Will gen 3 wheels fit on gen 2?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Davidude, Jan 30, 2017.
Tags:
  1. Davidude
    Davidude Junior Member
    94
    Georgia
    Found a 2010 Prius for part out, and it looks like the wheels are in good condition. I was thinking it might go good with my white 04'. Is the stock(black) wheel size the same as most gen 2s? Hoping to just change my current tires to the new wheels.
  2. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    Yes same rims fit bought gen 2 and gen 3 Prius. Tires can be swaped between them if they have same size rims. I think gen 2 came with 15” or 16” rims and gen 3 with 15”, 16”, or 17” rims.
    Justdidit and Davidude like this.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I believe so, yes.
    Davidude likes this.
  4. Carter Moskowitz
    Carter Moskowitz New Member
    PHX
    Yes! I have them on my gen 2 Prius and took the hubcaps off and it looks BOMB
    iPhone View attachment 124143
    #4 Carter Moskowitz, Feb 8, 2017
  5. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Should fit, my 2010 came with silver colored wheels under the hubcaps, I believe later models had black wheels.
  6. MR OCD
    MR OCD New Member
    Anaheim, California
    Four Touring
    Did all 3rd gen have alloy wheels? I was looking to replace the silver 5 spoke plastic hub caps, and a site on Ebay said " remanufactured Toyota hubcaps for steel wheels. Please make sure your wheels are steel for proper fit."
  7. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    never seen steel wheels from toyota. just throw the plastic caps away for a nice custom alloy wheel look.
  8. daveprius09
    daveprius09 Junior Member
    Ivyland, Bensalem, Pennsylvania
    You can remove the ugly 3rd gen wheel covers and install a 2nd gen center cap in the center hole. Yes it fits i have done it and should have been that way to begin with.
  9. Mendel Leisk
    42,355
    Do get those centre caps, the 2"~ dia hub closer caps. Without those, especially if you're in an area with copious winter salt, you'll get a lot of hub rust.
    A thin coat of anti-seize on the hubs will keep rust at bay too, belts-and-braces. Extend the coverage to the mating surface that contacts the inside of the wheel too, keeps it rust-free and prevents rim getting glued on.
    Marcilla Smith likes this.
