Why the Need for High Dielectric Refrigerant?
Discussion in 'Gen 3 Prius Technical Discussion' started by jimolson, Dec 12, 2023.
  1. jimolson
    jimolson Member
    162
    63
    Indianapolis, USA
    Why has Toyota/Denso felt the need to make hybrid AC refrigerant especially low conductivity with the use of ND11 oil?
    The obvious explanation is that mixing high voltage drive waveforms and conductive refrigerants presents a shock hazard to those working on HVAC subsystems. But more than 100 years of slightly conductive refrigerant hasn't revealed a refrigerant-caused shock hazard for those working on residential or commercial refrigeration systems.
    The difference might be that most residential and commercial devices are plumbed with copper or steel lines that provide adequate safety grounding--plus the likelihood that all players in the repair chain have some degree of training.
    I think Gen 2 Priuses have their HVAC compressor electrically isolated with rubber hoses due to mounting the compressor on the engine block. Is this a factor in the safety considerations?
    It seems that it would have been far simpler for Toyota to create a compressor mounting strategy that forced the unplugging of the HV wiring harness before removing the compressor from its electrically grounded mount. For example, the HV wiring plug could have denied mechanical access to at least one mounting bolt.
    For a moment I wondered if the need for low conductivity refrigerant is instead driven by a desire to squelch internal electrolysis (=corrosion) of motor windings bathed in conductive refrigerant. (Residential and commercial refrigerating systems are powered with AC, not DC, so the potential for electrolysis is zero.)
    However, it then occurred to me that the signal on brushless DC motor windings is AC, even if the power source is traction battery DC, so the likelihood of winding-to-motor housing electrolysis through refrigerant is pretty small.
    It is true that a poorly-designed BLDC motor circuit board could still have a high voltage DC common mode bias on its AC-driven windings, but this could be designed around.
    Using a traditional H-bridge drive scheme on the BLDC windings would still leave 200VDC of common mode bias on the motor windings relative to the motor's metal housing. Avoiding this DC bias would require the creation of a mirror-imaged, high-wattage negative supply rail for the BLDC driver circuit.
    Anyone able to shed light on the need for low conductivity ND11 refrigerant oil in hybrid vehicles with electric HVAC compressors?
    #1 jimolson, Dec 12, 2023
  2. Tombukt2
    Tombukt2 Senior Member
    13,847
    2,515
    Durham NC
    because the manufacturer said it should be used. That pretty much ends the discussion then manufacturers make the necessary oil that's needed similar to the transmission oil right It's a similar problem over there with all the motor generators and so on and so forth in the transmission so they came up with a way to mitigate whatever fears they thought or engineering prowess they had or what have you. I do know people that are running regular incorrect oil in their electric air compressor and it out lasted the car. Woops.. a lot of manufacturers do similar and a lot of people do write text asking questions and wondering why and some people just do what they want sometimes it works sometimes it doesn't.
  3. ChapmanF
    19,007
    I'm not completely sure that the magic of ND-Oil 11 is its own low conductivity. Maybe it is, I just don't know for sure.
    The windings are already made of varnish-insulated wire, of course. They are all wound up on each other, so if not insulated, they would be dead shorts. The oil is already on the outside of the insulation, where its conductivity shouldn't matter a lot.
    It seems to me they would be more concerned about the chemical compatibility of the oil with the varnish, so that it doesn't degrade the existing insulation on the windings.
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,572
    2,602
    Taylors, SC
    Like what happens in large stationary AC units, moisture combines with contaminants in oil and deteriorates the insulation in wiring as Chap stated.
    More AC compressors are killed by moisture than any other cause.
    jerrymildred likes this.
  5. jimolson
    jimolson Member
    162
    63
    Indianapolis, USA
    Thanks for all the feedback.
    Thinking about your comments reminded me that Toyota/Denso is playing the long game and knows that electric A/C compressors are going to be commonplace in future models. The early generation Priuses had 200VDC traction batteries. I've heard that more recent plug-in Priuses are 400VDC, as are early BEVs. Hyundai's fast-charging Ionic BEV is 800VDC. Presumably the compressor voltage will rise as the traction battery voltage rises.
