Why the BMW i3-REx
Discussion in 'EV (Electric Vehicle) Discussion' started by bwilson4web, May 15, 2016.
  1. bwilson4web
    16,531
    It worked except I haven’t trimmed the ‘bump’ on the tire surface. I’ll sand it down later today.
  2. drash
    drash Senior Member
    2,600
    1,339
    Upstate NY
    XLE AWD-e
    Well as someone who’s put in 14 plugs and counting, the biggest hint I can give you is as you are trying to push the plug in, twist the handle. Takes quite a bit a strength to expand the little hole that screw made with the plug, but it’s doable. I leave about 1/2” and used to trim it with a razor or utility knife, unless it’s in the tread channel. I don’t worry any more about trimming it too much as they wear really fast.
    I have had a hole where it was necessary to put in 2 plugs. I worried about that one and checked the air frequently, but the plug held and the tire didn’t lose air.
    Unsupervised!
    bwilson4web likes this.
  3. Trollbait
    12,822
    I once saw a photo where someone used multiple plugs to seal a slash in the tread.
  4. El Dobro
    El Dobro A Member
    7,106
    3,282
    Must've run out of duct tape.
    drash likes this.
  5. Trollbait
    12,822
    Duct tape only works when applied inside the tire.
    It's a pain getting the tape do into the tread for a complete seal, and then you are lucky to get a mile before wear of the tape starts the leak again.
  6. drash
    drash Senior Member
    2,600
    1,339
    Upstate NY
    XLE AWD-e
    Yikes! As much of a believer in plugging tires, I don’t believe I would have even considered it, much less waste a bunch of plugs on something that might lead to a blowout.
    Unsupervised!
