Will EGR pipe inspection help me determine how bad EGR is?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bgustafson, Mar 23, 2018.
  1. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
    I have a last minute road trip next week. I won't have time between now and then to accomplish the complete EGR and manifold cleaning. I'm wondering if taking a look at the EGR pipe would help me determine how bad the EGR itself is? I don't want to risk a road trip if I could potentially damage my engine. I'll be driving from Chicago > Lexington. About 900-1,000 miles round trip. Odo is 104k, currently.
    Thanks for your input!(y)
    #1 Bgustafson, Mar 23, 2018
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    If you don’t have any symptoms just go for it.
  3. Bgustafson
    259
    222
    Chicago
    I thought it was something that didn’t give you any warning before failing?
  4. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Does your car make a rough transition between electric motor and firing the engine?
    Pixel XL ?
  5. Bgustafson
    259
    222
    Chicago
    Once in a while there's a slight jerk, however I'm no sure it's any rougher than my previous 2006. Seems normal. I'll monitor it more closely.
  6. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    If you do a ton of highway you may have more leeway with EGR.
    Taking a look at the EGR pipe can give us a rough idea.
    I'm hoping others have better advice.
    Pixel XL ?
  7. Mendel Leisk
    42,355
    With 104K miles on odometer, it's pretty much a given that the EGR will be partially clogged. Still, I wouldn't rush in, might as well wait till after. The pipe is readily accessible, and yeah, can act as the "canary in the coal mine". But with it almost for certain there will be partial clogging, maybe best not to look, till after.
    m.wynn, Raytheeagle and scona like this.
  8. Bgustafson
    259
    222
    Chicago
    Famous last words. ;):D
    AzWxGuy, Raytheeagle and Mendel Leisk like this.
  9. BZzap!
    1,607
    878
    Over the coarse of time the EGR can accumulate soot and carbon. As it was mentioned, it depends on the operating environment in which the car has be subjected. In any event, this is a condition that takes time to develope. If you feel that you have paid attention to the maintenance and haven’t been puttering around town with it exclusively, it should be fine.
    FYI, one of the symptoms is a misfire and rough engine start up.
    Raytheeagle likes this.
  10. Bgustafson
    259
    222
    Chicago
    I'm the second owner, previous owner did mostly highway miles.
  11. Mendel Leisk
    42,355
    My sense is that EGR clogging is inexorable/inevitable, regardless of driving style.Basically a design fail.
    Getting an oil catch can in, in concert with the EGR cleaning, might help mitigate future reoccurrence of the clogging.
    m.wynn, Raytheeagle and Bgustafson like this.
  12. Mendel Leisk
    42,355
    I think I should pull the throttle body off on ours come spring oil change. I'll be doing a second drain of the OCC then (OCC installed last fall, around same time as EGR cleaning), and it'd be interesting to see the condition of the intake manifold directly below the throttle body. I suspect it'll still be a bit oily; there seems to be a small amount of oil spitting back from the intake ports, beside the PCV contributions.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I will be doing round #2 of egr cooler to intake manifold cleaning / replacement in a couple of weeks:).
    This circuit install has ~55 k miles on it now and want to do the water pump while my old man is out here (hard to argue with a willing extra set of hands);).
    Have 175 k miles on our 2010, and doing the water pump as a preventative maintenance item as @Joele3 got me thinking I’m tempting fate:sick:.
    I’ll post up some pics once I’m done with round #2(y).
    #13 Raytheeagle, Mar 24, 2018
  14. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    I’ll be pulling out OCC soon too, which also a below PCV valve mount.
    Level from the OCC dipstick shows about 1/8 of an inch and have over 5 k miles on this setup.
  15. Mendel Leisk
    42,355
    My OCC caught about 50 cc of "cream", first time I checked. My notes:
    Saturday, December 30, 2017
    km: 73150~ (about 2380 kms since install)
    *Drained Oil Catch Can, about 50 cc, coffee with cream colour, smelled of gas.
    It seems like winter, rain and humidity, up the volume? I'm guessing I'll see about the same volume when I drain it again, in conjunction with mid-April oil change.
    It'd be interesting to see your water pump condition.
    I think I'd have to be REALLY bored to justify doing the water pump on ours, at 74K kms now, and driving less'n less. I'll do the coolant at 10 year mark, well ahead of the kms I'm sure.
    You higher mileage guys take all the hard knocks, and I just toodle along behind, arrive at the same conditions (if ever) many years on. (y)
  16. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    It'll be interesting if you can tell a difference in the EGR cooler with your OCC setup.
    Pixel XL ?
    m.wynn, Mendel Leisk and Raytheeagle like this.
  17. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    When I helped @m.wynn with his old Gen3 do a water pump replacement, the plastic impeller was what I found to be the weak point. @m.wynn was nice enough to let me do some destructive analysis :).
    What @Joele3 shared with me was at around 155 k miles, his failed and now he’s got a head gasket fail:(.
    9 years and 175 k miles out of a pump to me is a good run;).
    I’ll do destructive analysis on my pump and see what the impeller looks like. The magnets were in good shape, but the thin fins for the impeller will be my curiosity (y).
    #17 Raytheeagle, Mar 24, 2018
  18. Mendel Leisk
    42,355
    Plastic sounds like a poor choice.
    Bay Stater, scona and Raytheeagle like this.
  19. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    My plan is to run our Prius into the ground, so I can run this test ;).
    I’ve got the hv battery covered with the Prolong equipment :).
    I just hope the engine holds out :whistle:.
    Bay Stater, m.wynn and mjoo like this.
  20. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    I think thin cross section plastic is a poor choice ;).
    Plastic is an amazing material and has many useful applications. This is one of them as it is resistant to any corrosion and can perform well under stress:).
    But for a thin cross section to withstand many miles and years of use, everything has a service life:whistle:.
    Since the Prius was thought to be designed for 180k mile service life (at least by us around here), I’m inclined to pony up a water pump ;).
    Bay Stater, Mendel Leisk and m.wynn like this.
