Why the BMW i3-REx
Discussion in 'EV (Electric Vehicle) Discussion' started by bwilson4web, May 15, 2016.
  1. Trollbait
    12,829
    Probably easier to invest in OBDII data app and bluetooth OBDII plug.
  2. bwilson4web
    16,535
    Working on a more accurate cost per mile model, I ran to work and back:
    5.4 kWh = 20 mi / 3.7 mi/kWh
    $0.54 = 5.4 kWh * $0.10 / kWh (highest residential rate)
    $0.027/mi = $0.54 / 20 mi
    0.9% SOC/mi = (100.0%-82.0) / 20 miles
    JuiceBox Pro 40A
    $0.466 = 4.66 kWh * $0.10/kWh
    $0.233/mi = $0.466 / 20 mi
    1:06 hh:mm charge time
    Idaho National Labs: Vehicle Testing - Light Duty - All | Advanced Vehicle Testing Activity
    • $0.10-11/mi - Gen-3 Prius(*)
    • $0.22-23/mi - BMW i3-REx(*)
    * - includes fuel, insurance, and registration
    Curious, their results are so different from mine.
    We also have a Gen-3 Prius:
    • $0.034/mi = $2.00/gal / 52 mi/gal
    Today, our $0.0233-$0.027/mi, BMW i3-REx is cheaper per mile than our $0.034/mi Gen-3 Prius. However, a Gen-4 Prius has a chance of parity. I won't know until I get a chance to benchmark a rental, Level 2 ECO. However, I need to check calibrations, part of this exercise.
    #142 bwilson4web, Jul 19, 2016
    drash likes this.
  3. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    $0.10 / kWh - that is a nice price for electricity for higest residential rate. This number can vary for more than 100% depending on where you live.
    Together with depreciation my nearly 7 year old and 73k miles, Prius has costed me €0.35 / mile, fuel alone is € 0.1 / mile at EU prices.
    cwerdna and bisco like this.
    52,855
    24 cents here, makes no sense.
  5. bwilson4web
    16,535
    TVA has nice rates although I understand they are planning a rate increase.
  6. bisco
    52,855
    i think we're paying for natural gas pipelines, but some of the cost is political, and the utility is been purchased several times over, so there is debt to be paid for.
  7. Trollbait
    12,829
    Idaho National Lab might have gotten a high insurance quote for the i3, which would be expected for a BMW with carbon fiber body and aluminum frame.
  8. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    It can be a HELL of a lot more than that.
    Pacific Gouge and Extort's rates non-TOU rates are at http://www.pge.com/tariffs/tm2/pdf/ELEC_SCHEDS_E-1.pdf (page 1).
    I'm on E-6 (page 2 of http://www.pge.com/tariffs/tm2/pdf/ELEC_SCHEDS_E-6.pdf, page 4 explains their byzantine structure).
    I'm in area X, code B, so my baseline is 10.1 kWh/day in "summer" and 10.9 kWh/day in "winter". So, for a 30 day billing month, my allotted baseline is 303 or 327 kWh each. If I use beyond 303 or 327 kWh in a month, I start paying the higher rates for amounts I use above these baselines (e.g. 101 to 200% of baseline... PG&E's been eliminating tiers, that's why 101 to 130% and 131% to 200% are identical in price now).
    If I'm on E-1, the cheapest I can get electricity is for 18.2 cents/kWh. The 101 to 200% portions above baseline will be 24.09 cents/kWh. Stuff above that is 40 cents/kWh.
    bedrock8x likes this.
  9. bwilson4web
    16,535
    I was working on how to add a plug-in port or outlet at work when I realized, there is no point. Now that I have a data recording, high-speed charger at home (see below,) it costs just under $0.60 per day for a round-trip, commute to work. Charging at work would only save $0.30 which isn’t hardly worth the trouble. Especially because there are four free chargers, two at Whole Foods, 3-4 miles away, and two at Bridge Street, 2 miles away, where I can eat lunch for between $5-15 and save nearly half of my commuting costs.
    I did not buy the BMW i3-REx to become dependent on someone else for a plug or hose. I bought it for the freedom to go where I want and when I want. Now if an enlightened business would like my patronage ... well I do like free chargers.
  10. bwilson4web
    16,535
    A Facebook essay shared with my family:
    July 11-12, we finished the last of the house wiring upgrades. The outer insulation of our 48 year old, utility service line had rotted off so adding the NEMA 14-50 (aka., RV park socket) required utility service rewiring too. For a little more, we went from 100A to 200A service with a 'transfer switch' for an emergency generator.
    Level 1 (120VAC, 12-15A) charger
    The BMW i3-REx comes with a 120VAC, 12A Level 1 charger. Initially we plugged into a kitchen wall outlet close to the driveway. We limited the current to 10A but accidental operation of the microwave or toaster would trip the 15A circuit breaker. But when sleeping, who is cooking?
