Wi-Fi and microwave oven question
Discussion in 'Fred's House of Pancakes' started by hkmb, Oct 12, 2017.
  1. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    We have cordless phones.....
    A fish tank, I suspect, would mess with the head (and eventually the dryness) of the cat more than it would mess with an 802.11 signal.
    RCO and Prodigyplace like this.
  2. Prodigyplace
    12,709
    11,847
    Central Virginia
    Some cordless phones are 900 MHz so they should not interfere. The 2.4 GHz ones could be an issue. I would expect the user manual to list the specifications.
    pilotgrrl likes this.
  3. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Just to confuse the issue a bit more...
    Panasonic microwaves use an inverter power supply. Noise from the power supply may be backfeeding the 120VAC line. The interference may have nothing to do with the intended RF signal - it may be the power supply generating the noise.
    Same deal with cell phone towers - their inverter power supplies can trash the local power grid with RF noise that is not at any of the cell frequencies.
    Prodigyplace likes this.
  4. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    Some Panasonic microwaves use an inverter. It'll say if it does. The newer, smaller ones (like the one I have now) don't.
  5. Prodigyplace
    12,709
    11,847
    Central Virginia
    Discussing edge cases could go on ad infinitum and would mask the good advice in this thread, IMHO
    Perhaps we should have put a YMMV disclaimer with the advice.
    RCO and pilotgrrl like this.
  6. Trollbait
    12,799
    In what way will aquarium mess with the signal? From the equipment or the mass of water?
  7. pilotgrrl
    891
    1,797
    Chicagoan in TX
    The water interferes with the signal.
    hkmb likes this.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    By converting the signal energy into heat energy?
  9. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    No, the goldfish use all your bandwidth watching Spongebob and Octonauts on YouTube.
    RCO, pilotgrrl and Prodigyplace like this.
  10. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    Ahha! I was almost right.
    @Nifle: I'd be more concerned if the fish had little microwave ovens in their miniature cave kitchens (you know, the little caves you can buy at pet stores?). ;-D – Randolf Richardson May 28 '11 at 21:44
    I know water absorbs UV light pretty effectively. But that's at 800 terahertz.
    Prodigyplace and pilotgrrl like this.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    So I was correct at #28, then?
  12. Trollbait
    12,799
    Water also stops neutrons and other particles effectively. Which is why spent fuel rods go into a pool when first removed from a reactor, and why water tanks are used for shielding some scientific equipment.
