Will park at LAX for 13 days. Dead battery for sure?
Discussion in 'Gen 3 Prius Main Forum' started by Bruno_S, Sep 20, 2009.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    To top Patrick's advice, replace it with Optimum battery that can deep discharge. This way, when the 12V battery get fully discharged, it won't damage (~half the life) it.
  2. hotbrass
    hotbrass New Member
    312
    35
    Cowtown
    Is the 12v battery charged off the inverter or does the ICE have a separate alternator?
  3. rumpledoll
    rumpledoll Member
    179
    46
    New Jersey, USA
    There is no seperate alternator on the Prius. The 12V battery is charged from a dc/dc converter off the high voltage power supply.
  4. bpollard
    bpollard Junior Member
    58
    Austin, Texas
    just adding this little tidbit - as I don't have time to read the entire post.
    My wife parked her car at the airport on the morning of November 10th, and didn't retrieve it until the evening of November 28th. She did not experience any problems.
  5. morguex
    morguex Junior Member
    New Mexico
    For those of you who frequently leave the Prius parked for extended periods, try something like this:
    Solar Panel
  6. going red baby!
    going red baby! still a n00b
    610
    96
    Los Angeles
    Better have really long cables for those that have parked in covered lots.
    Looks like a cool little device though, and affordable too.
    Maybe those of us with solar roofs can mod it to charge the battery too!
  7. kentak
    kentak Junior Member
    Washington
    I left my 2010 Prius in the driveway from Oct 13 thru Nov 17 while out of town. I tried the passenger door on Nov 18, and couldn't open the door. I then went to the driver side door, got in, started the car, and had no problems after that. I heard, or read, somewhere that this model Prius shuts down automatically after a set period of time.
  8. alokeprasad
    alokeprasad Member
    162
    Ohio
    On Page 49 of my 2010 Prius Pkg III manual:
    Battery-saving function
    In the following circumstances, the entry function is disabled in order to prevent
    the vehicle battery from discharging and electronic key battery from
    depleting.
    l When the entry function has not been used for 5 days or more
    l When the electronic key has been left within approximately 6 ft. (2 m) of
    the vehicle for 10 minutes or more
    l If the entry function has not been used for 9 days or more, the vehicle
    cannot be unlocked by a door other than the driver’s door. To unlock the
    vehicle, grip the driver’s door handle or use the wireless remote control
    or the mechanical key.
    The system will resume operation when...
    l The vehicle is locked touching the door handle lock sensor area.
    l The vehicle is locked/unlocked using the wireless remote control function
    (→P. 63) or the mechanical key. (→P. 541)
    Looks like Toyota has taken care of the problem (except for bad batteries, which can discharge "for no reason").
  9. patsparks
    10,664
    567
    Adelaide South Australia
    If your 12 volt battery has gone flat 12 times, or more than 3 or 4 times it is most likely knacked and needs replacing. You can't run a lead acid battery designed for automotive use flat without causing harm to the battery. If the battery wasn't a dud when new it is now.
  10. garygid
    garygid Senior Member - Blizzard Pearl
    379
    23
    Orange County, CA
    Note, if you accidently turn the headlights on AFTER
    turning the 2010 Prius OFF, the headlights will stay on.
  11. The_Doctor
    The_Doctor New Member
    UK
    Just to add my own experience, parked my Mark 3 for 20 days at LHR, returned to it yesterday and happy to report it started up "on the button".
  12. littleprius
    littleprius New Member
    53
    Okay...did this procedure work when you tried it out a week later?
  13. saunj
    saunj New Member
    16
    San Diego
    I digitally recorded voltage and current every minute for 12 days. The results were voltage 12.54 to 12.36. Total drain 6.9 ampere-hours. The conditions were: Headlight and dome switches off, Kerr alarm activated and armed. Car started normally. Method was: 1/20 ohm precision 4-terminal shunt wired between battery negative post and battery holdown bolt before disconnecting the battery negative lead from chassis. Voltage measured from battery positive post to chassis. The data acquisition unit has a precision of 1 milliamp and 1/50 volt. Details at:
    Measuring Instrument with an Optically-Isolated Analog Input
  14. practica
    practica Junior Member
    43
    Raleigh, NC
    My 2010 manual says the smartkey system is automatically disabled after 5 days to save the battery -- so you don't have to do it manually.
    Yet by some trickery it comes alive again when it needs to. The whole thing is a big computer, sort of a giant laptop with wheels -- and the operating system quirks are obscure in the usual way.
  15. kentak
    Washington
    I have left the Prius for over 30 days while out of town. I have had no problems getting started again. The only thing is the unlocking works on the driver's side.
    Ken Tak
  16. a_gray_prius
    2,927
    783
    IL
    I've left my Gen2 Prius parked in front of my place for a month without driving it. No problems.
  17. madraddoc
    madraddoc New Member
    SC
    Purchased new 2010 Prius III with solar roof and Nav. in June.
    Drove car car minimally for first 2 days of ownership and then drove to Charleston International Airport and left car in longterm lot for 6 weeks. Did not do any key disabling/battery disconnection/etc.
    Returned 6 weeks later. Remote keyless unlock worked normally upon touching door handle and car started without incident. Drove away without another thought about the issue.
  18. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    When you pull on the door handle, the system realizes you are there and re-enables the SKS. If it's night and you are clever, you might notice that the interior lights failed to come on as you approached the car. Other than that, it's pretty transparent.
    Tom
