sense. 100% of our power comes from older coal fired power plants. I read an article in the local paper that more pollution is generated here recharging the PIP battery than the emissions saved vs a standard Prius.
    Sadly, I'm generating more pollution just reading this forum. I'll just go back to my cave now and stare at the mammoths drawn on the walls. That way my only emissions will be methane, which sadly is also a greenhouse gas.
