Why would one goes with a "regular" Prius and not a Prime?
Discussion in 'Gen 4 Prius Main Forum' started by toolbox2014, Mar 5, 2020.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    "Your miles" charge up nothing.
    If you don't plug it in, the gas engine provides 100% of the energy to move the car.
    I don't know if it will be more or less efficient than a conventional hybrid with a smaller battery. Other design considerations might have a bigger impact than just the battery size.
    A bigger battery is NOT automatically better.
    52,888
    i think it gets a mile or two more mpg's without plugging in
    jerrymildred likes this.
  3. Mendel Leisk
    42,369
    John Kelly, in his Prime battery deep dive, finds disassembly of one of the lithium ion packs to be very impractical. The base level Prius and AWD models still have nickel metal hydride pack, more suitable for hybrid battery "tinkerers".
    kithmo and alanclarkeau like this.
    52,888
    I wonder if the lift back lion battery is as cumbersome
  5. Itmaybejj
    Itmaybejj New Member
    2019 Prius
    The trim options are also different. The base 2019 prime didn't have blind spot monitoring, and that was one of my must-haves.
    And with the huge range of the nonprime, I only need to stop by a gas station once every few months, which I much prefer to fiddling with charging plugs every day. If I had a 20 mile commute I would have gone for the prime, but mine is only a few miles.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Correct ... mostly. EPA combined on the Prime is 55/53/54 mpg city/hwy/combined. On the hatchback, it's 54/50/52 mpg ... unless it's an L Eco. Then it's 58/53/56 mpg.
    Most times on the highway, I get 60 or better and around town it's closer to 70 mpg in hybrid mode. On our long road trip last May, we averaged 56.6 with the car packed to the gills and facing some extreme wind all the way across Nebraska and Iowa.
  7. Chris Wolfgram
    Chris Wolfgram Active Member
    425
    169
    Sacramento CA
    2019 Prius
    So Id still have to fill it every day...
  8. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Wow, You drive 600 miles every day??? :eek:
  9. Rmay635703
    Rmay635703 Senior Member
    2,704
    1,730
    Somewhere in Wisconsin
    2013 Chevy Volt
    213,000 miles a year, must work remotely while he drives his car
  10. bisco
    52,888
    Needs one of the 2,000 mile vehicles
  11. fuzzy1
    10,722
    ... or is a courier, such that the driving IS his work.
  12. Tideland Prius
    16,683
    Didn’t he say he was an Uber driver? Does a tank to a tank and a half a day?
  13. Salamander_King
    11,024
    8,980
    New England
    I don't remember. But 600 miles drive is a full time work for sure. I do 600+ miles drives in summer time, but only in weekend trip, and happens only a few times a year.
    Tideland Prius likes this.
  14. Tideland Prius
    16,683
    600 miles is very rare for me, even on road trips. I usually top out at 500 miles due to terrain, traffic volume and lower speed limits.
  15. jerrymildred
    11,517
    14,171
    Tampa, FL
    I only went over 600 miles on a road trip once (604). But I was getting 59 mpg on that tank when I calculated it.
    alanclarkeau likes this.
  16. Mendel Leisk
    42,369
    We're lucky to do 500 kms, per month. :oops:
    alanclarkeau, Raytheeagle and fuzzy1 like this.
  17. ice9
    ice9 Active Member
    581
    346
    norfolk va
    2018 Prius
    Yes. The large battery makes it practically impossible to use it as a camper.
    jerrymildred and alanclarkeau like this.
  18. Chris Wolfgram
    425
    169
    Sacramento CA
    2019 Prius
    Well I typically drive closer to 300-400 miles a day, but i like to start with a full tank though, so I don't have to stop if I'm busy. ... But then from Saturday at about noon, until Sunday night between 6pm and 10pm, I often drive close to a thousand miles.
    I've started with a full tank and had to fill up twice before Sunday night !
  19. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Show off:p.
    Give the garage queen to one of the higher mileage drivers so she can be put through the paces(y).
  20. Mendel Leisk
    42,369
    We do get it warmed up, every so often. But yeah, could be driving a Hummer and wouldn't break the bank.
    alanclarkeau and Raytheeagle like this.
