Why the BMW i3-REx
Discussion in 'EV (Electric Vehicle) Discussion' started by bwilson4web, May 15, 2016.
  1. bwilson4web
    16,537
    So we have both a 2017 Prius Prime and 2014 BMW i3-REx . . . which one to drive today:
    • BMW i3-REx - best urban car, a pocket rocket with a high seating and excellent view. The power to weight ratio means point and scoot and the short wheel base parks easy. It has acceptable cross-country capability but stay near interstates especially at night as it is 80 miles per segment and carry a 1 gallon spare can.
    • Prius Prime Plus - best cross country car, smooth, excellent suspension and outstanding highway MPG. Visibility is much improved over our Gen-3 and the dynamic cruise control is great. Around town, know your charging locations and shop at nearby stores. The traction battery charges ~40% or 10 miles per hour and has no fast charging. In town, it drives like a tuned-up Prius, more than adequate.
    Data Daedalus likes this.
  2. bwilson4web
    16,537
    Source: BMW i3 plug-in hybrid recall to fix fuel-vapor problem, fire concerns
    BMW is recalling more than 19,000 i3 REx extended-range electric cars due to concerns over the potential for fires to be started by fuel vapors.
    The REx uses a small gasoline engine to charge its battery pack, offering a longer range than the all-electric i3 when both gasoline and electric power are used.
    According to the National Highway Traffic Safety Administration, the i3's fuel-tank vent line may rub against the ribbed wire protection sleeve of the battery positive cable.
    I am so glad we have a 2017 Prius Prime that replaced our Gen-3 Prius.
  3. bwilson4web
    16,537
  4. bwilson4web
    16,537
    HOME TO WORK
    Preconditioning, nice cabin and 100% SOC. Got to cross-town intersection and had forgotten work badge. Added 3 miles to commute and brought SOC to 87% instead of 91%.
    Work to Nashville
    About 8-9 miles, the SOC reached 75% and I turned on the REx. In Ardmore, 20-25 miles at the Interstate, topped off gas tank, grabbed a burger and unsweetened tea and on the 70 mph I-65.
    Now 70 mph is the REx output energy output. I had a 15 mph tailwind but had to climb the Piedmont. SOC decayed from 75% to 72% and stayed there.
    Followed a 70 mph truck to Nashville but ran out of gas 6 miles short with 70 miles EV range in battery. Horrors! I continued and arrived actually an hour early.
    Sweet Home
    Turns out ChargePoint had put in a new, four hose charger three blocks away. At $0.84/hr, reasonable. The a block and a half away, a new Japanese style restaurant and sushi bar. Just the thing to eat a brunch before heading to a gas station and home.
    Expenses
    • $1.19 - top off tank in Ardmore
    • $1.35 (7.161 kWh) - charge in Nashville, $0.18/kWh
    • $4.98 (2.007 gal) - fill-up tank in Nashville ($2.48/gal)
    • $0.72 (7.161 kWh) - charge in Huntsville residential rate, $0.10/kWh
    • $4.50 (2 gallons ) - fill-up local Huntsville fuel, $2/gal Reg, $2.25/gal Premium
    • $12.74 - expected gas and electricity
    • 234 miles - HSV->Nashville->HSV
    • $0.054 / mile
    With the expense per mile, we can reverse calculate the equivalent expense using Huntsville prices:
    • $2/gal Reg / $0.054/mile ~= 36.7 MPG (regular)
    • $2.25/gal Prem / $0.054/mile ~= 41.4 MPG (premium)
    Ouch, I was not expecting this but I did have fun driving the Bimmer. Given the measured MPG at 70 mph is 38 MPG, this is about right. I did not dilute enough of the trip energy with electricity, the cheaper fuel.
    The USA default is to turn on the REx at 6% but some have found there is not enough energy to handle highway loads without limiting performance during the engine warm-up. If I wait until the SOC is ~12-18% instead of starting at 75%, then more of the gas, the expensive fuel, will be preserved, left in the tank. FYI, the SOC was ~40% when I parked.
    The lesson learned is if you're blending electric and gas on a given trip, maximize the electrical usage and preserve the gas. This is not a trivial problem because loss of electrical and gas energy can be unpleasant. Time to carry a spare gallon for future runs.
    #364 bwilson4web, Mar 6, 2017
  5. bwilson4web
    16,537
    A little math fun:
    • cost_per_mile = cost_per_gallon / miles_per_gallon
    • EV_cost_per_mile = cost_per_kWh / miles_per_kWh
    So we can the calculate the trip cost:
    • n%_gas_miles
    • 1 - n%_gas_miles
    Huntsville:
    model gas_price kWh_price MPG mi/kWh $gas/mi $kWh/mi
    1 BMW i3-REx $2.35 $0.11 39 3.4 $0.0603 $0.0324
    2 Prius Prime $1.97 $0.11 54 4.0 $0.0365 $0.0275
    Nashville:
    1 BMW i3-REx $2.25 $0.18 39 3.4 $0.0577 $0.0529
    2 Prius Prime $1.92 $0.18 54 4.0 $0.0356 $0.0450
    ChargePoint $0.85 for 6.6 kWh = $0.18/kWh
    Gas prices from gasbuddy.com​
    Well I wasn't expecting this:
    • BMW i3-REx is more efficient EV regardless of Huntsville or Nashville rates, slightly.
