Will the Chevrolet Volt be a failure or a success?
Discussion in 'Chevrolet Volt' started by Reginnald, Jan 20, 2011.
  1. gwmort
    gwmort Active Member
    985
    211
    Delaware
    Dude, that is sooo 8 pages ago...
  2. mfennell
    mfennell New Member
    241
    39
    They're all from the Kill-A-Watt. That's the only number that matters from an end user view IMHO.
    Unfortunately, the Volt does not tell you anything about electricity usage. I've read that the Leaf does but noone seems to believe the numbers it produces.
    So, the best we have is that a "dead" battery takes 12.9 kWh (EPA rating) to 13.1kWh (what I've personally measured) but we can only make an educated guess at what that translates to at the battery. 10-10.5 seems to be a popular range.
  3. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    We have all stated the Volt is a finely defined niche vehicle. Your Dad fits the niche. That is terrific. Those that do, the Volt is a good choice if you can afford the original cost .... or lease one.
    The "venom" stems from the tripe from GM (lies and misrepresentation), their president (would not be cought dead in a Prius), and the fact that the taxpayers had to bail out GM. And, now we read the government wants out and will not "make" money in the deal.
    Consider Ford. There is no "venom: there. They did not accept taxpayer money; they build a most competent vehicle; they did not bash the Prius.
    GM - "Too big to fail; too big to succeed."
  4. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    I didn't bring it up, and I used the word "were". I really don't want to even talk about it anymore. Please ignore the fact I'm talking about it now. :cool:
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Stop talking about not talking about it, so that we can move on to talking about not talking about not talking.
    Tom
  6. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    The Volt does use a mechanical path from ICE to wheels in CS mode (and at times in CD mode).
    So, how does it get across country just on electric? And we should be glad for said mechanical path, thus avoiding even worse CS mpg if everything had to go from mechanical to electric and back. So the statement that we are no longer talking about should probably be excused as poorly conceived mistake.
  7. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Thanks for the info. You seem to be achieving better than EPA rating.
    Have you had enough time in CS mode to see what the average MPG is during those excursions?
  8. gwmort
    985
    211
    Delaware
    My CS mode mileage has been 40.2 mpg so far in my Volt.
  9. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Displayed or measured at the pump?
  10. mfennell
    mfennell New Member
    241
    39
    I have only had one long trip. Overall average over ~250 CS miles was 35mpg according to the car's measure of fuel usage. ~220miles were highway @ 75-80mph with a few faster runs (testing, you know). I do have to confess I, um, left the car ON overnight. That was rather convenient in the morning since mine was the only car not covered in frost, but certainly affected gas mileage some.
    Another time, I traveled 18.5 miles mixed suburban/highway over the course of a day on 0.53 gallons of gas. I'm skeptical of 2 significant digit resolution in gas used (I guess it should be able to calculate it, but still...) though. Also, short trips like that are easily skewed by where in the duty cycle (engine on/off) your trip happens to end.
  11. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Based on what findings?
  12. Mark57
    2,945
    2,740
    OK
    Definite troll like qualities detected after reviewing all his posts.
  13. gwmort
    985
    211
    Delaware
    Displayed miles in CS mode divided by gallons at the pump, displayed mileage in the car was 94 mpg but its skewed by not factoring the EV miles.
  14. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    It is amazing how many people believe the entertainment show like Top Gear said.
    I would like to know where LG Chem get the Lithium and make the 400 lbs battery cells before shipping it to US.
    Prius HV battery is only 99 lbs.
  15. mfennell
    mfennell New Member
    241
    39
    Prius PHV battery is 330lbs, which I can't get my head around. Toyota Source.
  16. bigmike5
    bigmike5 New Member
    25
    San Jose, CA
    The battery unlike most batteries we are familiar with is not cylindrical or rectangular. The Volt battery is T-shaped and weighs approximately 450 pounds. The battery works best in a temperature controlled environment. The battery maintains a constant temperature by being liquid heated and/or cooled.
    Due to the battery’s weight, shape and size special handling is required. A pallet jack is recommended and only trained technicians should handle, remove or replace the battery.
    Can you get your head around that?
  17. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I believe it includes BMS and cooling components with eAT-PZEV 10 years / 150k warranty.
    If you include the liquid cooling components for Volt's battery, how much will it weight?
  18. mfennell
    mfennell New Member
    241
    39
    It's 16kWh. The PHV battery is about 5. Do you see the difference?
  19. mfennell
    mfennell New Member
    241
    39
    You believe but you don't know. Nor do I know what the external cooling components of the Volt battery weigh. I suspect they weight less than the extra 575lbs the Volt pack would have to weigh to be equivalent to the PHV per kWh.
    I'm still curious why the PHV battery weighs 63lb/kWh and the volt 27lb/kWh. Because of the warranty? :rolleyes:
    EDIT: The Leaf, at 24kWh/660lbs, is almost exactly the same as the Volt @ 27.5lb/kWh. Note that there's some confusion about whether the 24 is actual capacity or available capacity.
  20. Skoorbmax
    2,641
    265
    Western NY
    Ironically you found his post patronizing and yet you acted like somebody who is being spoken to by their father. Now go to your room until you've come out and know what environmental impact the Prius actually has.
