Why would you Mod a Prius?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by WilMent, Feb 27, 2013.
  1. macman408
    macman408 Electron Guidance Counselor
    1,179
    367
    I'm pretty sure that at the meet that I went to, I was about the only one that hadn't modded SOMETHING. And I'm pretty sure F8L chewed me out for it, too. :eek:
    Unless you count pipe insulation in the grill as a mod. :)
    F8L and WilMent like this.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Considering we're still getting over 40mpg
    F8L, mnml and WilMent like this.
  3. WilMent
    WilMent diacritic
    369
    149
    New York
    Speaking of mpg hit, my first tank after my wheel and tire change I took a 8 mpg hit, that totally freaked me out. Luckily, the tires has since wore in and I inflated them 42F/40R, plus I am more used to driving on a wider tires now, it is only a 3-4 mpg hit now:)
    mnml likes this.
  4. WilMent
    WilMent diacritic
    369
    149
    New York
    Agreed, That's where I set the warning bar to something is not right on a mod or tell myself to lift up that lead foot a little.
  5. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :DWhy? I believe all cars need tweaking and personalizing. I prefer appearance mods. I like the "FAST, sitting still look". Never had a car that couldn't exceed the speed limit from the factory. Nice wheels are always a must upgrade for me. Personalized plate and tint are other favorites.
    WilMent likes this.
  6. mnml
    mnml Ain't nobody got time for that.
    377
    161
    Ladera Ranch, CA
    Exactly. My main concern was how much of an EV hit I would experience. Luckily, I'm still able to make my 10.5 mile trip to work on all EV so I'm a happy camper.
  7. mnml
    377
    161
    Ladera Ranch, CA
    Last night I forgot to plug in my PIP. :confused: So this morning, I decided to take the freeway on all HV in power mode to see what type of MPG I would get. To my surprise, my 11 mile trip yield 49 MPG even though I was doing about 72 mph on the freeway. No regrets getting the 17" wheel upgrade.
    sfv41901 likes this.
  8. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    Almost every car I've owned has been an MR2 or a Supra, so I've definitely had my share of the "fast sitting still look", right from the factory.
    I'll probably do wheels at some point, but I will stick with the 15" size. 17s and 18s may look nice, but the ride quality REALLY suffers. Whatever wheels I get will be the same weight (or lighter) than OE. That's expensive to do with larger diameter wheels. Larger diameter wheels also mount heavier tires and move the weight farther from the center of rotational mass, giving a performance hit to both acceleration and braking.
    I like personalized plates (my 93 MR2 Turbo had "DEUC CP" on it) but Oregon doesn't allow personalization of their Veteran's plates. I have tinted windows, but those actually add efficiency to the car, since they reduce the amount of air conditioning needed in hot, sunny weather.
    I'm not telling anyone what to do with their car, just stating why I've done (or won't do) to my car.
  9. WilMent
    WilMent diacritic
    369
    149
    New York
    My 17s with Primacy MXM4 rides smoother and quieter than my stock Goodyear, and the added handling was well worth it. I have not pushed the car hard enough to get the springs and sway bar for performance, but I will do the springs for the wheel gap :D I'm not a racer, and definitely don't intend to race in a Prius, however, I do like to have a little fun now and then, and the added sense of safety and confidence is worth every penny.
  10. WilMent
    WilMent diacritic
    369
    149
    New York
    It most definitely counts, not all mods needs to be nice and shiny. After reading all the other threads about them, I am curious enough to take on that experiment. Waiting on my ecoroute hd so I can monitor temps.
  11. Ken Blake
    351
    180
    Portland, Oregon
    If you increased your unsprung weight (new wheels and tires weigh more than old wheels and tires) you probably HURT the ability of the car's suspension to deal with bumps/potholes. Any handling gain you perceive is probably due to running a tire that trades lower rolling resistance for faster wear/increased grip. That could be done with the stock 15" wheels and a different tire compound.
    Everything is a tradeoff. With the 18x9.5" rear wheels, clad in 275/35/ZR18 and front wheels 18x8.5" clad in 245/40ZR18 BFG KDW2 tires my Supra would pull 1.25 instantaneous lateral Gs on the track, and over 1.0 Gs of acceleration, but the rear tires needed to be replaced every 10k miles, and the fronts every 20k miles. They were also pretty noisy, and the ride was harsh, compared to the stock 17" wheels and tires. The wheels WERE 8 pounds lighter per wheel than the stock ones, so braking and acceleration was actually a little better than with the stock setup.
  12. WilMent
    WilMent diacritic
    369
    149
    New York
    (y) Yup in the process of replacing suspension components. I'm not too into the whole tuning for performance aspects. Most of my mods are for looks and comfort, as long as I don't hurt the vehicle like you mentioned. Added performance would be icing to the cake.
    Certainly I can never have the best of everything, that is why I didn't go with a LRR tire for the 1-3 mpg gain (as reported by other PC members) it rains so much here, I would rather have good wet traction over mpg any day.
    My total tire/wheel weight change was +3.5 lbs. I can live with that, just not the wheel gap:p
  13. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Sounds about right- when I had the 2012 Prius Five (not PIP) with the 17" wheels- my lifetime mpg was 50.5 for the six months I had it.
    One day last month I got ICE'd out of my regular charging spot, so I had to drive home in regular HV mode- my PIP has the 15" wheels, at the end of my 28mi commute I got 54mpg w/no EV charge from the beginning of the trip.
    mnml likes this.
  14. Joe-G
    Joe-G Member
    243
    99
    Ft. Lauderdale, FL
    Same here.
