Win a FREE BT Tech Stiffening Plate but there's a catch!!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by BT Tech, Feb 14, 2008.
  1. patsparks
    10,664
    567
    Adelaide South Australia
    Under BT Tech "Brace Yourself" or "Stiffen up" or "Harden Up" or "Enhanced" :D
  2. BT Tech
    BT Tech New Member
    885
    South Florida
    Thanks everyone for your suggestions and pictures that you have posted. There has been a lot of good ideas posted and up to this point, I really like the one that Ichabod has posted. The only issue I have is how much it will cost to machine. Also, adding color to the logo is sure to be an expensive proposition so it might have to be all silver in color.
    I have a feeling that we are going to have to give away more than one plate due to all of you guys that are posting your suggestions!! :)
    Keep the ideas coming!!!
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I know you like the idea of machining it, but I bet you could mass produce those via a commercial manufacturer out of plastic a lot more cheaply and they'd probably be more likely to stay on the car, not get oxidized (like aluminum would), etc. I'm not sure exactly who would make something like that, but I'd sure look at that route...I bet it would be cheaper than the blank metal and it would probably be cheaper to ship as well.
  4. efusco
    19,891
    1,196
    Nixa, MO
    Google shows lots of places, many do use brushed aluminum and seem to charge around $10 apiece.
    http://www.oceanemblems.com/Custom.aspx
    I found where This Company did a group buy for another Toyota site and got 2 decals for $15. Worth getting a quote anyway.
  5. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Well, I STILL like "BT Tech Equipped"... but "Brace Yourself" is pretty cute, too!
  6. ceric
    ceric New Member
    1,114
    Fremont, CA
    Ichabod,
    This one looks great. You have my vote so far.
  7. ceric
    ceric New Member
    1,114
    Fremont, CA
    Brian:
    Second entry from me.
    This one is for metal/chrome plastic. The white area is hollow.
  8. ceric
    ceric New Member
    1,114
    Fremont, CA
    Sorry, BMP format exceeded the limit.
    Here is the JPEG version. (a bit blurry).
  9. Godiva
    Godiva AmeriKan Citizen
    10,339
    I like BT Tech Enhanced. It can cover a lot of different mods. I don't like the idea that the Prius needs to be fortified, reinforced, fixed or in some way made stronger or stiffer because it implies the car isn't fine as it is.
    I'd do a mock up with Fireworks but I'm busy moving in to my new laptop and don't have the time.
  10. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    I can change the wording in mine if people (and Brian) like a different word or words.
    Brian, I could also be *convinced* to trade my professional services in refining a final design of any of these designs if one other than mine is chosen... since everyone seems to be talking about you giving out more than one prize. ;)
  11. Flying White Dutchman
    4,376
    313
    [​IMG][/quote]
    this one but then "Enhanced" instead
    i like it!
  12. koa
    koa Active Member
    980
    45
    Hawaii
    <IMG style="MAX-WIDTH: 800px; ; WIDTH: expression(this.width > 800 ? 800: true)" alt="" src="http://i175.photobucket.com/albums/w130/koa_/File0004.jpg" border=0>
  13. koa
    koa Active Member
    980
    45
    Hawaii
  14. Godiva
    10,339
    Shiney metal and beveled et all. But here are the words and spacing.
  15. koa
    koa Active Member
    980
    45
    Hawaii
  16. Cacti
    Cacti Poleikleng
    193
    Massachusetts
  17. Ichabod
    1,794
    Newton, MA
    Since Godiva started the "let's rip off Ceric" game, I figured I'd post this one. :) In theory I like the overlapping T's, but my only reservation about it is that from a distance, it reads "BTECH."
  18. koa
    koa Active Member
    980
    45
    Hawaii
  19. Godiva
    10,339
    I didn't rip off Cedric or Pat Sparks. I was thinking enhanced before it was mentioned. And mine isn't stacked.
    I don't mind the stacked version above but do think the T of Tech is getting lost so...move it to the right a little and maybe down a little more. Hard to tell with the angle.
    Because of size I'd reduce the size of the "ech". BTT are your main capitals with BT the most important. "ech" can be capitalized or not. Using the font you are you have all capitals but the size is wrong proportion for the enhanced. I really like the enhanced BTW). So rip me off a little further and make the "ech" smaller and offset that second T over to the right a little more. If you also bring it down a little more you're a lot closer to my logo. The "ech" can line up with the bottom of the T or just below the upper cross of the T. Doesn't matter.
    I did mine in four layers in Fireworks so I can offset and change font sizes easily. I just can't do metal or beveling or any of that fancy stuff. I thought mine would be a nice window cling using two tone paint.
    BTW Doc Willie? I was using Star Trek Next Gen font.
  20. Godiva
    10,339
    Here's the progression:
    Ichabod's original:
    Ceric's Stacked multicolor:
    Godiva's offset window cling:
    Ichabod's merged:
    BTW, like a few others, I already have a BT Plate so I don't need one.
