Wierd engine noise when it starts...
Discussion in 'Newbie Forum' started by MansTer420, Apr 14, 2013.
  1. MansTer420
    MansTer420 Junior Member
    119
    Is it normal?
    As soon as I push the start button, few seconds later engine makes some wierd noise for about 10 seconds and silence comes...that when I usually start drive away.
    Is it normal?
  2. frodoz737
    frodoz737 Top Wrench
    4,795
    2,560
    33
    Can you be more specific about "weird noise" please?
  3. MansTer420
    119
    the noise is not rattle sound for sure.
    it sounds like the sound other car makes when you turn on a/c..
  4. MansTer420
    119
    addition;
    If I press start button, its very quiet and about 4 sec later, the engine makes this a/c kinda sound and goes quiet again after 10 sec.
    I check hybrid monitor while it makes the noise and yes.
    engine is in operation while there is noise.
  5. Zormico
    Zormico Junior Member
    31
    Sioux Falls SD! (yea...)
    sounds like the engine is just turning on, mine takes about 4 seconds before the engine turns on after I start the vehicle, so going from no rev to idle.
    thats only thing I can think of from the discription you saying, and if that is the case, its normal because the engine needs to warm up to optimal running temp.
  6. MansTer420
    119
    yeah I think thats what it is...
    i searched rattling noise and it sounds totally different from mine so I know its not it.
  7. Zormico
    31
    Grats on the new prius btw, just got mine last week.
    Have not gotten alot of time to joyride it but aiming on crusing around a couple hours tomorrow to see what kind of milage I can crank out of it (got 62.5mpg today joyriding it today for only 30 minutes).