    • Prius Prime is more efficient EV in Huntsville but somewhat cheaper on gas in Nashville
    This suggests we should be able to make a table of gas and electric costs that defines parity for both cars. Then select the motive fuel/energy to minimize the cost per mile. It should be linear relationship for each vehicle.
    #365 bwilson4web, Mar 7, 2017
  6. bwilson4web
    16,537
    Got a nice e-mail from ChargePoint:
    Hi Robert,
    Just a heads up, your Toyota Complimentary Charging balance of $98.65 expires in 60 days. Any remaining Toyota Complimentary Charging balance will disappear at that time, and has no cash value. See full terms and conditions here.
    Don't worry, you can keep using your ChargePoint card or mobile app to charge your Prius Prime after your balance expires.
    We hope you're having fun driving in EV mode.
    Charge on,
    Team ChargePoint
    I charged the BMW i3-REx in Nashville.
  7. bisco
    52,863
    very nice of them to send out reminders.
  8. bwilson4web
    16,537
    I have to admit, driving the BMW i3-REx around town is a blast.
  9. hill
    9,039
    To blow through that $98 credit on our employee Chargepoint EVSE's - costing 28¢/kWh, all i'd have to do is drive <20miles/day & i'd have all that $$ spent ... you can do it - easy peazy !
  10. bwilson4web
    16,537
    Electrical rate effect of BMW i3-REx, ~$20/month:
    • (20000 - (6440 + 1863)) / 10 ~= 1,670 miles / month
      • 6440 miles, when bought
      • 1863 miles, vacation 700 miles each way, 463 mile delivery
    • $20 / 1,200 mi ~= $0.017 per mile, out of pocket
      • $0.17 per 10 mile
      • $0.25 per 10 mile based on both free and home electrical costs (*)
      • $0.08 per 10 miles, free charging
      • ~1/3d free electrical miles
    • Charging just at home, estimated ~$60/month
    * - $0.10/kWh local Huntsville electrical rate
  11. bwilson4web
    16,537
    An opportunity missed.
    Saturday afternoon, I was running errands and stopped at Whole Foods. There were two families admiring a Tesla but no one around. So I backed in and plugged-in. Then I gave them a walk around and talk economics. One sat in the car and noticed the visibility and I'd opened the rear seat doors. I was thinking about giving some test drives but my wife was waiting at home.
    I regret not having the time to take them for a test ride. Unlike 2900 lbs, 168 hp, a test drive converts that into butt feel. Maybe another day.
    drash and Jeff N like this.
  12. bwilson4web
    16,537
    Source: The Electric BMW i3: Incorrect State Of Charge Readings Causing Problems For i3 Owners
    . . . look up service bulletins B61 20 16 and B61 20 17. These bulletins will instruct the dealers on how to correct the problem. You should also make sure you have software version 16-11-502 or later.
    . . . There have been cases where the software update didn't work for some reason. When that happens, the dealership needs to connect the car to BMW HQ and perform a remote IRAP session. The IRAP reprogramming will definitely resolve the issue if the software update doesn't.
  13. bisco
    52,863
    it's a work in progress.:cool:
  14. bwilson4web
    16,537
    A graphical history of a JuiceBox Pro 40:
    • Up until 2017 the EVSE was at home and we only had a BMW i3-REx, maximum 31A.
    • In 2017, the EVSE was at Propst where our BMW i3-REx, Prius Prime, and mystery cars could charge.
  15. bwilson4web
    16,537
    After a visit for the recall, I got a copy of the "Tire Tread Depth" which shows 'red' on the inner grooves:
    outer center inner side inner center outer position
    1 5 6 2 L(*) R 2 6 5 front
    2 5 5 2 L(*) R 1 5 4 rear
    * - the driver side
    The service writer suggested it was the aggressive regeneration. Since the rear, center grooves are shallower than the front, that would be the signature of regeneration wear. But the 1 and 2mm inner grooves fail on all four tires. These tires have +13k service miles and the service writer reports they typically last 15k miles. Tires that were new in June 2016, 10 months ago.
    Searching, I found heated, 'tire groove' tools, that have a mix of heated blades. These are typically used in competitions to improve tire performance. Prices range from $90-500 and there are different sizes and shapes, round and square. But they do not appear to have a gauge or stop to limit the depth (Oh give me a hard problem!) So this begs the question, has anyone thought to use a tire groove tool to deepen the shallow, inner groove?
    The rubber profile looks OK although the driver-side, rear looks a little raised. But if this happened on our Prius, I would look at putting in shims to give the tires more camber towards the outer tread. In effect, offloading the inner tread to even out the wear. But another alternative is a wheel alignment tool and add the camber without the shim. Anyone (@ericbecky or @3prongpaul ) look at this approach, adjusting the camber to offload the inner tire tread?
    Thanks,
    #375 bwilson4web, Apr 5, 2017
  16. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Don't re-groove the tires, that could cause structural failure I'd argue.
