Will These Wheels Match?
Discussion in 'Gen 3 Prius Main Forum' started by Godawgs, Nov 26, 2022.
  1. Godawgs
    Godawgs Junior Member
    Portland
    2018 Prius Prime
    I have already purchased my tires so looking to see if these tires will match my 2012 Prius two:
    Buy Tires Online | TireBuyer.com
    The have a +35 offset and I am using 195/65/15 tires.
    Thanks for any help!
  2. Tombukt2
    Tombukt2 Senior Member
    13,863
    2,519
    Durham NC
    Did you look up to see what the original Prius wheel offset is I can't remember what it is right off but generally I try to stay within plus or minus five of that reading generally now I've been way off on other vehicles without anything rubbing or causing problems but looking strange and it's not good to space the wheels exponentially further out than needed might load up front suspension components differently and things like that I put a similar set of wheels as to what you're buying in 15s on a 14-in Corolla 4 lug similar offset to all Toyota wheels so they should work fine
  3. Godawgs
    Portland
    2018 Prius Prime
    I am not certain but I think the OE offset is either +42 or +45. Not certain though.
    if accurate what would it mean if I bought these wheels at +35?
  4. hoffeck
    hoffeck Member
    Germany
    The rims should fit. I had Audi rims on my prius. These had +38 offset. (195 65 R15)
  5. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    You can probably get by with +35s but I’ve never gone beyond a +40. Ideal offset to keep the tire edge flush on a G3 Prius is +42, but seems to be fewer choices in that +42mm range now.
