Why should early buyers have to pay for USB? Here's the answer.
Discussion in 'Gen 3 Prius Main Forum' started by Danny, Apr 22, 2009.
  1. Jabber
    Jabber Chicagoland Prius Guy
    703
    215
    Chicago
    I believe Ipod has its own tech. Any MP3 player can be used via the aux port. But it can't be controlled like the Ipod as mentioned above.
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    The USB functionality allows you to connect a USB device, and control it through the car. So with a USB thumb drive for example, you should be able to navigate through the file structure (artist/album/track, for example).
    I'd imagine it would also work with a USB enabled MP3 player, although who knows if there are proprietary controls in the MP3 player that would preclude this.
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I "might" splurge for the USB upgrade if a self-installed price is <$299. I have a couple of Sansa's I could try to validate the theory. Worst case, they're viewed as mass storage devices with the MP3's played from the head unit.
    I believe Doug mentioned iPod and Zune in the chat thread though as compatible devices.
  4. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    yeah, if your usb mp3 player does support being seen as usb storage device (and most do) then thats the way it will work... there is no special way to control mp3 players.
    but easiest way is sto simply get 8 GB USB stick, which is now extremly cheap and simply drag and drop your music there... simple, effortless and cheap!
  5. HTMLSpinnr
    5,341
    920
    251
    I would recommend a high speed memory stick at 8+GB. Waiting for the car to index the music on a slower device would be a painful experience each time the car was started (unless there's some persistence in the "RAM" of the head unit).
    I have a slower Corsair 16GB (cheap after rebate), and the thing is ungawdly slow compared to smaller devices.
  6. irondentist
    irondentist New Member
    Cali
    Does anyone have a guess if the iPod can be controlled via Voice Command similar to the Ford Sync? I.E. you can tell the Nav Artist and Track names, instead of scrolling through the thousands upon thousands of songs you have on your iPod.
  7. Tideland Prius
    16,539
    Never tried lol. I know it will work for discs but I don't know about iPods and folders.
  8. Husker4theSpurs
    Husker4theSpurs Active Member
    656
    128
    Papillion, Nebraska
    So do we know FOR SURE that we can add the iPod/USB intergration later if we buy a '10 before September? Hope I'm making myself clear ... I guess I just want to make sure if I buy right away can it be added after it comes out so that it's exactly as it'd be from the factory after September?
  9. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Yes, but only for the Nav units. This is a quote from Doug Coleman (Prius Team) from another thread:
    "Just to be clear, the accessory iPod adapter will only be available on Prius II (base audio system). The September USB/iPod adapter will only be on Navigation systems. The non-Navi JBL audio will not have a USB/iPod adapter."
  10. hill
    8,779
  11. Gilbert
    Gilbert Member
    255
  12. Tideland Prius
    16,539
    At least it's under the USB tab and not the DVD tab :eek:
