Will going up one size correct speedometer?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Slovewell, Apr 30, 2010.
  1. Slovewell
    Slovewell New Member
    95
    Va
    I have a 2010 Prius and I, like others, have noticed that the speedometer is off (fast) by 2-3 mph. I have noticed that the miles on the odometer seem to accumulate faster too. I used a Garmin to confirm this which means when the car says I have 100,000 miles on it, the true mileage will actually be less. I was thinking of changing the tire size from the stock 195/65R-15 to a 205/65R-15 after the originals wear out. My concern is clearance in the wheel wells, especially when there is extra weight in the car. I know that doing this would slow down the speedometer but would that bring it closer to being accurate? Would it be a linear change or a percentage? I know it could slightly affect take off speed but I don't care. It shouldn't mess up the mileage too bad since the change is not that drastic. I saw where someone went from the 65 series to 60 series and lost a few miles per gallon, but that made sense because there is more rubber on the ground (more resistance). I am a little surprised it was so drastic but air pressure and brand may have something to do with that too. Thanks for any input.
  2. Jim Clark
    Jim Clark Member
    310
    22
    Northern VA, the 51st state (someday)
  3. bwilson4web
    15,586
    I did both speed and distance ground checks last summer with our 2010 Prius and found:
    • indicated speed ~102% - 51 mph indicates is 50 mph true
    • ground distance ~100% - I could find no significant ground distance error on the interstate I-65 from Ardmore TN to Nashville TN, ~90 miles
    What you want to use is the revolutions per mile for your next set of tires. The first number is the tread width and not nearly as effective in changing revolutions per mile as the second number. So with my NHW11 (2003) Prius, I went from:
    • 175/60R14 - 919 revolutions per mile
    • 175/70R14 - 886 revolutions per mile
    Now my speed indicated is 3% low so 60 mph indicated is ~62 mph. But I've always driven the speed limit or a bit low so this is not a big deal. But my next tires to test will be 195/70R14, 849 rev/mile, and these will more than double the error to 7%. At 60 mph indicated it will be ~65 mph and that is too much error for my taste.
    I'm looking at three alternatives:
    1. GPS speedometer - I found a nice, heads up unit for $165 and a couple of do-it-yourself units for less.
    2. Garmin nuvi in speed mode - generates a large enough speed display and also provides navigation. However, I'm also looking at all GPS units.
    3. iPhone GPS speedometer(?) - a wild-card, it could also be my MP3 player. But I won't contract with AT&T for phone service and it is a pricy solution. Still, it is easier to pull it in and out of the car than the oversized Garmin nuvi
    I'm not sure which approach I'll go with since there are significant advantages and disadvantages of each approach. I'm still doing my 'trade study.'
    GOOD LUCK!
  4. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Bob,
    If I understand what you were saying correctly, with the initial tires, you saw a 1 mile per hour difference in rate, but no significant difference in odometer reading (which suggests that the two aren't necessarily "coupled").
    If you switch to the 195/70/14 and see an approximate 5 mph difference in highway rate (65 mph vs 60 mph indicated) do you expect your odometer reading to still be accurate?
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Maybe I'm just being simple here, but if your speedometer is fast, and it's affecting your odometer meter...which is tied to decisions about routine maintenance and overall mileage which will eventually affect the value of your automobile isn't the best answer just for Toyota to fix this? I think a reasonably accurate speedometer and accurate odometer isn't something beyond expectation in a vehicle.
  6. bwilson4web
    15,586
    The odometer reading will change too but I only adjust that when I enter my gallons and miles ... once per tank. I tend not to worry so much about distance. In contrast, speed errors can lead to a discussion with law enforcement as well as driving in avoidable, high drag speed regions.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Generally the odometer is accurate as it comes from the factory. Speedometers are usually a little optimistic. Both of these are regulated by law. In some jurisdictions it is required that the speedometer read high.
    Tom
  8. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    There was similar discussion regarding this on the Phaeton Forum. While the speedometer is geared to read 2-3 mph high, the odometer will be dead-nuts on.
