Wind Susceptibility
Discussion in 'Gen 3 Prius Accessories and Modifications' started by d0nsut, Jan 18, 2012.
  1. d0nsut
    d0nsut New Member
    28
    Houston
    Is there a silver bullet to making the Prius (mine is a 2011 but my GF has a 2009 with the same issue) less susceptible to winds and air turbulence? I've never driven a smaller car and assume the size/weight has something to do with it but at freeway speeds this car is constantly moving from stripe to stripe. It's a fight to keep it in the lane at 70mph on a windy day. On a two lane highway, passing oncoming big rigs requires finesse. I enjoy the car but driving at freeway speeds are something I'm having a problem adjusting to.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Side wind susceptibility is common with aerodynamic cars. They are designed to cut through headwinds, but the consequence of this is often flatter sides.
    In addition, the Prius tends to have numb steering with little or no dead band, which means the driver tends to over correct and induce oscillation. Likewise, the tires on a Prius are designed for low rolling resistance, not optimized handling.
    So what's a Prius owner to do? Try these:
    1) If you are new to the Prius, give it time. Most people get used to the handling and find it better with experience.
    2) Have the alignment checked. Bad alignment can cause handling issues.
    3) Get better tires. There is a HUGE difference in how the Prius handles with good tires. Stay with low rolling resistance tires (LRR) or your mileage will take a hit, but get good ones. Many tire threads on PC discuss this issue in detail.
    Tom
  4. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    692
    151
    Seattle, WA
    For your 2011, Cusco & Tanabe underbraces are available. You should also get a rear anti-swaybar, either the TRD 2008 Scion xB bar or the new Toyota unit that's part of the Plus package.
  5. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    what tire pressure are you running? I went to 42 front/38 rear and it helped.
    Prius has high profile LLR tires with soft sides, which are susceptible to deformation. Since most of the weight rides on front tires they deform more from body roll, hence pull you to the side. Lowering rear/rising front to the point front/rear tires curved as much keeps it more stable.
    Stiffening body, installing strut and anti-sway bars helps too, but adjusting pressure is cheap, try it good luck
  6. d0nsut
    d0nsut New Member
    28
    Houston
    I got the rear sway on it's way and I plan to put the STB on tonight or tomorrow night. Not sure on what under car braces I'm going to do but I'll add them likely sooner than later if it'll help.
    Tire pressure, I'll give it a try. I don't know what the tires have in them as I just went with whatever the dealer had in them when I picked it up. I can check them tonight and toy with them.
    Thanks guys! Hopefully I can get some stability without having to lower the car or change out the tires. I've never had/used tires that last 30k+ miles. I'm used to ZR rated and large/soft all terrain on the SUV's. I'd never heard of LLR tires until after I got this prius. I thought getting more than 20k out of a set of tires was a marketing myth.
  7. tv4fish
    tv4fish Member
    202
    46
    OK - :) Do you only race at a drag strip with your SUV's ? Are you kidding or serious ? If I only got 20,000 miles out of a set of tires for my Explorers - I would be all over the tire manufacturer ! If I got less than 40K, I w/b upset! What brand tires are you buying?
  8. cyclopathic
    3,292
    547
    2014 Prius c
    if this is for your gen3 STB and rear sway should be enough. Most of the improvement will come from swaybar, STB will add more precise steering. After that the improvements from adding tanabe underbrace were very minimal.
  9. d0nsut
    d0nsut New Member
    28
    Houston
    My Tahoe had some aftermarket wheels and tires that the previous owner had just installed. I got 20k on them before I traded it in and the fronts were worn down past the wear bars. They were some kind of Cooper AT tire but they weren't stock size. I read in the Tahoe forums that those Cooper's were horrible for wear life, moreso than the other cooper tires. I do not know, but there was no way I'd get another 2k out of them.
    On my CTS-V I was getting 12k on the fronts and 10k on the backs. Some of that may have been attributed to my foot. That seemed to be the norm for me on tires for the last decade as I've pretty much owned sports cars.
  10. ETC(SS)
    7,557
    I'm thinking that sports cars (like the CTS-V) come with a little softer tires from the factory than Priuses and SUVs do, so I wouldn't be surprised that you're getting to see what the wear bars on your OEM tires look like before you hit 20K.
