Why won't my iPad charge in my PiP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 9G-man, Sep 22, 2013.
  1. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Why won't the iPad charge when plugged into the USB port in the center console ?
    My iPhone charges and auto plays but the iPad will only auto play.
  2. Bill Collins
    Bill Collins Junior Member
    East rutherford N.J.
    2013 Prius Plug-in
    possible the PiP does not supply enough watts of power..the charger for the iPod,iPhone and iPad are not compatible
  3. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    Correct, my Nook Color charger is 1.2 amps at 5v DC whereas my smartphone charger is only 800 miliamps output.
    The power requirements for an iPad is probably even higher than 1.2 amps.
    You might need to get a suitable adapter that plugs into the power outlet. Though finding a USB adapter that plugs into the power outlet and puts out that kind of current might be harder.
    SCH-I535
  4. xliderider
    8,056
    3,223
    Honolulu, HI
  5. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    I've been using this very small InCase adapter in the center console with my iPad for many trips. Streaming over Bluetooth while charging from this adapter.
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
  7. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Your iPad might charge when it is turned off but not when it is in use. That is what happens if you plug an iPad into an iPhone charge adapter (5W) instead of into the iPad-specific adapter (10W).
    Ken Blake likes this.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Even though the iPad does not light up the 'charging' light, my experience is that a dribble of energy makes it into the iPad battery.
