Will 50 psi tire cause any problems with my car?
Discussion in 'Gen 4 Prius Main Forum' started by rlecastro7, Jul 7, 2018.
  1. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    You are, of course correct, but that's all behind the curtain. For the average owner and to summarize the functionality, the differential pressure turns on the light. That's the way Toyota TPMS works. Of course it needs the numbers to do the calculation. Thanks for supplying the detail.
    RCO and Merkey like this.
  2. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    I read a blog by Tony Schaeffer. Is that the same Tony, the founder of this website? He is in favor of higher tire pressure for a Prius. and gives all the pros & cons. He puts up a convincing argument.
    So my next dumb question is, what type and brand of tire gauge do you prefer? My new digital gauge shows the tires as being 3 psi lower than my new Milton pencil-style gauge. I've used the Milton gauges for 40 yrsrs.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    The pressure listed on the side wall is "Maximum SAFE inflation pressure".
    Anything over that (cold) is NOT SAFE.
    This is not a difficult concept.
    RCO and Starship16 like this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Thanks - that's where I read it - Tony says "Some have gone as high as 50/48 and continued to report even better overall mileage"
    The article:
    Check Your Tires’ Pressure » What Drives Us
    Starship16 likes this.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I find good quality dial type gauges seem to be the most accurate.
    I have one of these: https://www.google.co.uk/aclk?sa=l&ai=DChcSEwjx27zE7pHcAhUNOhsKHdJHB4QYABAJGgJ3bA&sig=AOD64_0RCRSQTZQPlJdpkiiZm1M6tHSrtQ&ctype=5&q=&ved=0ahUKEwi-urjE7pHcAhXPbVAKHY5iDS0Qwg8IRw&adurl=
  6. Starship16
    1,348
    1,455
    Beach Christmas
    Correction. It was Danny Cooper who started Priuschat. Great website.
    Now everybody go check your tire pressure. ;) (I'm not touching mine. 199 mpg is good enough.)
    #46 Starship16, Jul 9, 2018
    RCO and alanclarkeau like this.
  7. ChapmanF
    19,060
    This extraordinary claim would require extraordinary evidence, not supplied here that I can see. The TPMS has alarm thresholds in gauge pressure and the warning light comes on if any pressure goes below threshold, or, directly to the point, even if all four pressures go below threshold, which would not trigger a "differential" alarm.
    The typical cause for a single pressure dropping would be a leak in one tire. For all four dropping together, the typical cause would be a large drop in outdoor temperature, such as that between Indianapolis and Dayton, OH six days ago, which turned on my TPMS light despite all four pressures staying quite close to each other.
    -Chap
  8. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Yeah, outside temp is gonna affect the pressure. I like to set mine at around 1am after its been sitting all day. A couple of degrees from the coldest time of night isn't a big enough difference, but the temperature difference between night and day is too much.
    After that I just leave it, I like to check once a month though.
  9. fuzzy1
    10,723
    Actually, no, my tires don't say that. In fact, a quick sampling of all four vehicles parked in dad's yard (where I am working now) at this very instant, finds NONE with that wording.
    At the moment, my Prius is the only one of wearing tires rated for under 50 psi. Its other tire set (I swap based on season, and it was shod with that other set a couple visits ago) is rated for 50.
    Reading the actual tire sidewall labels, without adding your own words -- even emphasized, at that -- is not a difficult concept. Among four different tires sets, I'm seeing three distinct wordings, NONE of them including that word you emphasized.
    #49 fuzzy1, Jul 9, 2018
    kithmo likes this.
  10. Starship16
    1,348
    1,455
    Beach Christmas
    My sidewall says: MAX Pressure 44 PSI. Michelin website says that number corresponds to the maximum load limit. Whatever! I don't claim to understand it, and you can argue all this psi stuff until the cows come home. :LOL: The Priuschat Tire Pressure Wars! The conservative 36 psi boys vs the wild 90 psi dudes!
    All I know, is that my Prius rides like an old stage coach If I exceed any pressure over 41, or abouts. It feels and sounds like I'm driving a '65 Chevy pickup! And all the crappy roads around here sure don't help. Good luck!
    #50 Starship16, Jul 9, 2018
    RCO, kithmo and Merkey like this.
  11. Mendel Leisk
    42,377
    I harp on about this: significantly higher pressures will transmit more road shocks to the suspension and bearings.
    Merkey likes this.
  12. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I agree...Prius all have the "active" TPMS system which has the TPMS sensor in each tire continuously reporting Pressure and Temperature, which is pretty cool data if we could only see it like many other cars can see the TPMS data readout without a special tool.
    The "passive" TPMS system - which is not used in Prius and seems less common these days - is where individual tire RPM is monitored and a delta RPM implies that a tire is low. I believe early Volts had the passive system, and some pre-2006 Toyota's had it.
    #52 wjtracy, Jul 9, 2018
    Merkey likes this.
  13. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    Get a Scangauge and then you can see all tire pressures.
    Fester likes this.
  14. fuzzy1
    10,723
    But only after a certain firmware revision that went into production earlier this year. Before that, late last fall, it was made available for those who sent their units in for an update, and a number of us took advantage of the offer.
    #54 fuzzy1, Jul 9, 2018
    Merkey likes this.
  15. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    I can see the pressures/temps with Techstream, but it would be nice to have it on a utility screen of the vehicle
    Raytheeagle likes this.
  16. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Buy a Lexus, the pressures are there(y).
  17. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Re: TPMS - On my *other* vehicle I just had a near blow out on the highway when my TPMS valve stem broke spontaneously. The tire place said the TPMS on some of the Dodge/Chrylers (minivans etc) have been corroding due to road salt etc. I was lucky the valve still held some air in, and the TPMS light came on allowing me to get to the exit to install a compact spare.
    We are lucky the Toyota TPMS are more robust, and you just gotta wonder if TPMS is a good thing or a bad thing overall. In theory very good to keep tires inflated but how many accidents/repairs are they causing?
    #57 wjtracy, Jul 10, 2018
  18. Mendel Leisk
    42,377
    That's irony personified.
  19. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
  20. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Race X Professional Tyre Pressure Gauge RX 0014 £10.99
    RCO likes this.
