Wife filling up at fuel stop.
Discussion in 'Prius v Technical Discussion' started by schmuly, Jun 2, 2014.
  1. El Dobro
    El Dobro A Member
    7,087
    3,265
    VW blames misfueling as the problem.
    Official list of HPFP Failures - TDIClub Forums
  2. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)My early 1980 VW Rabbit diesel would emit a lot of black exhaust under hard acceleration. Our 1999 & 2006 VW NewBeetle diesels didn't. Many of the later diesel pickups are loud and obnoxious.
  3. Breadman03
    Breadman03 Junior Member
    24
    White Haven, PA
    Most recent diesel pickups are so quiet from the factory that you would be hard pressed to tell they were diesel by just listening. It's the aftermarket exhausts and programmers making them scream like banshees.
    Not a Dalek
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Absolutely. But because people have always mixed petrol into diesel they carry on doing so, despite the manual saying not to. Such is life.
  5. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    They blame everything other than design in an effort to avoid warranty costs. Bosch (they supply most of the diesel injection systems on the road today, including all the 3/4 and 1 ton pickup market) seems to be having issues with their new pumps and the Ford 6.7L also had similar problems to the VW with the pump randomly going south and sending metal throughout the fuel system. More than likely it was a high sensitivity to water contamination not gasoline causing the issue though.
    This is true stock, most of the sound and smoke come when the converter/DPF are removed and poor programming gets installed. My truck is fully programmed and there is no smoke at all even when putting down over 500HP on my race tune.
    #25 MTL_hihy, Sep 7, 2014
    GrumpyCabbie likes this.
