Why would one goes with a "regular" Prius and not a Prime?
Discussion in 'Gen 4 Prius Main Forum' started by toolbox2014, Mar 5, 2020.
  1. toolbox2014
    toolbox2014 Junior Member
    36
    central OC, CA
    For 2020, LE is the only trim level that has a spare tire. Is it a cost reason the other trim levels does not have a spare tire?
    alanclarkeau likes this.
    52,889
    Now you’re asking us to guess
    Prodigyplace likes this.
  3. Prodigyplace
    12,720
    11,852
    Central Virginia
    Not likely. I got the lowest 2017 trim level with the spare and rear wiper.
  4. blane
    blane Carmudgeon
    98
    56
    NJ Suburb of NYC
    2019 Prius
    I wouldn't consider getting the Prime unless I were able to charge it at home.
    Range Anxiety!
  5. Mendel Leisk
    42,369
    I don't understand. (n)
    douglasjre and Raytheeagle like this.
  6. blane
    blane Carmudgeon
    98
    56
    NJ Suburb of NYC
    2019 Prius
    I replied to the OP's question "Why would one goes with a "regular" Prius and not a Prime?"
  7. Mendel Leisk
    42,369
    With a pure electric vehicle, sure you can have range anxiety. But with a Plug-In, c'mon. ;)
  8. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Most likely to maximize fuel efficiency by not having extra weight. Is there a flat repair kit in lieu of the spare tire back there?
  9. Mendel Leisk
    42,369
    Or that the battery occupies the space directly above the spare tire depression?
  10. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    You'd be surprised how adamant some Prime owners are about never using a drop of gas! They hyperventilate at the thought of burning gas!
  11. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Not me. I run twice as much miles on gas than on electic for my first PRIME 40K miles. For my second PRIME now I plan to do the same.
  12. Mendel Leisk
    42,369
    Hey, you're still burning mpg doughnuts 'round the regular Prius, and sleep at night. (y)
    I think makes for a happier engine too.
  13. bisco
    52,889
    He probably means the fact that it only goes 600 miles on a tank
  14. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    I would have went with the Prime but I was needing a car in 2016 instead of 2017. Also unfortunately for the East coast peeps like in Florida, they are over 30k at a mimimum unless they are flooded or totalled or something like that. I would definitely say for 2 or 3k more out of pocket, I would have surely went with the prime instead of the regular prius. If you are in an area like me and would have paid 10k more, its simply not worth it. I believe right now there are maybe 2 or so available to me within the state of Florida brand new and I am sure they will not be willing to wheel and deal. Also with the prime, I am pretty sure if you go a long downhill, you can put all that EV energy back in the main prime battery pack as well. Not that I go down much hills in Florida, but I saw this on the prime forum I believe.
  15. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Why would a HVAC Heat Pump be more complex. Should be similar - there is less coolant running around for a start - it's only cooling the engine.
  16. alanclarkeau
    7,045
    7,593
    Problem is - triple the battery range, you need to triple the battery volume and weight - oh, and many more $$$$. TOYOTA have come up with a reasonable compromise.
    They'll join the BEV Rat Race when it's fiscally viable to do so.
    Hopefully, with spare tyres. Full Size.
    jerrymildred likes this.
  17. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Not this owner;).
    I'm getting triple the mpg of the 2010 gen3 Prius it replaced:).
    And I get free electrons at work. What a deal(y).
    robsnyder20, bisco and alanclarkeau like this.
  18. Tideland Prius
    16,683
    No. If the battery is “drained” and you’re in HV mode, it’ll generally stay in the HV portion. However, you do have that excess capacity so going down steep hills or long hills will charge up the battery into the EV section.
    According to @john1701a ’s videos, it uses 8-14% of true SOC in the hybrid section of the battery.
    The EV portion is 83-14%
    Weight savings to keep it within the EPA weight range (weight class) for mpg advertisement.
  19. fuzzy1
    10,722
    The Prime has not just reduced cargo volume, but also reduced cargo weight rating, by about 155 pounds.
    Because my household tends to use the full rating of a regular Prius, this reduced load weight rating is very significant.
    All that ICE-driven battery charging does nothing to save fuel. Thus, while that extra hardware and complexity is put to some use, it brings essentially no benefit, thus is effectively wasted.
    To get an true energy efficiency benefit, it must be plugged in. Or be used on a route with long downhills where it can recover energy of descent that a regular Prius must throw away and waste.
    Efficiency also. The higher MPG trims exclude the spare tire to save weight too.
    Absent plugging in, some CA drivers select a Prime in order to get HOV lane stickers, for which the regular Prius is not eligible.
  20. FuelMiser
    1,349
    929
    Monument, CO
    Makes sense because the battery is heavier. Total gross weight is the same, but more battery means less cargo.