    This is so that, when using the largest size tire physically possible on the car, the speedometer will not read low (e.g.: you're doing 63 when the speedo reads 60). This is regulation in Europe and is common practice with most European vehicles. I've noticed the same discrepancy in my Prius, whereas the speedometer in my roommate's '10 Outback is dead on.
    Having said that, the readings on the odometer are accurate, providing you're using the factory-specced O.D. tire. For example, using the 215/45R17 tire, my speedometer is about 3.3% fast at 60 mph, but the odometer is accurate. When I switch to the winter tires (195/65R15), the delta is 1.49% larger, which means the calculations will be 1.5% too slow, meaning the odometer is now logging miles 1.5% slower than normal and the speedometer is now only 2.2% fast at 60.
  9. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Just use the Scangauge. it shows the true speed.
    Only the speedometer indication is 5% faster, everything else is correct except the mpg/tank average calculation is base on the instantaneous speedometer reading. It is about 5% higher too.
  10. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    Tom,
    This would make sense, but what about if someone changes their tire size, would the odo not be off slightly? I do not care, as I will drive my car till it cannot drive anymore, but I am curious to know.
  11. qbee42
    18,058
    3,074
    Northern Michigan
    Yes, that would throw off the odometer.
    Tom
  12. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    Generally, and for the first time in any car I've driven, the Prius speedo and my Garmin agree, and GPS velocity readouts, I'm told, are based on Doppler measurements of the satellites' carrier waves....
  13. Holbrook22
    Holbrook22 Junior Member
    68
    Holbrook, NY
    I've been heading back north from Florida for the past two days and have frequently checked the speedometer reading against my Garmin 760.
    Shortly after getting my Gen III I discovered that the speedometer was off by 1 mph. I first noticed it when going by those speed read-out signs and then by checking it against the Garmin.
    During this current trip I noticed that below 66 or so mph the speedometer is off 1 mph, yet after 68 mph up to the maximum speed I reached of 74 mph the speedometer and my Garmin both indicated the same speed.
  14. qbee42
    18,058
    3,074
    Northern Michigan
    I don't know of any common consumer grade GPS devices that measure Doppler speed. Consumer devices use track point time and distance to calculate speed. In other words, at time T1 you are at point P1; at time T2 you are at point P2. Find the distance between points P2 and P1, and divide by the time difference between T2 and T1, and you have the speed.
    Obviously this technique suffers with positional errors, and curving paths will also introduce errors.
    The Doppler units calculate speed by looking at the Doppler shift on the L1 signal from each satellite. Given that the satellites and the earth are all moving, this is no easy task. Some specialized commercial units can do this. It's only a matter of time until consumer units do too. Perhaps some high end units even now, but I'm not aware of any.
    Tom
  15. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    you are mainly worried about clearance?.... 205 is easy for a prius. my Gen II only rubs when i put 225/-/17's on... it's really the width that rubs, not height.
    i currently run 215/50/17. the speedo is basically dead accurate and the look is much better than stock... the package V model of the gen II uses 215/45/17... i heard 18 inch rims will fit the gen III without rubbing, so i doubt you will have problems...
  16. sti-nkr
    sti-nkr Prius Ricer
    45
    Tyler, Texas
    I currently run an 18x7 inch wheel with no clearance issues with 4 people and a trunk full of crap. i have 215/40/18 tires so they are stretched little rubber bands also.
  17. Marvinh
    Marvinh Marvin
    189
    NY - Long Island
    There is a calibration tool in the GPS system on my 2007 Prius. So I would assume it is also built into the 2010 model. If you go into the setup in the GPS system you will see 3 screens. The tire calibration is at the end of the 3rd screen.
    Marvinh
  18. qbee42
    18,058
    3,074
    Northern Michigan
    Keep in mind that this is only for the Nav system.
    Tom
  19. Slovewell
    95
    Va
    This is a great calculator. Based on the website, I could go from a 195/65R-15 to a 205/65R-15 or a 225/60R15 and that would slow my speedometer about 2.5 mph. When I am now going 63 mph my GPS and scanguage says I'm at 60 mph . I have even confirmed this riding next to other type cars with digital speedometers and the speed signs on the side of the road. My Garmin in my other vehicle shows them very close. I know the Prius is off consistantly which bothers me. Since Toyota did this on purpose I doubt they would correct it.
