Why Prius 2010 gas one Drive gear
Discussion in 'Gen 3 Prius Technical Discussion' started by harshy7, Mar 6, 2010.
  1. harshy7
    harshy7 harshy7
    Deep River, ON, CANADA
    My old Corolla automatic transmission used to have Drive D followed by several lower:rockon: gears. I used to shift to lower gears while going up or down a mountain. This helped in braking through engine RPM change. So why Prius 2010 changed all this to only ONE drive D? This has nothing to do with ABS fixes.
  2. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    Use B mode going down those mountains...
  3. dr_d12
    dr_d12 Member
    154
    Um...
    There is a lot of good information on this site if you search for it. It seems to me that "CVT transaxle" and "regenerative braking" would be a good place to start.
  4. richard schumacher
    7,663
    1,038
    United States
    That would be the whole infinitely variable transmission thang.
    "B" is used only for coming down mountains because it invokes/allows more engine braking to avoid riding the brakes. Using it anywhere else will harmlessly but pointlessly reduce MPGs. It in no way changes the effective transmission ratio.
  5. spinkao
    spinkao New Member
    316
    76
    Czech Republic, EU
    Because Prius has only *one gear*. If you are interested in how the Prius transmission works, read this:
    Whats Going On As I Drive?
  6. northwichita
    481
    102
    29
    Wichita KS
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    It would also make sense to post this question in the Gen III forum since you are asking about a 2010 Prius.
    Tom
  8. austingreen
    austingreen Senior Member
    13,533
    4,063
    Austin, TX, USA
    because there are not real gears like in your corolla.
    Honda in their insight created 7 pseudo gears, and I like this solution better. Although I have no idea why they chose 7 or what the best number should be.
    The prius has a B gear that is quite like a 2 on traditional automatics.
    Since there is no completely right answer, you can decide if you like toyota's 2 or honda's 7, or even if you like the implementation. I'd really like speed racer style buttons.
  9. Harold Bien
    Harold Bien Member
    113
    39
    Stony Brook, NY
    As everyone pointed out this is by design. However, I would suggest that future incarnations try to capture on the "traditional" feel of gears as they did (I believe unfortunately w/accelerator pedal at neutral = slight decel).
    There have been issues with the joystick transmission setup especially with the separate button 'P'. I would suggest instead, a more intuitive approach using a standard shift controller with the positions: "P, R, N, D(Eco), D(Nml), D(Pwr), B". Although debatable, I feel this parallels better the traditional concept of "shifting down" in an automatic (although I still prefer manual, lol)
    D(Eco) would be the "default" akin to D3 on traditional cars and would put the car into "Eco" mode. This would get you weaker acceleration (not really true on automatics, but if you imagined a manual transmission, keeping a car at high gear makes it go fast but very weak acceleration). D(Nml) would then improve on that acceleration, and finally, of course D(Pwr) representing "Power" giving you maximum acceleration similar to being in low gear.
    I had trouble fitting "B" because it can be invoked in Eco, Nml, or Power modes, but I think it most fits at the end because there it simulates gearing down to a really low gear to use engine/compression braking. This should remove the thought of "B"="Battery".
    Heck, they should probably rename "Eco", "Normal" and "Power" to just D3, D2, and D1 anyway to remove any misnomers (as if Power is not eco-friendly when it can probably be more fuel efficient than Eco or Normal if the car is driven in an aggressive manner).
    Then just rename "B" mode as "D0" eliminating further confusion with "Battery" mode. The only disadvantage is that you'd have to be in "Power" mode by the time you engage "B" meaning either you're going to be shifting rapidly between B and your desired drive mode or stuck with using Power (not a bad idea if you consider steep downgrades are usually followed by upgrades and that you'd probably get better mileage when climbing back up to shift away from B mode instead of leaving it engaged).
    I say bring back the simple shift selector with button interlock to avoid the 3-second delay but keep it electronic.
    One final advantage of this method? You could continue to emulate "old automatic" style behavior of flashing the reverse lights (as you pass through R) when engaging Park. I've used this trick sometimes to identify a car ahead has just engaged Park or has just shifted out of Park.
  10. Tom183
    Tom183 New Member
    652
    65
    Maine
    Pretty sure the best number is zero (CVT). This may be why the Insight is less efficient, particularly off the highway.
  11. mainlin
    mainlin Junior Member
    25
    Lower Marion, PA
    I had a 3 Diamond Outlander SUV with a 'fake' computer generated 6 spd. CVT that you could lock into any speed, otherwise it shifted from gear to gear like any other auto/tranny. Liked it, but what I miss more than that with my '10 'V', is that when I put it into 'B' for engine braking, the cruise control cuts out- why? Very frustrating as I have to reset it from scratch every time. Getting use to the CVT 'rubber-band-drive' is not happening, the engine changes speeds, and sounds, but not much else speedwise happens in a direct relationship via the foot and ear inputs one expects in controlling one's forward movement in a car (regaredless of a car's use or gas, or electric, or both for acceleration.)
  12. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    So you remember you are in a power robbing state and shift back out of B, when you get to the bottom of the hill.
    I am surprised that anywhere in PA needs B. You only want to use B if you have over a 600 foot drop in a hill. No place in PA is over 3300 feet tall, but I suppose 700 ft of it could be in one incline.
    An example of where you do want B:
    http://www.oregon.gov/ODOT/MCT/docs/EmigrantHill.pdf
  13. mainlin
    25
    Lower Marion, PA
    I like B for the 'feely control' of going faster and slower by using one pedal on curvey roads and hills, like driving a manual tranny in a lower gear. It is not power robbing when you give the car gas (it acts the same as if it was in D), and it only hurts gas milage a little during braking. I shift to D during braking if I am going to do a complete stop so the battery won't be turning the engine over (it consumes no gas while it acts as a brake, or idles- being rotated by the electric motor.)
