Will I break the car if...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by yourock, Jun 1, 2012.
  1. yourock
    yourock Junior Member
    So Cal
    Hello everyone,
    Had the car for about a month now. Love it so far.
    I carpool with 4 to 5 adults to work 40 miles one way, mostly freeway in carpool lane. I hope I can ask a few questions in one thread so here it goes.
    Will I damage the car in anyway, with 5 adults in the car, if:
    1) accelerating up to 65 mph in EV mode?
    2) constantly switching between EV mode and HV mode during my commute? As opposed to leaving in EV mode until it automatically switches over to HV mode.
    I'm concerned that problems will occur if I am constantly switching in and out of EV mode or stressing the car since I have 5 adults.
  2. Grappas
    Grappas New Member
    Napa California
    If the car couldn't handle 5 people then they would've built it for 4 people and renamed it Volt.
    ....but in all seriousness, you'll be fine. Just enjoy the car and the high MPGe!
  3. crewdog
    crewdog Acting Ensign Prius Prime
    493
    388
    Woodstock, GA
    There's a yellow sticker on the door jamb on the driver's side that says "total weight of cargo and occupants should not exceed 825 lbs"
    As long as the adults you're carrying, including you the driver, don't total out to more than 825 pounds, you should be ok.
    52,855
    i probably wouldn't accellerate to 65 in ev mode. i would switch to hv at 15-20 mph just for efficiency, unless you're on a strictly ev route in which case you're fine except it will probably start the ice around 62 mph.
  5. NYPrius1
    NYPrius1 Active Member
    1,181
    125
    Middletown, NY
    825 divided by 5 = 165. Just make sure no one is over 165 lbs. That leaves out a lot of people. (Just Saying)
  6. bisco
    52,855
    i'm out.:oops:
  7. yourock
    So Cal
    But what is happening mechanically when I push the EV/HV button? Or is it just software? And is it no different than when the gas engine turns off while in HV mode?
  8. CharlesH
    2,798
    1,166
    Roseville, CA
    Not much happens using mechanical connections in the PiP. The steering and the brakes have mechanical connections for safety reasons, but even the brake behavior is moderated by the computer to favor regeneration if possible. All the EV/HV button does is tell the control computer whether you want to favor using the battery or the gasoline engine.
  9. blmoore
    blmoore Threadfinder
    31
    Pennsylvania
    Thanks for the info - I too was wondering if it was ok to "play" with switching back and forth between EV and HV - still getting the hang of how to get the best mileage!
