Will we see 20 year old Priuses still on the road?
Discussion in 'Gen 3 Prius Main Forum' started by Tom777, Oct 13, 2015.
  1. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    As a general principle, I prefer to buy a 5 year old car (private party) and drive it for 10 years. I'll have a 15 year old car by the time I part with it. My 2012 Prius plug-in is the newest car I've purchased (bought in Feb), but I bought it with a reconstructed title, so I saved a lot of money that way.
    I've got my eye on a 2013 Leaf or a 2014 Spark EV in 2-3 years when the Bolt and Tesla 3 are released. That's when I'll part ways with the 2006 Acura TSX.
  2. CR94
    CR94 Senior Member
    2,761
    1,210
    Northwestern S.C.
    Last year my Prius replaced my 34-year-old Mazda. I'll be shocked if the Prius lasts 20 years or half as many miles without needing a much more expensive repair than the Mazda ever required.
  3. Tideland Prius
    16,625
    Why is that? Yes a more expensive car will, typically, have a more expensive part but my thinking is that electronics in a Toyota vehicle are fairly reliable. If anything, I expect wear & tear parts to go first (like brake pads, shocks, typical 20 year old car stuff). Also, you're saving on things such as no alternators to replace in that 20 years (what's that, 3-4 alternators?), brake pads that last nearly the life of the car (11 years/240,000km on the 2005 with mostly city driving and still on its original brake pads. The 2010 with half the km but 6 years of mountain driving still have 70%/60% life front/rear left). You'll go through 2-3 sets of pads depending on driving condition, driving style and brake pad type. No clutch to replace (if your mazda was a manual) and no ATF to replace (although it's probably prudent to get it done to keep the Power Split Device well serviced). LED brakelights and taillights don't need replacing either.
    N.J.PRIUS and energyandair like this.
  4. CR94
    CR94 Senior Member
    2,761
    1,210
    Northwestern S.C.
    The reason why is essentially that you're comparing routine cheap-to-moderate cost repairs (light bulbs, brake pads, struts, etc.) to several very expensive specialized parts I wouldn't trust to ALL survive beyond 20 years and 303K miles. One Prius brake controller, one high-voltage battery, one motor-generator, or one inverter alone would far exceed any one repair on the Mazda.
    As for alternators, the single replacement was about $55 at about 480K. My brother has had two cars go well beyond 300K with zero alternator problems, so that's a non-issue.
  5. Tideland Prius
    16,625
    Right, but that's the same as saying a transmission needs replacement before 20 years and automatic transmissions aren't cheap.
    However, to perhaps give you some peace of mind, there are taxis in service and the HV battery will last 500,000 km (note the units). One had it replaced at 700,000 km. Clearly you and your brother maintain your cars very well.
  6. Redpoint5
    1,026
    509
    Portland, OR
    I expect to never replace brake pads on the Prius. The only time I use them is to bring the car from 7 MPH to 0. Brake pads last 100,000 miles on my other vehicles, and they cost me maybe $70 to replace both front and rear with ceramics. $140 amortized over
    20 years is small beans.
    I've also never had an alternator failure in any vehicle. Some of my friends have, but they drive crappy cars like VW. Brands with good reliability should never need the alternator to be replaced during the life of the vehicle. Certainly there is a problem with the car if someone is going through 1 alternator every 5 years.
    Struts often need replacement somewhere after 200,000 miles. Those will cost me less than $200 to replace, so again it's a fairly insignificant cost.
    What would not be insignificant is a traction battery failure. Who knows what the cost of junkyard MG1 or MG2 units or inverters would be? That said, I expect the traction battery to go at least 200,000 miles in the PiP, and the MGs and inverters to go the life of the vehicle.
    #46 Redpoint5, Oct 22, 2015
  7. Tideland Prius
    16,625
    Really? Our 5 year old Camry had its original alternator before it was totalled but my other friends with older cars have already replaced their alternators once. (one is 7 years old, the other is 11 and both were replaced several years ago).
