Why would you Mod a Prius?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by WilMent, Feb 27, 2013.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Me either! Hopefully they fix the rattles too! :)
    WilMent likes this.
  2. bwilson4web
    16,507
    Smile and say, "Well if you don't want my Prius business, can you recommend someone who wants a Prius customer?"
    You've gone to the wrong store so don't worry about it. In the future screen them with a phone call but otherwise, don't worry.
    Jayw13702 and WilMent like this.
  3. WilMent
    WilMent diacritic
    369
    149
    New York
    Tell me about it, I started out on the wrong foot. The first couple of upholstery place I called were specialized in hot rods and muscle cars :ROFLMAO: They probably thought I was joking at first. Then, the import tuner places were like, "Are you serious? Where's your weekend car!"
    bwilson4web likes this.
  4. bwilson4web
    16,507
    Something to consider, many of my Prius mods have more to do with expanding the safety (a sounding backup LED, combination bluetooth, GPS, backup camera rear view mirror,) and over-sized front tires for handling,) utility (1kW inverter, tow bar,) and fuel efficiency (using Type WS instead of Type T-IV and all-the-time overdrive from over-sized front tires) and not performance or creature comforts. However, I do enjoy my iPad/iPhone audio instead of the radio and CD player.
  5. WilMent
    WilMent diacritic
    369
    149
    New York
    Never thought about that on a FWD Car, I've done that on my RWD but the uneven tire wear was pretty bad. And to rotate tires properly means I still needed 2 full sets. The tire warranty is also voided or 1/4 of the max miles. How's the ride quality with over sized F. tires on the Prius?
  6. bwilson4web
    16,507
    I'm using oversized front tires on the NHW11 which improved handing and also gave me about a 6% overdrive capability. But this also means the speedometer is off by 6% (use a GPS speedometer instead) and MPG calculations work only for the pump measured values. The indicated values show 'low' when in fact they are higher.
    Understand the NHW11 handing is stability neutral. The larger diameter tires let the car 'track true.' I don't have that problem with the ZVW30.
  7. WilMent
    WilMent diacritic
    369
    149
    New York
    Poked around a little, took me some time but I'm beginning to understand the concept for the NHW11. Very interesting read. Glad the Gen3 doesn't have that same problem. :confused: My head hurts...
  8. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    If "handling was my thing" I would have bought an FRS, not a Prius. :eek:
    Those shorter, stiffer sidewalls are what kill ride quality, unless the roads near you are billiard table smooth. They also increase the tendency of the car to tramline. I ran R compound tires on the stock 15" MR2 turbo wheels, and the car far outcornered the 17" wheels shod in Z rated rubber...Granted they wore out much faster too!
  9. WilMent
    WilMent diacritic
    369
    149
    New York
    +1 FRS saw it drifting around on the track. Miata killer IMO - the roof.
    With my limit track skills, I'm still having a load of fun driving the Prius, maybe it is the "underdog" factor.
    I will take my Prius to the track after I install springs and sway bars. If I beat any other newbies' track time with their "sports" cars I might crash from laughing:ROFLMAO:
    This will give me an idea if I would ever need any more performance parts for the Prius. I'm guessing no, I believe my limited skills and The Prii's lack of power will be apparent on the track. But I still want to try before I concentrate on aesthetic mods:) (Besides, it'll be fun to see the other driver's faces when I show up)
    Ken Blake likes this.
  10. bwilson4web
    16,507
    "Track" is a somewhat ambiguous term:
    • max speed? -> oversized tires
    • max acceleration? -> undersized tires and weight loss
    • max turn Gs? -> balanced but suspension tweaked
    Can you give a Google Map address where I might take a peek?
  11. WilMent
    WilMent diacritic
    369
    149
    New York
    Pacific raceways, Kent WA
    On open track days, they allow stock cars to have a go, as long as you have the proper safety equipment, and sign a wavier or buy on-track insurance. Nothing as serious as you mentioned. It's still a Prius:) I just wanted a close course where I can speed without getting a ticket or risking the safety of others.
