Will the new Prius do anything to avoid collision when changing into an occupied lane?
Discussion in 'Gen 5 Prius Technical Discussion' started by priusmouse, Sep 1, 2023.
  1. priusmouse
    priusmouse Member
    255
    85
    Long Island, NY
    2023 Prius
    Let’s say you are on the highway and you want to change lanes. Maybe you signal or maybe you don’t. But there is a car driving immediately next to you, or perhaps in your blind spot.
    Despite the BSM illuminating, indicating that there is a car next to you, if you continue moving towards the vehicle, will the Prius do anything to avoid collision?
  2. BiomedO1
    BiomedO1 Senior Member
    4,631
    2,427
    Left Coast
    I'm 99.9% sure that the illuminated BSM is your collision avoidance / warning.
    Your steering wheel may rattle a bit; if LDA is turned-on and you didn't signal. If you did signal, see above sentence.
  3. Hammersmith
    Hammersmith Senior Member
    2,494
    2,552
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I don't know about the car changing direction on its own, but you'll at least get some strong beeping if you signal in the direction where a car already is. It's happened to me at least once where I signaled a little early as either I was passing or being passed.
  4. Chimera1978
    Chimera1978 Junior Member
    45
    San Diego
    2023 Prius Prime
    XSE Premium
    This actually happened to me today. So many beeps... easy to ignore. I started to change lanes into somebody with all of the stuff going off. Ultimately, the car steered away and I finally noticed the other guy. Probably would have hit him if it didn't do that. Very glad for the feature. I don't know what setting it was that made that happen, but I have most of the safety things still turned on.
    I also once started backing out and there was a car coming and the car hit the brakes for me and prevented me from backing into the other guy. So the features have potentially saved me twice already (embarrassed to admit).
    Gotta love this car :).
    AndersOne, tovli and priusmouse like this.
  5. AndersOne
    AndersOne Active Member
    346
    200
    Europe
    2023 Prius Prime
    Regarding lane changes - did anyone actually use already the Lane Change Assist? It would only change if the lane is free anyway - so not much room for mistakes. I cannot imagine myself using it often though...
  6. Hammersmith
    2,494
    2,552
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Huh. Didn't even know the car had that. I'll have to give it a try, though I agree I can't see myself using it often.
  7. Chimera1978
    45
    San Diego
    2023 Prius Prime
    XSE Premium
    Here are the manual pages for the LCA.