    Junkyard traction batteries are significantly cheaper than brand new ones. Or if you're near Boulder, look for Paul Guzny (What Drives Us panelist). He specializes in hybrid cars (mostly Prii)
  8. Redpoint5
    1,026
    509
    Portland, OR
    The thing is, in 20 years I don't want to be driving my current Prius. Technology will advance so much in just 10 years that I expect to have moved on from my current PiP well before the traction battery gives out. In fact, I'm looking at buying an EV to replace the TSX in the next 2 years; probably a used Spark EV or a Leaf. It will actually be cheaper for me to replace the paid for 2006 TSX with a newer EV than continue driving the older technology.
    People driving 20 year old cars generally aren't saving any money by doing so; they simply can't afford the upfront investment to purchase something newer and more efficient.
    N.J.PRIUS likes this.
  9. frodoz737
    frodoz737 Top Wrench
    4,733
    2,522
    33
    Toyota and Honda are the only cars I look at any more because they have better reliability hands down. Preventative maintenance is a given cost regardless of what you drive...yes even the Prius with it's NOT lifetime fluids...component failure costs are what bite ya in the -ss. As a Mechanic my opinion is currently Toyota beats the curve on reliability. That said, Prius failures will cost you more when they do occur. There will always be folks that get lucky and buy the car assembled on Thursday verses the one assembled on hang-over Monday. All vehicles can be maintained and repaired as long as parts are available. Whether you want or can afford to do so is just a choice based on one's own personal and financial reasons.
  10. Fore
    Fore Don't look back!
    494
    107
    Big fat Nooooooooooo!
  11. PerryD
    PerryD Junior Member
    27
    34
    Near Boston
    2022 Prius Prime
    The Boston Globe just ran a story on the 15 cars that owners have kept for a decade; the list is heavy with Toyotas, and includes the Prius.
    Perry
  12. PerryD
    27
    34
    Near Boston
    2022 Prius Prime
  13. bisco
    52,431
    the o/p's premise is 200-240k after 20 years, not 303k. and i think we can safely assume most mazda's don't hold up any better than a prius, all things being equal.
  14. Tideland Prius
    16,625
    It's also possible that the owners of other vehicles hit the "expensive repair" point of ownership earlier than the models listed. That's a popular reason for someone to purchase a new (or new to them) car. The Corolla and Yaris have the least amount of required maintenance and the cost of said maintenance is pretty low. Likewise, someone mentioned that the Model S' maintenance schedule is fairly light too (not many things required to be checked on an EV) but the cost of that maintenance is high, similar to other luxury makes.
  15. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Well, don't include LED brake lights and headlights as "a good thing" for inexpensive repair. They DO fail, and they cost hundreds to repair! Of course, the brake lights might be done by the owner, taking the assembly apart and replacing the bulbs, but the headlamps, not so much.
    But you have to ask yourself, do you really want to be driving a 15-20 year old car among the morons piloting 1 to 2 tonne missiles on the roads? Crash safety improves a lot in 15 years! I know these days I'm tempted to get out and kiss the ground when I arrive safely at my destination. ;)
  16. roamerr
    roamerr Member
    135
    43
    Winston-Salem, NC
    The led brake lights on gen 2 last me 10 years. I just replaced both on my 2005 in last year. The red brake part stopped working. $75 each on eBay to replace. Cheap enough.
    iPhone ?
  17. CR94
    CR94 Senior Member
    2,761
    1,210
    Northwestern S.C.
    Bisco, the 303K number referred only to my earlier comment about the odds of a Prius lasting 20 years or half as far as the Mazda without failure of any of its expensive specialized components.
  18. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    My father daily drives a 1995 Tacoma; he only has that because he bought it from my sister-in-law last year when he gave the 1991 Hilux he had been driving to my brother.
    I'm planning on keeping the Prius for 20 years or more; I'll check back in to this thread then (if this site still exists).
  19. Tideland Prius
    16,625
    I wonder if we'll see a rash of Corolla owners replacing theirs. Their LED headlights are used as DRLs so either TCI has good faith in their durability or they're going to see a lot of replacement headlights (and angry owners at the cost of replacement).
  20. ChapmanF
    18,606
    Hmm, that is $15 a year though. Hardly a dealbreaker but, come to think of it, definitely more than I've ever been used to spending on light bulbs for cars....
    -Chap