  12. bwilson4web
    16,507
    Two courses:
    • Oversize tires on the front for the big course - you have enough straights to reach the 105 (?) mph indicated limit. So oversized tires can add 6% so you can beat all of the other Prius. Use a GPS speedometer. <GRINS>
    • Donuts for the front and back for the Grand Prix course. - or the smallest wheels and sticky tires you can get. <grins> Weight loss, take out everything that can come out including passenger seat and knock yourself out. You're not really trying if the traction control light is not lit at least once every lap.
    • Perhaps a divide-by-two interface for the wheel encoders? I would only recommend if you are prepared to lose the car. Get a 'beater' Prius.
    • If you have a 'beater' Prius, perhaps an electric boost . . . just to make it a little more . . . interesting.
    • Quality, straight gas, 89 or better - the engine will tune for the octane but needs to be track tested.
    Have fun!
    Of course my type of mods are a 2kW inverter with a microwave, lights and TV in the back. A little tent to keep the rain out and enjoy the show. <grins>
  13. Bill Norton
    Bill Norton Senior Member
    2,233
    748
    MONW, Ks.
    2019 Prius
    L Eco
    I plan on Autocrossing my Prius a soon as I get my sticky 17"s, TRD springs and rear sway bar, strut brace installed.
    I plan on trying the car in "Recertification mode" to disable VCS and Traction Control. I'm not clear yet if it also disables ABS. It's not for every day use. (No cruise, display is limited and a warning light is on).
    I also plan on running in "B" to keep the engine from shutting off when it thinks that's a good idea.
    So,, does this sound like a good plan of attack, you Motorheads?
    Track days sound like fun too!! I'll have to figure out when I can get my Prius out on the local race course !!
  14. WilMent
    WilMent diacritic
    369
    149
    New York
    The owner of the track thought it was a fun idea, he bet me 20 bucks I won't break 100 mph on the straight. My Prius is my commute car so I won't do anything that hardcore. Plus the ECU is a little beyond me to crack.
  15. Bill Norton
    2,233
    748
    MONW, Ks.
    2019 Prius
    L Eco
    WilM,
    Think about borrowing a Nitrous Oxide tank ( for less than $20, hopefully) and plumb in a simple hardware store needle valve and aquarium tubing to the air inlet.
    If the straight is long enough for you to slowly feed in some Nitrous,,, you, my friend, shall be eating free that evening !!!!
    WilMent likes this.
  16. WilMent
    WilMent diacritic
    369
    149
    New York
    Nuts on the NOZ. I should be able to put off a near 60 mph turn into the straight of a little less than 1/4 mile. We'll see:)
    I just heard about the guys over at LS1 doing a conversion on the Prius, they are having a bunch of problems overhauling it to fit the V8. I would love to see that Sleeper when it is done.
  17. wotcher
    wotcher Member
    403
    97
    16
    LA
    i recently returned from a trip the bay area. In San Francisco and palo alto, I noticed that there was 1 prius for every 8 cars. Sometimes, at the intersection, you would be surrounded by prii. So, I mod to stand out and give your car some personality, handling, and stability.
  18. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    One car in 1400 is a Prius in MS, I stand out just fine, stock.
    I do know one other Prius owner in MS.
  19. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    I didn't follow this whole thread but the OP's statement to why... as I thought it was silly initially as well.
    For me, it's for aesthetics mainly and and if some gains are loses come from, it's fun to debate about them and make a personal decision.
    If you consider most buyers of performance cars, they do not posses anywhere close to the ability to take those cars to the limit nor can on city streets. So why do they buy these cars? aesthetics! but that's subjective too..
  20. Ajourney101
    Ajourney101 Member
    127
    88
    Seattle
    sfv41901 and Burna J like this.