  15. walter Lee
    1,126
    376
    Maryland
    Hypermiler/Fuel efficiency Mod:
    1) ScangaugeII (programmed for Soc,Amp,Flv,RPM,GPH,AVG)
    2) LLR tires, e.g. Michelin Energy Savers A/S - reduce rolling resistance
    3) shark fin radio antenna - decrease aerodynamic drag
    4) Rear wheel skirts - decrease aerodynamic drag
    5) Alloyed wheels - reduce weight
    6) Window Tinting - lower AC load, ceramic is the best, summer mod
    7) Grill blocking - increase thermal efficiency, winter mod
    8) engine block heater - assist thermal efficiency - winter mod
    9) extra hood insulation - increase thermal efficiency, winter mod
    OR
    Carbon fiber engine hood with adjustable hood insulation - reduce weight, increase thermal efficiency
    10) upgrade HV battery and computer software of the Prius.
    All Weather/interior Mod:
    1) WeatherTech rubber floor mats and rear cargo mats
    2) leather seats or Leather seat covers
    3) HiD headlights (since you have a two and not a type four)
    4) fog lights (since you have a two and not a type four)
    5) a trash can - important if you have messy passengers in the rear
    6) additional LED glove compartment lights
    7) additional LED lights for center console
    8) additional LED lights for door handle controls.
    9) rear cargo area netting.
    10) extended rubber/plastic film to protect the
    bottom of the sill to the driver's door
    11) add a 120VAC outlet (circuit breaker protected 400W peak/300W sustained max when ICE is running)
    12) this is for WilMent since he is a smoker front window vents & smoking tray - the Prius doesn't have a smoking tray so a smoker needs to add one - to vent tobacco smoke while preventing the rain from getting inside the cabin when driving at high speed, side window vents can be used )
    SuperHighway Mod:
    1) switch to 17 inch hi speed performance tire - better hi speed road handling here
    2) front grill deflector/bra - protect paint from road debris.
    3) portable GPS unit with lifetime maps - so you dont get lost
    4) radar/laser scanner if u like to speed.
    5) rear camera
    Wunderlust - Sportsman Mod:
    Roof kayak-ski rack
    Rear bicycle rack
    Towing ball - Bob Wilson did this...
    Dog/Pet Cage w/ramp that separate to rear cargo area of the Prius V
    Doggy-Cat seat/harness
    Baby/Toddler/child seat/harness
    Accessories nice to have
    1) a hi quality tire pressure gauge
    2) a hi quality 12VDC tire air compressor
    3) 80W max 12VDC power adapter to 120VAC inverter - to run stuff
    while you are on the run
    4) 15 amp fuses when you blow your 12VDC power adapter fuse
    5) a portable 12VDC jump starter - the Prius battery cannot provide
    a jump start - this is a good samaritan hardware
    6) an extendable up to three feet - snow brush /ice scraper
    7) can of fix a flat, a set 3 flares
    8) bluetooth enabled phone
    9) windshield heat shield (for the summer)
    10) Iphone/Ipad/MP3 input for the stereo system
    11) spare battery for your smartkey (battery last about 3 years)
    WilMent and F8L like this.
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    You forgot about the shorter and stiffer sidewall and higher speed rating (construction) of the 17s. You're just not going to get a 15" tire to handle as well as a good 17" tire on the Prius without suffering mpg penalties. Such that the effort isn't worth it. You're better off having a better looking wheel in a 17" size than trying to stick with a 15" if handling is your thing.
    Unfortunately, all of the fuel efficient 15" tires tend to roll the sidewall much easier than a LRR 17" tire. A high performance 15" tire may roll less but you will lose about the same amount of fuel efficiency as a good LRR 17" tire and you'll still look bad. :)
    WilMent likes this.
  17. WilMent
    WilMent diacritic
    369
    149
    New York
    :ROFLMAO:Nice to have but I never smoke in any of my mistresses.
    Laser detector: will stay on my weekend roadster for now:) Until I sell it, I don't drive it much anymore and the expenses for 3 cars is killing me.
    I love how you manage to squeeze aesthetic mods into the FE section, though I can see how it could have help .00001mpg gain :ROFLMAO: I'll use that to justify the budget with the wife.
    BTW the sharkfin ant. I've read about reception lost, did that happen to you? I use my ipod most of the time, rarely even touch the Sat. Radio but the AM/FM radio is nice to have (Traffic jam/major accidents/disaster) I think the stock antenna gives it a nerdy :cool: look I like it.
  18. WilMent
    WilMent diacritic
    369
    149
    New York
    :ROFLMAO: F8L I can see you won't be able to stay 15s for too long, or have you switch them back already?
    Everyone uses a different equation to balance their mpg, performance, looks, and vehicle longevity. I was struggling in the beginning to stick with the stock 15s black alloy with center cap. I kept thinking, "It's a Prius, grow-up!, you bought this car for mpg!" Then I found enough " benefits" to the 17x7 setup to justify my need for good looks:D And for once, I feel that my decision was without draw backs (handling/mpg/looks) all in one package.
  19. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    ohh yeah. I have quite the reputation around here for swapping wheels and tires. :p
    I had my 2012 Three for less than a year and I had tried 5 different sets of wheels and something like 7 sets of tires. I'm too broke to mess with the PIP. Although I really miss my old CT200h wheels after seeing Sean's car.
  20. WilMent
    WilMent diacritic
    369
    149
    New York
    Drools... wow (at the wheels:D )
    +1 Lexus
    -10 PPP
    I saw some pics of the concept/development 2015 Prii, it seems they are moving in the directions of the CT200h, I can't wait for the 2014 auto show.
    F8L likes this.
