Will changing the Head Unit remove reverse camera gridlines?
Discussion in 'Gen 3 Prius Audio and Electronics' started by DJ Q, Feb 8, 2018.
  1. DJ Q
    DJ Q Junior Member
    52
    24
    Trinidad & Tobago
    I'm thinking of changing the head unit on my Gen III Prius to a Pioneer AVH-4201NEX
    What I'm wondering is what generates the guidelines that turn with the wheel... is it the camera or the head unit itself?
    Will I lose that when I change?
    Thanks!
  2. ssdesigner
    ssdesigner Active Member
    304
    241
    california
    2013 Aqua
    The head units control the guidelines. You can adjust them in the head unit settings.
  3. ChapmanF
    15,662
    The lines are generated by the parking assist ECU; on the cars that have them, the camera signal goes to the ECU instead of the headunit, the lines are added, and the combined signal goes to the headunit over a GVIF cable.
    As long as your new headunit has a GVIF input, it all might still work.
    -Chap
    HeadOfJarg likes this.
