Why the XLE has less cargo volume?
Discussion in 'Gen 5 Prius Main Forum' started by TheGodX, Feb 26, 2025.
  1. TheGodX
    TheGodX New Member
    Austin
    2024 Prius
    Wo dering what's the cause of cargo floor to be higher in a regular 5th gen XLE compared to LE; its not that it has AWD traction motor or added batteries under there. The XLE and LTD loses 3.5 cu ft of space to what?
  2. Trollbait
    12,806
    The higher trims get an ABS foam cargo tray with a floor deck covering that is level with the hatch threshold. The LE doesn't, so the cargo floor is sunken. There are illustrations of the different configurations in the manual. The tray and deck cen be removed if you need the total hatch space.
  3. TheGodX
    TheGodX New Member
    Austin
    2024 Prius
    My LE also has a foam tray (see photo) and the floor covering on top. Why the higher trims have thicker ones cutting short cargo volume.
  4. Mendel Leisk
    42,264
  5. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    They really went the extra mile with the styrofoam inserts! Leaving them white was a nice touch /s Hopefully they aren’t as cheap and flimsy as they look.
    bisco and Mendel Leisk like this.
  6. Mendel Leisk
    42,264
    Everytime I see pictures of white styrofoam under the hatch floor (and nothing else...), I see RED.
    daisy555 and Pri3C like this.
  7. KMO
    KMO Senior Member
    2,026
    751
    Finland
    2023 Prius Prime
    The benefit is the flat load area when the seats are folded.
    Who knows why they decided that should be standard for higher trims outside Japan.
    In Japan the lower floor is standard across trims, and the higher floor is a (dealer?) option.
    Trollbait likes this.
  8. Trollbait
    12,806
    The others also get more usable cubbies for stashing stuff out of sight.
    In markets that get a spare tire, that also raises the rear floor up higher.
    It is ABS; same foam used in the bumpers. So it is tougher that styrofoam
    And it isn't like carbon black is an expensive additive. Toyota is looking cheap to save pennies.
    TheGodX, daisy555 and Mendel Leisk like this.
  9. bisco
    52,776
    Camry foam is black
  10. TGTGUUD
    TGTGUUD Member
    99
    76
    San Francisco
    2024 Prius
    It is EPP, expanded PP, the same material used in helmets, child car seats and some other life-saving equipments.
    KMO likes this.
  11. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    It comes in darker color too. So strange to put white in a cargo/trunk area.
  12. Hammersmith
    Hammersmith Senior Member
    2,451
    2,515
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I get that it's not the most popular opinion, but I actually like the white. Makes it easier to see what's in the different compartments and how big/deep they are. Since the area is often in shadow, a dark object in a dark container in shadow is not the most fun to deal with. And the whole area is covered with the floorboard, so it's not like I'm constantly looking at white. But this is absolutely a matter of taste, and it's clear I'm very much in the minority. ;)
    PMF and KMO like this.
  13. Mendel Leisk
    42,264
    Can't compare to those round, black things though. :)
    TheGodX likes this.
  14. daisy555
    1,729
    716
    CT
    Actually I never thought about it that way. Good point. I was thinking about greasy hand marks from a future AAA tire repair person. : )
  15. Jotunn
    Jotunn New Member
    17
    High Point, NC
    2024 Prius Prime
    XSE Premium
    Has anyone with the higher trim converted to the lower trim for the extra cargo space? Vertical height clearance has been an issue for me with some of the gigantic stuff my daughters try to put back there, and it hits the cargo cover privacy thing.