    In any case, that's a clear case of camber being too negative for your driving style and/or cargo/passenger loading. (Aggressive cornering requires more negative camber to maximize grip - to the point that when the suspension is higher in its travel, many suspension designs increase negative camber to enhance that, and counteract the effects of roll. This is also why cargo loading matters - if you're putting more weight on the rear end, the suspension is being pushed up in its travel, and may be increasing negative camber.)
    Whether shims are required is dependent on the suspension design of that car (seeing as it's MacPherson strut front, multi-link rear, I doubt shims will be required), but I'd take it in for an alignment. Optimum alignment is done with typical cargo, typical fuel loading, and typical passenger loading, but in your case, if you explain what's going on, a good alignment tech will know to add some positive camber (not actually take it to positive, mind you) based on the tire wear specs.
    One trick used in autocrossing is to chalk the tire across its full width, and onto the sidewalls, too, before going on a run - this gives a clear visual indicator of what parts of the tire are touching the surface. That's usually used for setting tire pressures - if the chalk line's getting worn off too close to (or on) the sidewall, you need to increase tire pressure. Conversely, if the chalk line's not getting worn off anywhere near the edges of the tread, you need to reduce tire pressure. That tactic, though, on a short drive, might be usable to check camber, too.
    It's also interesting that the right rear tire got the worst of it - that's the corner with the REx, right?
    Trollbait likes this.
  17. bwilson4web
    16,537
    Thank you!
    Upon further reflection, I agree that re-groove needs to be done carefully. Rather than just hack at it, I think I'll ask for both rear tires as they seem to have the worst of it. Then I'll see if I can section and experiment. My biggest concern is whether I'll be able to get a clean-cut through the belt with my reciprocating saw and a metal blade.
    I agree that the problem is the camber is off both front and back. Upon checking with Mr. Google, I plan to use the 'string plumb bob' technique to measure the camber of the existing tires. Once I have my metrics, I'll go back and discuss what we can do when they do the alignment of the new, rear tires, and let them get the first crack at 'doing the right thing.' I'll double check their work with the string plumb bob and if off, try to fix it myself without using a shim kit.
    Then we'll order the new front tires and again, ask to add some camber.
    I do like your suggestion of chalk testing the tire contact. The other technique I've used is tire tread temperature.
    You are right that the REx is located on that side. This is also the car that had the motor mount bolt on the driver side break. No telling what the heck it was doing before then.
    BTW, this car came without the tire goop and pump. The maintenance record shows it had a tire replaced which suggests it had a 'boo boo' with the original lease holder. These things can screw up other parts and one is always concerned that in an ordinary car, there might have been frame damage. I'm not ready to go there, yet.
  18. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I wasn't able to attend this SAE presentation in person but I figured Bob or others might be interested in reading at least the free preview version of this paper:
    "Control Analysis and Model Validation for BMW i3 Range Extender" from folks at Argonne Labs
  19. bwilson4web
    16,537
    Good news! A false-positive from the screening system.
    I spoke with the tech and he checked the tires and he thinks they are OK. I'll measure when I get home to make sure. Then I'll do a tread-temp test. If they are even, it ain't broke.
    The tech said their screening system is designed for wider tires.
  20. bwilson4web
    16,537
    Thanks!
    You're not crazy:
    So this morning, 63F, I ran at 60-75 mph on an extended commute and used an IR thermometer to measure the driver-side, rear wheel tread temperatures going from outside to inside:
    87.3 1st
    88.0
    85.9
    86.1
    86.4
    86.6 2nd
    86.1
    86.4
    88.6
    87.2
    87.6
    86.4 3d
    86.2
    86.3
    86.1
    85.8
    86.8
    88.4 4th
    88.1
    88.4
    88.1
    88.4
    88.6
    88.9
    88.8​
    The temperature profile shows the inner tread it doing more work than the outer tread. This is the signature of negative camber that would wear out the inner tread of the tires first. So I checked the training charts, pp. 24:
    • IO1 Chassis and Suspension
      2. Axles
      Rear axle adjustment values . . . I01 Standard chassis and suspension
      Camber ... -1 degrees 40 minutes
    Now this bothers me because the outer tread has the deeper groove. The inner tread starts with the shallower groove. This leads to two hypothesis:
    • The camber is wrong and should read +1 degree 40 minutes.
    • The tires have been mounted wrong side out.
    Regardless, it is worth sharing this information with NHTSA, Bridgestone, and BMW. I'm not terribly concerned about how this came about. But I am interested in getting serious people to start talking with each other.
    FYI, negative camber (tops closer together) in theory makes a car corner better as the lateral force would tend to move the tires into a more vertical orientation. But if you're going to do that, the thickest tread should be on the inside to wear the tires evenly and get a firm grip. Our tires are the reverse and that would lead to early wear of the thinnest part.
    It is not enough to have the tires mounted so the outside is now the inside. The grooves and tread pattern are critical to getting water out of the way so the tires won't hydroplane. If we become our own auto/tire engineers, we would need to quantify what happens in rain as well as on a track.
    #380 bwilson4web, Apr 12, 2017
