Why Won't My Prius Go Into (Drive)
Discussion in 'Gen 2 Prius Technical Discussion' started by jensendump, Apr 26, 2017.
  1. jensendump
    jensendump New Member
    Mesa Arizona
    I had 2 battery cells go bad on my '05 Prius. I replace them with a friend and seems everything should be in working order. But now I can't get my car to go into drive. Only Park and Neutral are options.
    I tried clearing the codes, but it hasn't seem to do anything other than causing the dash the flash.
    Here are the codes that came up on my code reader:
    $7E8
    $7EB
    $7EA
    My research states the following definitions:
    7E8 for ECM (engine control module)
    7EB for Traction Battery
    7EA for HVECU (Hybrid contol module)
    Any ideas? I'm at a total loss. My wits end.
  2. JC91006
    16,937
    8,647
    Lock down the orange interlock switch. Press down to lock it in place. Then the car will start
    SM-N900P ?
  3. jensendump
    Mesa Arizona
    We thought that we had it locked down in place. But we can doublecheck.
  4. JC91006
    16,937
    8,647
    The lever will pivet up and then you press down to lock it into place
    SM-N900P ?
  5. JC91006
    16,937
    8,647
    If it's not the interlock switch, then it's a bad 12v battery
    SM-N900P ?
  6. jensendump
    Mesa Arizona
    Yes. It's locked into place. I slid it in. Then locked the lever down 3x
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Take the cover off the battery and with orange interlock in measure across battery side connectors at relay and see what battery voltage is.
    And the codes you listed are gibberish. Those are not correct hybrid codes, what are u using for
    OBD?
    Blows my mind that people go through the trouble of installing modules and never even check if the battery has correct output before installing it.
  8. jensendump
    Mesa Arizona
    I figured it out! A couple of our bolts on our hybrid battery cells were not screwed in all the way tight. Because we were working as a team one of us were getting things tight my hand while the other was going through and tightening more they socket wrench. Four of them were not tight enough. Simply tightening them solve every problem. The car is driving and performing well. I'm so happy! Thank you for your help.
    valde3 likes this.
  9. JC91006
    16,937
    8,647
    Tightening nuts on the battery should never be a team effort. I hope 1 person checked all the terminal nuts were tightened to 47 inch pounds. Loose nuts can cause all kinds of problems, even potential fires when they heat up
    SM-N900P ?
    valde3 and edthefox5 like this.
  10. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Yes team effort can be disasterous. One person thinks the other got it....
    2 people and still no one checked it's output before buttoning it up.
