Why so few shop recommendations?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sean_999, Aug 12, 2019.
  1. Sean_999
    Sean_999 Junior Member
    Seattle, WA
    There are a few threads of the "looking for a decent Prius shop in the _____ area" variety that do NOT lead to much in the way of useful recommendations. Given that much maintenance and repair work (not all, but still, a lot) on a Prius is somewhat specialized, I find this lack of info on shops a bit surprising, and more than a bit disappointing. I get the sense that owning a Prius is best left to folks willing and able to do a fair amount of DIY work.
    I live in the Wash. DC area and am searching for a shop to re-charge and leak-test the A/C on a 2005 Prius. Here are the 3 threads I've just looked at (the DC one for info, the others to see if shortage of info is specific to DC):
    Recommended Mechanics in Washington, DC / Maryland / Virginia | PriusChat
    Recommendations for Mechanic near Atlanta (for combination meter repair) | PriusChat
    Mechanic recommendations in King County/Seattle area | PriusChat
    Comments on any of this?
    Thanks,
    -Sean
  2. ETC(SS)
    7,571
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Or be able to pay the price that Toyota asks for their service shop.
    I don't think you should find the situation either surprising OR disappointing.
    The Prius is somewhat unique in a lot of respects and most independent shops just can't afford the training to "do it right" so they just don't do it at all. Most "american car" garages won't work on exotic foreign car brands either. Similar situation.
    I recently got a CanAm Spyder (3 wheeled motorcycle) and NOBODY will touch it except the CanAm dealers.
    52,877
    i would say most prius owners fall into three camps:
    dealer service, regular private mechanic or diy. prius are so reliable, it generally isn't necessary to find a specialty shop until they are too old to be worth fixing
    if you're in cali, there are a handful of recognized alternatives because there are so many prius.
    i still cannot find one in the boston area after 20 years
  5. Sean_999
    Seattle, WA
    Thank you, ETC, Sam, and bisco, for thoughtful -- and fast -- replies.
    I'm slightly confused, though, because the many (MANY!) PriusChat discussion threads on A/C work really seem to make clear that a typical auto shop won't have equipment for properly re-charging the A/C refrigerant of a Prius, because typical shops work on A/C systems that don't require special compressor oil, and they often (so I gather from those threads) won't even know that special care is needed for Prius A/C. Did I get the wrong message from those threads?
    -Sean
  6. JC91006
    16,937
    8,647
    Trusting a car forum to recommend a mechanic in your area is no different than looking at a Yelp review. This forum is used by people all over the world, surely to find one in your neck of the woods would be quite a challenge......unless you live in a big Prius city like Los Angeles and San Francisco
    Skibob likes this.
  7. Sean_999
    Seattle, WA
    I would disagree with your first sentence! There are plenty of clearly knowledgeable people taking part in extended in-depth technical discussions on PriusChat -- and I really do not see anything like that with auto shop reviews on Yelp. Not even close, really.
    And, regarding A/C issues, these knowledgeable folks are generally saying two kinds of things: (1) if you're seriously DIY, here's how to do it, what not to do, etc. (2) otherwise definitely take it to a shop that knows Prius A/C.
    I did nothing but DIY with various motorcycles for over 20 years, but a Prius is a very different beast (and back in my motorcycle days I had way more free time).
    -Sean
  8. JC91006
    16,937
    8,647
    If you can DIY a motorcycle repair, you can DIY most Prius repairs. All you need is techstream (a computer program) that helps you with the diagnostics and reading of various ECU's on the Prius.
    Regarding your statement of various clearly knowledgeable people taking part, those are usually not the mechanics you'll be going to, they are the enthusiasts that work on their own cars. The mechanics will be the same as the yelp reviews you read about in your own general area.
    AC is also not very different in a Prius, only the oil used is a different non conductive ND-11 oil. So if you go to a "hybrid" aware specialist for AC repair, they can handle a Prius without any issues. This car has been around since 1999, surely after this many years, you'll find quite capable mechanics that can repair this car. Main thing people say about going to a Prius expert is because you don't want the wrong oil mixed or put into your car, that'll screw up the entire system.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    @wjtracy is in Your area and may have a recommendation ;).
