Will the 2021 Prius Prime have TSS 2.0?
Discussion in 'Prime Main Forum (2017-2022)' started by run2w8s, May 15, 2020.
  1. Tideland Prius
    16,559
    @Sarge @drash I can confirm that the 2021 Prime is getting a 120V outlet - It is mentioned in the ordering form.
    Sarge and drash like this.
  2. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Sweet!!! I wonder if it will be a 10Amp one like the RAV4 Prime? So they’ll probably make double use of the Inverter and put the outlet in the hatch area. Of course there’s a bit of area below the middle front console in the rear passenger side they could stick the outlet in as well.
    iPad ? Pro
  3. Daisy81
    Daisy81 New Member
    25
    Frisco, TX
    2020 Prius Prime
    Are you guys talking about power in the rear and not just in the front?
    My boyfriend installed this accessory outlet in the back of the armrest for the second row passengers to use in my 2020 Prius Limited while he was installing a front and rear hidden dash cam system.
  4. Tideland Prius
    16,559
    Yes. The 2021 Prime states it’ll have a 120V outlet so it’ll probably be a two-prong outlet.
  5. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    any confirmation that the 2021 PP Limited does/does not have android auto? Is it really restricted to the LE model?
  6. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    Yap, AA only for LE model with 7" display not for XLE or Limited with 11.6" display. It is on the Toyota site. https://www.toyota.com/priusprime/features/mpg/1235/1237/1239
  7. yaun
    yaun Member
    72
    65
    MA
    What effect does TSS 2.0 have? Has LKA improved?
  8. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    TSS 2 has LTA instead of LKA.
    It works but it is not that great, I have it on my 2019 Corolla HSD.
    When the light is good and the lines are clear it often works quite good. But if there are for example double lines in the center it sometimes wants to use the left one of those and it then crosses the right one and system complains that you crossed a line...
    Full range ACC works good in traffic but even on the shortest following distance it starts to slow down way to early. If you drive up to a slower vehicle it starts dropping speed when you are still 300 to 400m behind it so you either need to apply a bit of throttle yourself or switch to the passing lane way to early.
    It tends to quickly react on vehicles slowing before you but it is very slow to react when vehicles in front speed up again.
    Merkey likes this.
  9. Tideland Prius
    16,559
    TSS-P 2.0 also adds low light pedestrian detection and daylight bicyclist detection to the PCS. Road Sign Recognition is part of the package as well (instead of relying on the navigation map speed limit data to display speed limits)
