Will EGR pipe inspection help me determine how bad EGR is?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bgustafson, Mar 23, 2018.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    If you have liquid resting on the discharge side of the check valve (in this case the PCV), you’ll have to overcome the liquid force along with the spring set pressure prior to the valve performing its designed function ;).
    While that may seem trivial, over time you’ll give the spring a new “memory” of how to work, which will affect long term functionality :(.
    So if you put the “wide spot in the line” below the PCV valve, it can free drain and not affect it:).
    Hope that helps(y).
  2. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
    Well that just makes my head spin.:whistle:
    Raytheeagle and m.wynn like this.
  3. Mendel Leisk
    41,463
    For me it was a slam dunk to locate the OCC low: lotsa room, short hose runs, cross beam convenient for mounting, and any caught oil/water needs to climb to escape the can.
    Bay Stater, mjoo and m.wynn like this.
  4. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Sorry, I tried to be as layman as I could:oops:.
    m.wynn likes this.
  5. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    This statement is plausible from my engine component tear down at 120 K miles. Upon inspection of the IM, throttle body, EGR pipe, and spark plugs (haven't taken apart the EGR assembly yet), found them to be very clean with little soot. I do mostly highway driving causing the engine to run constantly at low RPM most of the time.(y)
    farmecologist, m.wynn and Raytheeagle like this.
  6. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    Hmm so do we have consensus where the best OCC mount point is? Over on the OCC thread the OP had 3D printed a mounting plate that at least some have used. However, the mount point in that thread would be higher than the PCV valve. Also, does a low mount point have sufficient access to easily check the OCC level...etc?
    I think I'm going to hold off on OCC install for now (and just do the manifold cleaning) until we get a little more 'data' on how the OCCs are doing. :whistle:
  7. Mendel Leisk
    41,463
    Access from above for mine is definitely awkward. It works for me though, since the OCC I'm using has a tap on the underside, and I'm under the car with the engine underpanel off, every 6 months for an oil change, and we're quite low mileage.
    When I checked mine, about 2380 kms post install (at end of December) I got around 50 cc. I'd suspect that time of year is worst case, it'd be lesser amounts through summer. I'd guesstimate the working capacity of mine (Moroso 85474 Universal Air/Oil Separator) is about a cup.
    #47 Mendel Leisk, Mar 27, 2018
    m.wynn, Bay Stater and farmecologist like this.
  8. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Ah a request for data(y).
    I have some, but it is from the Northern California climate where it hasn’t dropped below freezing, so take this with a grain of salt;).
    I have ours mounted to the lower cross member and check the oil catch can dip stick every weekend, which is every 400-500 miles. I have put 6 k on our 2010 since the install and have accumulated about 1/8 of an inch of “material”:).
    When I do the preventative maintenance in a couple of weeks I’ll dump the oil catch can and measure the amount;).
    More to come(y).
    m.wynn, Bay Stater, RMB and 3 others like this.
  9. mjoo
    mjoo Senior Member
    1,156
    1,328
    Michigan
    As promised, I found a couple of sources.
    Page 7, figures 10a and 10c in this research paper depict for a gasoline engine the huge spike (10x) in particulates during acceleration and cold starting. The largest increases happen when their test vehicle accelerates from 80 km/h to 100 km/h and also from 100 km/h to 120 km/h.
    Also from this paper:
    "Finally, although the engine braking increases the total particle number emission of the studied vehicle, it should be noted that the total emission was dominated by particles emitted during acceleration conditions."
    An electric motor assisting acceleration of the vehicle can mitigate some of the soot production that occurs from extra fuel and/or EGR during acceleration. May be a good reason to pick a Prius Prime or future hybrid with a more powerful electric motor & battery.
    #49 mjoo, Mar 28, 2018
    m.wynn, Bay Stater and Grit like this.
  10. Mendel Leisk
    41,463
    Maybe 4th gen with EGR intake downstream of the Catalytic Converter does a wholesale reduction of the clogging. Time will tell. I haven't heard of any 4th gen'rs installing an Oil Catch Can. The lazy, complacent sloths. :ROFLMAO:
    m.wynn, RMB, Bay Stater and 3 others like this.
  11. Bgustafson
    259
    222
    Chicago
    With the amount of money I sunk into my 2nd gen over the course of last year, I could've funded 75% of a 4th gen purchase. :mad:
    m.wynn and Mendel Leisk like this.
  12. farmecologist
    1,958
    1,799
    Southern MN
    You are 'lucky' though...2nd gen Prii don't have these EGR components! Lucky you..eh? :D
  13. Mendel Leisk
    41,463
    They have shim style valve adjustment, bladder gas tank, coolant thermos, keeps 'em busy.
  14. Bgustafson
    259
    222
    Chicago
    Quick update... I did the trip - 900 miles and back home safely. All good. (y)
    m.wynn, RMB, farmecologist and 3 others like this.
