Will the new 2012 front bumper fit on a 2011?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by D Unit, Apr 19, 2012.
  1. antech5
    antech5 Member
    160
    who is the seller that you found on ebay selling the front bumper for that cheap. I had no luck finding any of the drl on ebay as you have.
  2. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    seller is elady01 for the bumper. can you post a pic of your car? I'd love to see it. How did you connect the DRLs.? Do they turn off when you turn the headlights on?
  3. antech5
    antech5 Member
    160
    I had the body shop finish all the wiring and install. DRLs turns off with the headlights turned on. My front end looks identical to any 2012 prius, I had fog lights installed also. Nothing special, looks just like any 2012 model, mine is 1F7 silver metallic. That is a nice find from Japan, since they are used it is a bit risky but the color should be close to what you have now on your prius. The only thing I don't like is having a front licence plate holes cut outs for the front license plate. I notice all Japanese cars require front license plates so that is something you will have to deal with. I know in arizona, front license plates are not required so the front bumper are often left alone and the dealer leaves the mounting plates in the trunk for you to decide what to do with them. I have purchased a few hondas from right honda myself and purchased a 2012 prius V wagon from right toyota a year ago. We have a second home in maricopa az.
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    All that is needed besides a complete front bumper (ie: grills, DRL/signal lights & brackets, logo & tow hook covers) is the bumper absorber.
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Dawit likes this.
  6. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    No problem
  8. antech5
    antech5 Member
    160
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Those are easy. All u have to do is buy the OEM covers from the dealer. They even come painted.
  10. antech5
    antech5 Member
    160
    nice, everything should work out for you then.
  11. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    this is the one I bought. it doesn't have the washer cut outs
  12. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    Hey Sean, Do you have any suggestions on ways to cover the license plate holes?
  13. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    U've got 2 choices:
    1) this is the cheapest of the 2. The dealer sells color matched plugs that u can use.
    2) if ur getting it painted, u can get them filled. This is the method I used.
  14. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    Hey Sean,
    any recommendation on which fog lights to buy that would fit in the 2012 bumper?
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Just be careful.......they sometimes don't supply the correct switch from what I've seen from other members
  16. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    thanks for the info!
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    No problem
  18. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    Hey Sean, do you know where I can find the connector socket that attaches to the drl/signal light? I tried to get one from autozone but it doesn't fit:(
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Are u talking about the 4 pin gray connector?
