Will optima battery fit?
Discussion in 'Gen 2 Prius Main Forum' started by NinnJinn, Oct 17, 2013.
  1. NinnJinn
    NinnJinn Member
    276
    Indiana
    Last week I ordered an Optima yellow top D51R battery for my 2002 prius. Now that the 02 is not worth keeping, Can I install the D51R into my new 2008 prius?
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  3. NinnJinn
    NinnJinn Member
    276
    Indiana
  4. Patrick Wong
    18,210
    6,515
    The 12V battery for the Classic Prius has the positive terminal on the right side, when the battery is positioned so that the terminals are closest to you. That is the reverse of what is needed for 2G Prius where the positive terminal needs to be on the left side.
    If you install the battery so that the battery terminals are where they need to be, they will be quite close to the fender which poses a potential safety hazard if your car is hit in that fender.
  5. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Patrick,
    Will the Optima Yellow Top that is being sold that fits the Gen II Prius work without any sort of kit? In other words, can you use the existing OEM cables that came with the Gen II Prius originally?
    I was under the impression that the Optima's being sold today have the small posts with the orientation of the posts in the correct placement (negative close to rear of car and facing towards center of car). But now I am not sure about all of that.
    Thanks for all of your help here on Prius Chat!
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  7. brownsnoutuk
    brownsnoutuk Active Member
    185
    119
    Shepherd, TX
    You can buy a direct fit battery from Napa, either a Napa brand or the Optima Brand. Both have the pencil posts and vent holes.
