Will it be cheaper to replace the entire hybrid battery, or replace 19 cells?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GreenTea&SaltWater, Mar 16, 2022.
  1. GreenTea&SaltWater
    199
    58
    Los angeles
    So over the past few years I've replaced a total of 11 cells with various levels of success, the first repair giving me 15k miles, the second 100, and the most recent one 250mi before the check hybrid system issue came back. I'm thinking I may just have to replace the remaining 19 cells.
    If i buy 19 cells from JWAP at $30 each = $570 (and having already spent close to $300), would it be more cost efficient to just buy a new hybrid battery? How much would that cost?
  2. JC91006
    16,939
    8,647
    A new battery will cost you $1600 to $1800 bucks plus tax from a Toyota dealership online pricing. This is always the best option as it'll provide you with 10+ years of worry free battery service.
    The problem you are facing is the 2010 has a lot of issues that can come up. Brake accumulator/actuator issues that can cost $2000+. The infamous headgasket failure. Water pump needing replacement.
    Well you get the idea this will lead you down a slippery slope of spending money to keep this car running. One repair will lead to the next from this point forward. The next repair will not be far behind on a 2010
  3. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    My 2010 got a head gasket at 149k right before the California emissions warranty expired. It now sits at 200,000 with no further expenses other then oil, filters and headlight builds. I totally thought this car would be a money pit but so far no other major expenses have come up.
  4. GreenTea&SaltWater
    199
    58
    Los angeles
    My car is at 148k miles D:
  5. JC91006
    16,939
    8,647
    I'm at a similar mileage on my 2010. I've changed the HV battery (warranty), brake actuator (warranty). I've just changed the water pump recently and changed the EGR valve (warranty). Cleaned the EGR circuit and Intake manifold, so hopefully I'll be good for a little while
    Raytheeagle and 2010moneypit? like this.
  6. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    I’ve gotta 10 W 260 ish wife drives commercially. Replaced w a 2015 battery wen we bought . Junk yard battery. Nothing else ever done . Looks new inside n out a bit cracking on Driver seat. No egg no head nada and it’s never parked . Theyres something to that me thinks
    2010moneypit? likes this.
  7. GreenTea&SaltWater
    199
    58
    Los angeles
    When I first bought my prius in november 2019 the hybrid battery pack issue came on within 100 miles, and i checked the warranty and it was still within mileage but it had been a few months over 10 years so they didnt acccept it :(