    Later, I bought the parts to make an adapter for the dryer socket, a NEMA 6-30 three-prong Y-socket. The adapter split it into two, independent, 15A circuits, using NEMA 5-15 (regular house plug) with ground fault safety. This meant we no longer ran an extension cord from the kitchen and let the Level 1 charger run at full, 12A. But it still took hours to top-off, charge the car after an ordinary day of driving. Still, with an occasional visit to the free, high capacity Level 2 chargers or using the range extender (REx) engine, no problem.
    Level 2 (240VAC, 32-50A) charger
    We bought a 'JuiceBox Pro 40' that comes with a NEMA 14-50 plug like those found at RV parks. But the BMW i3-REx limits AC charging to 32A. The Level 1 and Level 2 charging circuits, built into the car, set the charging rate. So I've actually 'overbuilt' the NEMA 14-50 circuit but that capacity is available for a future EV and reduces wiring losses.
    I usually get home with about 80% battery level. The car fully charges in an hour and 15 minutes and a discharged battery should take 3-4 hours. I no longer need to visit the 'free', high capacity Level 2 chargers.
    Cost EV vs. Gasoline
    Our highest residential power rate is $0.10/kWh and my typical, workday driving takes just under 6kWh for ~20-25 miles or just under $0.60/day. I was looking at work-place charging but it would only save $0.30/day. Over a year, ~250 work days, saving $150. But eating lunch at free Level 2 charger does the something.
    Our 2010 Prius gets 52 MPG in a similar commute and regular gas today is $1.88/gal. So 25 miles would be half a gallon or about $0.94/day. Prius parity occurs when gasoline reaches $1.20/gal. But the BMW i3-REx uses plus gasoline, $2.18/gal, at 44 MPG or about $1.35/day.
    A new 2016 Prius was offered for $28.5k versus the $29.9k paid for the BMW i3-REx. But with the 16kW, natural gas generator, our BMW i3-REx runs on:
    (1) TVA electricity (~$0.60/day)
    (2) gasoline (~$1.35/day)
    (3) natural gas generated electricity (~$1.08/day)
    drash likes this.
  11. bwilson4web
    16,535
    First full month utility bill which arrived with the hot weather:
    • $8.88 - access charge
    • $129.30 - 1400 kWh @$0.092360
    • $52.96 - 527 kWh @$0.100500
    • $191.14 - total, 1927 kWh
    July 2015, ~1600 kWh
    About alternate taxes to replace gasoline tax: https://avt.inl.gov/sites/default/files/pdf/phev/PEVandPHEVeVMTforIAHD.pdf
    • $34.73 - PHEVs
    • $72.22 - BEVs
    Seems like reasonable fees to me.
  12. bisco
    52,855
    has anyone asked them if they could come up with a road tax scheme for heavy vehicles that destroy the asphalt?
  13. bwilson4web
    16,535
    I understand there is a bill in Montgomery but I don't know the particulars. I was told by a guy at work who is building his own EV.
    He introduced me to a lady at work who bought a Leaf a couple of weeks ago. Then another tenant came by when I was going to lunch asking questions about the BMW i3. So I'm thinking about making some 'Take One' flyers for the car.
  14. bwilson4web
    16,535
    Printing a couple of flyers to leave on the car:
    I've been approached roughly every 1-2 weeks by strangers asking about the car. If I have time, we chat but sometimes I have things to do and informal chats don't always cover everything. The only thing missing, follow-up. So I'm thinking about referencing PriusChat.
  15. bwilson4web
    16,535
    Looking for something else, I stumbled across the YouTube that raised my interest in the BMW i3-REx:
    I'm updating the flyer to include "carbon fiber body, aluminum frame."
  16. bisco
    52,855
    you guys are way more progressive than here in mass. it's amazing we even got a tax credit.
  17. Trollbait
    12,829
    The federal tax on diesel is higher than on gasoline; 24.4 cents to 18.4.
    NJ and Pa have higher registration fees on trucks than cars. Then Pa classifies a full size SUV as a station wagon, making it a car, even though it is more weight on the road than the trucks that are empty most of the time.
  18. bisco
    52,855
    and there are plenty of bigger trucks that run on gas.
  19. Trollbait
    12,829
    I don't think the weight difference between a mid-size car and a full size SUV results in a significant amount of road wear. The weather from the changing seasons seems to be the main culprit for potholes here.
  20. bisco
    52,855
    i was under the impression that potholes were the result of water getting under, and freezing an already compromised surface.
    i'm not aware of any study's of vehicle weight and road wear, but it certainly makes sense. the road bed beneath the asphalt is always subject to compression, and the asphalt itself, in warmer weather is subject to softening.
    but i'm also talking about pick up trucks, delivery vans, and larger commercial vehicles that run on gas.
