Will ScanGauge II work correctly in Prime?
Discussion in 'Prime Main Forum (2017-2022)' started by dafinn, Dec 12, 2017.
  1. Alvin Huang
    Alvin Huang Junior Member
    22
    Taiwan
    In the RM100000001009M.pdf, here is A/C information.
    A/C Consumption - Power A/C consumption power- Min.: 0.00 kW, Max.:12.75 kW - While the air conditioning system is operating:0 to 5.00 kW - Air conditioning system
    From definition, I think the MTH I used 0014000100000 should be correct as I observed..
  2. Alvin Huang
    22
    Taiwan
    @Linear Logic
    Can we have Auxliary Battery volt/current/temperature? I saw them in Techstream..
    It seems quite important since all electrical devices using 12V battery except traction motors and air condition compressor.
    Thanks!
  3. Linear Logic
    Linear Logic Junior Member
    Mesa
    I've added the following:
    Auxiliary Battery Current
    Auxiliary Battery Temperature
    For Aux Battery Temperature, if you use a MTH of 00010001FE70 it should read in °C if that's your preference.
    Also, with regard to an XGauge for Auxiliary Battery Voltage, it may not be necessary. The VLT gauge on the ScanGauge will show you the 12V battery voltage. The OBDII port is wired directly to the battery (with only a fuse in between) so the ScanGauge is able to take a direct voltage reading of the battery and displays it as the VLT gauge on the gauge screen.
  4. Alvin Huang
    22
    Taiwan
    Yes! worked as a charm !
    Thanks alot !
  5. Alvin Huang
    22
    Taiwan
    @Linear Logic If the current value is negative, is it under charging or discharging?
  6. Linear Logic
    Mesa
    A negative value I believe means it's charging.
    #66 Linear Logic, Apr 5, 2018
    Alvin Huang likes this.
  7. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    @Linear Logic today is the first day i've hooked up my ScanGuage to my prime. Question, the Scan Guage turns off when I turn off the car, but turns back on when the car is charging and does not shut off, will it shut off when charging is completed?
  8. PCPrime
    PCPrime Member
    110
    103
    Tampa Florida
    Yes, it will shutoff when charging is completed
  9. Mark57
    2,945
    2,740
    OK
    It will also turn on when you walk close enough to it to wake up the car with the key fob in your pocket.
    If any of this bothers anyone it's very easy to just disconnect the cable from the back of the SGII before you get out. That way you know there's no power draw. Easy to reconnect. Snap!
