Will the EV-Auto mode drain the battery all the way down if you drive far enough ?
Discussion in 'Prime Fuel Economy & EV Range' started by GKL, Jun 13, 2020.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    Unlike @mr88cet, I see considerable difference in efficiency between normal and eco in EV mode when driving at lower speeds. I can set the throttle to a much more precise power point at low speeds in eco mode and that often lets me keep the m/kWh indicator at around 10 m/kWh at those lower speeds. It's way twitchier in normal and way way twitchier in power mode. At highway speeds, it's not much of a factor since you're more in the middle of the throttle range. So, I just leave it in eco and the cruise control knows what to do.
    GKL and mr88cet like this.
  2. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Good stuff! I have also seen these sorts of concerns and effects. For me at least, the differences between Eco and Power mode (in EV) have been fairly small — perhaps on the same order as air conditioner on vs. off.
    As with so many things, it depends upon driving conditions: I usually drive in suburban traffic, so I’m only occasionally in a position to be able to take much advantage of Power Mode, or even Normal Mode, anyway. So, I generally keep it in Eco anyway, unless I have a merging kind of situation to deal with.
    GKL and jerrymildred like this.
  3. GKL
    GKL Active Member
    533
    259
    South Carolina
    2020 Prius Prime
    Thanks, while we normally don't get excessively cold winter weather here in South Carolina (rare exceptions) it can get quite chilly at night here in the winter, but likely 95% of our driving will tend to be during the daylight hours. But I think my wife will like the steering wheel and seat heaters :D
    As far as the A/C even in our house we prefer only using A/C when it gets excessively hot and humid, even then we just try to make it comfortable and not chilly. So we will do the same in the car.
    Right now the car can get really hot on the inside after sitting parked in the sun for a while during the day, but we ordered a 10x20 canopy to park the car under, I am thinking that will make a difference in keeping the car from getting as hot inside when parked, not to mention protecting the paint from the sun and occasional bird droppings. :D
  4. GKL
    GKL Active Member
    533
    259
    South Carolina
    2020 Prius Prime
    Okay, I had been considering switching to normal mode for better response, but after hearing both your comments maybe I'll leave it in Eco for local driving, we live in a small town, lots of stop signs and a few traffic lights, most of the town ranges from 30mph to 35mph, with the exception of the bypass which is 45mph and the main road on the other side of town in the business section is 25mph.
    Maybe I'll wait to the times we go out of town and get on the road leading to the expressway (55mph) to switch to normal mode and of course leave it there for the expressway (70mph).
    mr88cet likes this.
  5. jerrymildred
    11,517
    14,147
    Tampa, FL
    Yeah. ECO mode doesn't reduce the car's ability to accelerate. It just takes more pedal travel to get the same response until you start getting close to WOT.
    mr88cet and GKL like this.
  6. GKL
    GKL Active Member
    533
    259
    South Carolina
    2020 Prius Prime
    Okay, I got the impression from some posts that the normal mode added some more "pep" and better response than Eco mode and I didn't want to feel like it was driving sluggish like it had a delayed reaction.
  7. jerrymildred
    11,517
    14,147
    Tampa, FL
    It just remaps the throttle so it feels peppier at low pedal travel. This is an old picture, but it should be very similar in the newer generation. At least it feels like it. Full power is the same in any mode.
    Tideland Prius and GKL like this.
  8. GKL
    GKL Active Member
    533
    259
    South Carolina
    2020 Prius Prime
    Okay, so Eco mode should be best for local driving in EV mode, and maybe switch to normal when going out of town and faster speeds in HV mode ?
    Sorry for all the questions, just so many variables to sort out as a noob :LOL:
    jerrymildred and Tideland Prius like this.
  9. mr88cet
    2,313
    1,335
    Austin, TX
    I think sometime back in 2018, about a year or so after we bought our P.Prime, I did an acceleration study, flooring it in Eco, Normal, and Power modes, and didn’t see much difference, if any. As you pointed out, it’s much more about what it does with the throttle in the middle than all the way “floored” or all the way off.
    The mathematical analogy I came up with at the time for the throttle mapping is that it’s more or less like y = x vs. y = x ^ 2 vs. y = sqrt (x):
    * Foot off the pedal means 0 power no matter the Mode setting. For x = 0: x = x^2 = sqrt(x) = 0.
    * Pedal floored means full power (1), no matter the Mode. For x = 1: x = x^2 = sqrt(x) = 1.
    So:
    * Normal Mode is roughly linear: the pedal half-way down (0.5) gives you about half the power.
    * Eco Mode is (perhaps ironically) like x-squared: the pedal halfway down gives 0.5 * 0.5 = 0.25 power.
    * Power Mode is (again, perhaps ironically) like square-root-of-x: the pedal halfway down gives you square-root of 1/2, 0.7071..., power.
    Anyway, I’ve more recently concluded that there are slight time- or speed-related effects too: EV Eco Mode also seems to slightly, implicitly “ease off the hammer,” so to speak, as your speed increases. Whereas Power Mode tends to continue accelerating more at higher speeds.
