Will a failing 12Volt Auxillary Battery adversely affect the hybrid EV battery?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by JImmyPriNew, Aug 25, 2020.
  1. BiomedO1
    BiomedO1 Senior Member
    3,555
    1,841
    SacTown, Ca
    in addition; cold cranking amps test isn't really valid for this car - as the traction battery actually starts the motor. The battery just needs to provide enough power to close those traction battery relays. Your on the traction battery when the green ready lamp is lit.
    jerrymildred likes this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,149
    Tampa, FL
    Exactly. Amp/hours are far more important on a hybrid than CCA. How long can it let the vampires suck out the electrons when the car is "off?"