    I can imagine that refrigerant and refrigerant oil will need to have zero conductivity at these elevated voltages, regardless of how small the shock hazard might be.
    At 800VDC even a teeny bit of residual, mildly-conductive refrigerant oil wiped across a compressor's electrical connector would constitute a shock risk. A megohm of leakage resistance is borderline lethal at 800V.
    I wonder if the auto execs and engineers who bailed on the CCS charging plug in favor of the smaller Tesla plug gave adequate consideration to the shock hazard presented by 800V connector pins after the vehicle has just exited a car wash.
  6. ChapmanF
    19,007
    You've probably noticed the responses you got were not chiefly about electric shock hazard from conductive refrigerant.
    There is published documentation from Toyota that's been cited on PriusChat before indicating that what they are trying to avoid is the failure of your A/C system with a P0AA6-611 code, requiring expensive replacement of pretty much all of the system ... and indicating the kind of astonishingly low fraction of contamination with non-ND-11 oil that can make that happen.
    There are some threads here that link to a study by some A/C outfit (distinct from Toyota) where they deliberately filled a system using the wrong oil, then tested whether they could recover from that 'mistake' by just replacing the compressor (and receiver/dryer element, presumably) but only HECAT H-1000 flushing the rest of the system. That seemed to work out ok, for a cost much lower than replacing everything.
    I'm not sure whether the refrigerant even gets into any areas where the high-voltage circuits inside the compressor are uninsulated. The windings themselves, of course, are insulated. Whether the circuit board in there is cooled directly by refrigerant, and has uninsulated connections exposed, I don't know for sure. Maybe someone here has taken one of those compressors apart and could comment.
  7. Tombukt2
    13,847
    2,515
    Durham NC
    Why do the ancillary components of the 800 volt system necessarily have to be 800 volts couldn't the compressor stay two or 300 or whatever just have some form of electronic circuit takes what it needs of the 800 volts to run the compressor the electric steering whatever else maybe high voltage might be deemed necessary?
  8. ChapmanF
    19,007
    Well, a circuit like that is called a DC/DC converter, and there's one in the car already to convert the battery voltage to 12 volts. It's good for about 1500 watts, and it takes up a bunch of space in the bottom of the inverter assembly, and needs coolant piped over it, and people get sad when it fails.
    The A/C compressor can use around 3000 watts, so you'd be asking for another DC/DC converter in the car, of about twice the size and weight of the one that's there already (and would still be there), and would need twice the amount of coolant piped over it, and be another thing to make people sad when it fails.
    Just building a compressor that can work at the battery voltage seems like it would save cost and weight and components.
  9. Tombukt2
    13,847
    2,515
    Durham NC
    Yepers it's always something.gotta make all new everything. No more parts bin cars like VW was so good at.
  10. CR94
    CR94 Senior Member
    2,826
    1,241
    Northwestern S.C.
    How about terminations of the windings? Are they embedded in insulating substance?
    Interesting that 240 VAC stationary compressors apparently aren't as fussy.
    Tombukt2 likes this.
  11. ChapmanF
    19,007
    I just haven't taken one apart enough to see where the terminations are, and where the refrigerant gets.
    CR94 likes this.
  12. rjparker
    rjparker Tu Humilde Sirviente
    11,068
    6,936
    Texas Hill Country
    Everything in normal residential and commercial AC compressors is insulated and gets covered in oil and refrigerant. Just like in an inverter driven compressor. The difference is there is no high voltage leakage current check on normal compressors so minor leakage is of no concern unlike automotive inverter driven compressors.
  13. Tombukt2
    13,847
    2,515
    Durham NC
    Yeah I work on some of this stuff in the field and the commercial and light commercial HVAC and yeah the 240 volt compressors are pretty stout they can take a pretty good beating. Now these newer DC inverter job is they're finicky is all get out You look at them the wrong way and they'll shut down on you can't take any overcharging nothing It can't pound on the gas like an AC 3450 electric motor.
