Will Our Prius Rust Too?!
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Coast Cruiser, Nov 13, 2016.
  1. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Does that plastic panel cover the oil filter area? I wonder how the mechanics at the dealership remove those rusted bolts when they are doing an oil change? And do they replace them with new boats…
    RCO likes this.
    52,761
    all manufacturers cut corners where they feel like they can. if it becomes a big problem, they change strategy. if you want a perfect car that will last forever, look at
    RCO likes this.
  3. Tideland Prius
    16,667
    Yes but there's an access panel. I believe the access panel is free of anything metal. It's all plastic. (snap in/out plastic tongue and plastic release)
    look at ...? Don't leave us hanging!
    RCO and Coast Cruiser like this.
  4. Coast Cruiser
    2,267
    2,571
    That should read: new "bolts."
    Tideland Prius likes this.
  5. bisco
    52,761
    pick your poison.:cool:
    #25 bisco, Nov 13, 2016
    RCO likes this.
  6. Coast Cruiser
    2,267
    2,571
    Man, that's the most terrible rust I have ever seen on a vehicle! Until I read that article, I had no idea this rust problem went so far back in time. That is very embarrassing for Toyota. I'm surprised they still sell as many trucks as they do.
  7. Coast Cruiser
    2,267
    2,571
    Back in my younger days, I crawled underneath my 1995 Camry many times and changed the engine oil and transmission fluid. I don't recall ever seeing any rust under there, anywhere.
    So, what has Toyota changed since then?
  8. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    IIRC the Gen 4 has returned to screws (3) holding the access panel on.
    RCO, Mendel Leisk and Coast Cruiser like this.
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Wow.
    I would have to wonder how that happened.
    That level of rusting, you think would only manifest with some outside contributing factors.
    How do you NOT see that coming? And that didn't happen overnight.
    Impressive video..and horrible rust problem...BUT...you'd hardly need a frame inspection to determine....that frame needs to be replaced.
  10. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Other published reports I've seen have shown the leaf spring mounting locations giving way with the axle rotating about! :eek: Yeah, that's not good.....
    Edit: ahh, I knew I've seen a settlement before. Two years ago, very similar issue: Toyota Recalls 690,000 Tacoma Pickups for Snapping Leaf Springs – News – Car and Driver | Car and Driver Blog
  11. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Shucks, and I thought that new boats was what they were buying with the $ they made by not replacing rusted parts . . .
  12. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I started reading the report in our local press - I thought it said it only affected USA built vehicles, so stopped reading, knowing that our Australian PRIUS is built in Japan - are the USA ones imported or locally manufactured?
    In reality, anything metallic will rust given enough time. Cars have been notorious in past years. I remember cars in the '60s, with a 1yr warranty would often have visible rust before the warranty expired, corners of doors etc could be bought to weld on. My 3yr old NISSAN in 1980 was riddled with rust. Cars improved in the late '80s, my first car I didn't have any sign of rust in was a 1980 DAIHATSU (Toyota by another name), and since then, most cars have been quite good - but except for maybe a BMW i3 with plastic panels, they will all rust in time. Most will die of other causes first though.
    The bodies go through a number of process including dips, as well as being pressed from steel which is more rust resistant than it was in say the '50s etc. Trucks and truck based SUVs are a very different manufacturing process.
    Personally, I'm not at all worried.
    RCO likes this.
  13. krmcg
    2,592
    2,393
    Whittier, CA
    Every Prius is built in Japan.
    alanclarkeau and RCO like this.
  14. Tideland Prius
    16,667
    Bummer.
    RCO likes this.
  15. Mendel Leisk
    42,249
    If they're the coarse thread screws, maybe not that bad. They're likely tapping into a nylon receptor. Just take it easy re-installing them, by hand, don't strip the nylon portion. They're hopeless for rusting, so whenever I take that kind out I saturate them with oil before reinstall.
    And too (applause): there's NO HINGE, the smaller panel is completely held by screws, comes off completely, and then is reinstalled.
    RCO likes this.
  16. Coast Cruiser
    2,267
    2,571
    Maybe Mendel will post the photos of his 2010 Prius again. I never saw rust that bad on either my '95 or '05 Camrys. And I drove each of those for 10 years. My parent's '94 Camry didn't show any rust after 25 years of ownership. My dad did all the Maint, and I was under that car many times with him. He drove it to Montana every winter.
    We don't have snow here, or salt-covered roads. I'm not too concerned about my new Prius, but I don't think a 5 or 6 year old Gen3 should be showing so much rust on the suspension parts, bolts, or frame.
    But those Toyota trucks are an embarrassment, and they ignored/neglected the problem for way too long. Maybe 3.4 billion will deflate their ego a bit. (Or maybe not)
  17. Mendel Leisk
    42,249
    We hardly get snow here too. Once in a long while. Winter typically alternates between cold but wet, and below freezing but clear. When the temps start dropping trucks go 'round with a multi-nozzle spray system, leaving lines of brine solution. I refer to them as the "guitar strings". And if there's snow they spread rock salt and/or sand.
    Bottom of right/rear shock:
    Left/rear trailing arm linkage to body:
    The way the bolts rust-bloom is something new for me. :(
    #37 Mendel Leisk, Nov 13, 2016
    Coast Cruiser and RCO like this.
  18. Wolfman33
    Wolfman33 Member
    43
    26
    Virginia Beach, VA
    2022 Prius Prime
    My other car is a 92 Honda Accord. I expect rust on a 92 but it's still road worthy. Being new to Toyota's I'm pretty disappointed about this. So am I going to have to trade my Toyota after a couple years?
  19. alanclarkeau
    7,045
    7,593
    I wouldn't worry - it is only trucks and SUVs with old-fashioned chassis.
    RCO likes this.
  20. Prodigyplace
    12,710
    11,848
    Central Virginia
    This reminded me of their earlier recall for 2000-2003 Tundras. See Toyota Launches Tundra Frame Replacement Program | Tundra Headquarters Blog
    It is interesting that the 2004 model is not covered by either program? I happen to have a 2000 Tundra but it has not had the rust issue.
    Why not another recall?
