Will these fit on a 2017 Prius Prime?
Discussion in 'Prime Accessories and Modifications' started by MSAGRO, Mar 19, 2018.
  1. MSAGRO
    MSAGRO 2010 Prius Five with Advanced Technology Package
    259
    227
    Portland Oregon
    4737D277-E50A-4C59-B3F4-4EF9F26E3FC4.jpeg Those wheels are exactly what I’m looking for!
    What brand and style are these?
  2. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Another wheel that might work, but you'll be back to higher wheel/tire unsprung weight.
    Impression - Konig Wheels
    18×8 // 5×100 // ET40 // 24.2 lbs
    # IP88510405
    Rob43
  3. Tideland Prius
    16,681
    Ahh ok. Yes it's much clearer now!
    With 195/65R15, you can upgrade to a 215/45R17 size (with the correct bolt pattern) without any spacers for the most part (assuming the alloy wheel hub is correct.
    The 17" rims on the Gen 4 are 7J x 17 (The same wheels are available on the Prime in Japan) if you need a guideline.
    MSAGRO likes this.
  4. MSAGRO
    259
    227
    Portland Oregon
    Thanks. I now know what to get.
  5. MSAGRO
    259
    227
    Portland Oregon
    Just wanted to thank you for posting above Rob43. I finally found this thread again. Because I ended up getting the wheels that were posted. Thanks again for steering me in the right direction.
  6. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    Thanks, I'm glad you're enjoying them. IMO the Prime looks much much better when 17's are mounted on it.
    Keep up the good work,
    Rob43
    MSAGRO likes this.
  7. cek347
    cek347 Junior Member
    SE PA
    Are those the 18" or 17" version of the wheels posted above? What size tire did you go with? Thanks! Looks great.
  8. MSAGRO
    259
    227
    Portland Oregon
    215/50 R17. So 17 inch wheels. They are actually 12 ounces lighter each then the stock 15 inch alloy.
  9. Mendel Leisk
    42,354
    Not the official 215/45R17 size? Comparing to 195/65R15, with the 17's 45 reduces tire OD about the same amount as the 50 increases it, so maybe no big deal. And the ride is a little cushier with 50.
  10. cek347
    SE PA
    Awesome, those wheels look great!
    MSAGRO likes this.
  11. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    That looks nice. What was the cost to swap out?
  12. MSAGRO
    259
    227
    Portland Oregon
    Koenig wheels and Nokian Entyre 2.0 tires were a total of $1200… But I sold my OEM wheels and tires for $500… So $700.
    The larger tires handle better, quieter, and a longer warranty.
    I chose the Nokians Because they have the highest waterplaning resistance of any tire you can buy.
  13. Sddunn
    Sddunn New Member
    Nanaimo
    2018 Prius Prime
    Wow nice car can’t say I would trade a Tesla for a prime. Truly a shame you are not using the car. Good luck with your prime !