    Good luck and keep us posted (y).
  10. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    If you go back to the earliest days of Prius pre-2008 or so, there was a list of approved hybrid mechanics in the USA. That list included MAC in Ashland, Virginia way down towards Richmond and I think it was Hillmuth in Maryland.
    Since then it has been pot luck. I use my regular shop West Springfield Auto because they have a guy formerly with Toyota. I am not sure he is still working there, but he did my inverter pump last year. One option in DC area we have PriusHybridRepiar.com and they travel to the site. I saw their advertizement-rich custom painted Prius on I-270 is how I saw them. Various places but we have very little consumer input here.
    It's a little bit like the Maytag repair man with Prius being so darn reliable.
    #10 wjtracy, Aug 14, 2019
    Raytheeagle likes this.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I have never had repairs that were not road damage. I only really do routine maintenance, and the Dealer is fine and competitive. (Kirk Toyota, Grenada MS)
    So it is hard to say much about other mechanics near me. And everything else is rumor.
  12. lech auto air conditionin
    830
    606
    261
    san francisco
    All the way down in San Francisco there’s Luscious Garage. And all the garages I’ve worked in the past 30+ years they are definitely ahead of the pack. And when it comes to hybrids service for your Prius there at the head of the game. There is those who lead there’s those who follow then there’s those who just need to get out of the way. Luscious Garage is definitely a leader.
    But I will tell you lack of Training and not just learn by mistake Training like most shops do when they bring in a new technician who knows nothing a lot of expensive mistakes to both the shop and the owner of the car happens but never gets talked about. Most shops have those large automatic recovery recycle and re-charge machines usually several years old or older and they’re charging accuracy is not that good plus or -2 or 3 ounces which is a lot to the small charge quantity of a Prius. Most shops do not own a refrigerant identifier so every time a car comes in with Unknown contaminated gas they just suck it into their machine and mix it with all the gas that gets spread like a virus (STD) and pumped into all the cars that they work on after that . I’m top of that they have a Lotta overhead and it’s all about time and money high production and very very rarely if ever do they leave the vacuum pump on long enough to actually clean out your system thoroughly. When it comes to being cheap or lack of knowledge they do not even own the equipment let alone even know that it exists to literally measure the moisture content in your air-conditioning system after they finished performing a vacuum. They don’t care because it takes extra time and it’s not profitable. Then you have to include the shops that dangle the golden carrot in front of their technicians to make a bonus by moving fast and selling parts you could just let your imagination fly and guess what happens in that scenario.
    #12 lech auto air conditionin, Aug 15, 2019
  13. sam spade 2
    7,035
    2,804
    2017 Prius c
    Lots of good info. there.
    But could you PLEASE put some white space between lines occasionally.
    I find it almost impossible to read the way it is.
    Thank you.
  14. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    General observation: Washington D.C. appears to be the third biggest metro hotspot for Prius ownership after LA and SF.
    #2: Hybrids are what, 2-3% of the automotive market.
    Given these two? I'm not surprised that there are few recommendations overall, though if I really wanted to know where to go, I'd find a way to ask a taxi driver where they get theirs fixed.
    Sean_999 likes this.
  15. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    DC is the only "state" with hybrid incentive (sales tax free over 40 EPA City).
    VA and MD are pretty big Prii states, VA in part due to older HoV benefits which are phasing out.
  16. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    With the exception of a few shops where the owner is a Prius expert it’s a pretty dicey proposition to recommend a garage. The Prius expert may have left for another job, is on vacation, retired. Then you get someone else and come back here and say Skibob tricked or cheated me. Why bother with the hassle.
  17. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    One good reason for recommending not just the shop but also the mechanic's NAME.
  18. Sean_999
    Seattle, WA
    That's a good idea -- I was just thinking about the fact that so many taxi's are a Prius.