    #29 mr88cet, Jun 16, 2020
  10. jerrymildred
    11,517
    14,147
    Tampa, FL
    No problem. You ask good questions. You could switch back & forth as you described. And that would be fine. There is no universal "best." Your idea might be best if you want a combination of maximum efficiency around town with a more "normal" response on the highway. For me, I just leave it in ECO. Once my foot adapted to the feel of the throttle, there was no reason to change the setting anymore. But I do change the climate control in and out of its ECO mode depending on passengers and weather.
    Coming from the realm of sport touring motorcycles, I have not ever experienced a car that had anything like a responsive throttle. They are out there, but cost too many years worth of paychecks. I just like efficiency. :D
    dig4dirt, GKL and mr88cet like this.
  11. mr88cet
    2,313
    1,335
    Austin, TX
    I agree on all of these comments.
    In terms of acceleration, I have more concerns with HV Mode than with EV Mode! EV acceleration responds instantly, and is more substantial from a stop or near-stop.
    Two or three times now, I’ve switched lanes into a faster-moving lane, being used to it leaping over and accelerating quickly. That, only to forget that I’m in HV Mode, where the acceleration has a slight lag and is a bit sluggish from a near stop, compared to EV Mode.
  12. jerrymildred
    11,517
    14,147
    Tampa, FL
    Yup! Electric motors have full torque from zero RPM.
    But it also seems like at about any speed, if I switch from HV to EV while keeping the throttle in the same position, there's a little extra push like a weak turbo charger kicked in. Going the other way, the speed drops. The only guess I have on that is that they didn't quite get the throttle mapping to match between the two power sources. Not a surprise when you consider how differently they behave.
  13. mr88cet
    2,313
    1,335
    Austin, TX
    I was about to add something to that effect; you beat me to it.
    More specifically, at medium-throttle, Eco Mode especially, switching from EV to HV, everything becomes sluggish. Then switching back to EV, every feels like gliding on Teflon again: quicker, smoother, and slicker!
    However, in HV Power mode, I do find the acceleration from a stop to be considerably more responsive than in HV Eco mode.
    Soooo, if you need a burst of acceleration, temporarily switch to power mode is usually not a bad idea. Except that you’re more likely to lose tire grip entirely in Power-Mode acceleration from a stop!
    As you can tell, it’s a topic we love to ramble on about!
    #33 mr88cet, Jun 16, 2020
  14. GKL
    GKL Active Member
    533
    259
    South Carolina
    2020 Prius Prime
    Hey, ramble on, I may not feel the need to respond to every post, but I like to read them and learn from the actual experiences of different drivers, the manual is good to get much info, but learning from actual driver experiences is kinda like "on the job training" :LOL:
    dig4dirt, benagi and jerrymildred like this.
  15. Tideland Prius
    16,527
    Yup. And that's what everyone who's ever driven an electric car will experience - that instant torque. It's what gets people hooked. (What do you mean the engine has to rev up to 4,400rpm to get max torque? :LOL:)
    mr88cet, jerrymildred and GKL like this.
  16. mr88cet
    2,313
    1,335
    Austin, TX
    Indeed!
    This video cracks me up! My favorites:
    * Hey, where’d my torque go?!
    * What’s with the [engine] noise?
    * Transmissions?! What the frack?!
    #36 mr88cet, Jun 17, 2020
    Tips, benagi, Tideland Prius and 2 others like this.
  17. phlack
    phlack Junior Member
    32
    2020 Prius PHV
    What lower speeds are those? I'm rarely getting close to 10m/kWh even at slow speeds.
  18. jerrymildred
    11,517
    14,147
    Tampa, FL
    Oh, maybe 25 mph or so. Generally on those annoying speed bump roads found in expensive neighborhoods. On a 35 mph road, I can set the cruise & it'll run along at about 7-8 m/kWh. I can also do that w/o the cruise, but it's more work.
  19. CINQUIRY
    CINQUIRY Junior Member
    24
    Little Rhody
    2025 Prius Plug-in
    SE
    Can I switch modes while my phev 2020 is moving (silly Q). It appears The hv mode will only work when the the car is charged? Correct? I’m trying to get the most from a charge.
    Tips and Salamander_King like this.
  20. jerrymildred
    11,517
    14,147
    Tampa, FL
    Of course.
    No, HV works all the time. EV has to have some EV range showing which can come from the wall, from using charge mode, or from going down a mountain. If you don't have EV range available and try to put it into EV, it beeps, says you can't do that, and delivers a mild shock through the driver's seat. (I might have made up that last part. :LOL:)
    Sounds like you haven't been properly introduced to your owners manual. For most cars, it's basically a kneeling pad for when you change a tire. For the Prime, it's your new best friend. ;) It really helps to peruse that thing till you get an idea what's going on with this amazing machine. That and the old saying around here: "Just drive it." Enjoy the wonderful car. It's amazingly carefree. But it does have lots of cool features that the manual will help you find and use.