    However (comma!) there's no reason that you shouldn't be getting closer to 40K on OEM tires for econo-boxes and SUVs alike---depending on your driving habits.
    I'm not a gentle driver, but I routinely get 50K++. Some of this is due to religious rotation and pressure monitoring. Some of it is due to the fact that I left my sportscar days dwindling in the rear view mirror a few decades ago.
    Based on my wear to date, I expect to get 50K out of the rubber on my G3. YMMV.
    As far as the handling in dirty air, I think Tom hit all of the high points. I'm no fan of the G3's "Xbox360 steering" but I've not found it to be unstable at speeds that a G3 is capable of reaching. That's me. I ride motorcycles a lot, so I may be a little more difficult to rattle in the cockpit. Again.....YMMV.
    Give it time.
    Good Luck!!
  11. lpe350
    lpe350 Member
    56
    32
    Long Island
    I upgraded from the stock 15" wheels to 18's with a 1.5" drop and that helped the wind issue significantly. (but my fuel eco when down 3.5 mpg)
    The GY Supercar tires that comes on the CTS-V only lasted 8K on my Corvette, you were lucky to get 12 and 10k on a heavier CTS-V. :D
    How does it feel to go from 500+ hp to a Prius?
  12. Dark_matter_doesn't
    692
    151
    Seattle, WA
    I'd tend to agree on the Tanabe underbrace alone, since it ties the very front of the underbody together. The STB should be more robust in that regard.
    The Cusco power brace should keep the rear body flex to a minimum.
  13. d0nsut
    d0nsut New Member
    28
    Houston
    I've been weening myself off of HP for some time. Sold the CTS-V last year and made myself get used to the exasperating acceleration of a 7,000+lb 4x4 Tahoe. After initially fighting desires to supercharge the hoe, I finally got enough self-control of the speed bug that upgrading passed. I miss the acceleration and power of my previous cars but at the same time, when people are flying by me at 90+mph I see how wreckless I used to be and what's really funny, driving 65-70, I complete the freeway portion of my drive in approx. 15min a huge time increase over my previous 13min speed educed trip. Today power for me is trying to accelerate without putting the HSI in the 'power' zone. :D
    Acceleration wise, the prius far exceeded my expectations of what I initially thought it would do. I'm not winning any races but it will get me up to freeway speeds in a respectful amount of time, often faster than the cars merging in front of me. Surprisingly, from light to light, it's just fast enough to cut off the unsuspecting taurus or f150 who think they're going to cut me off.
  14. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Wreckless, that's funny!
  15. d0nsut
    d0nsut New Member
    28
    Houston
    A little update. Had to drive about 180 miles today with 150 at freeway speeds. The Tanabe STB was installed last night and it seems to have cut the wind susceptibility by seemingly half so it was a definite improvement. I'm not sure if it's because the STB makes the steering more crisp and steering can be adjusted with minimal wheel movement or it the brace actually stiffens the chassis? Either way, it makes a difference.
    I'm having a problem finding my tire pressure gauge so I'll run buy one this afternoon. I haven't made any air pressure changes yet. When I get it changed I'll report back.
  16. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Get the brace for the GF, it really helps the Gen2.
  17. Dark_matter_doesn't
    692
    151
    Seattle, WA
    Chassis flex seems to be the problem, so you should next try the Cusco power brace to stiffen up the middle of the chassis. Last would be the rear anti-sway bar to further control body roll.
    Tire pressures probably won't make much difference, but it costs nothing to try.
  18. d0nsut
    d0nsut New Member
    28
    Houston
    I thought I'd provide a final (likely final) update to this thread. Since posting the original message I've added a Tanabe Strut Tower Brace, Toyota TRD Prius Sway Bar, and I've adjusted the air pressure in the tires. IMO the car seems to be more stable on the freeway when the wind is blowing or where crosswinds are at play. I believe some of this involved getting used to the car but all-in-all the additional air and suspension parts did make a difference.
    The dealer had 36psi in the front and 33psi in the rear. I changed it to 41f and 39r. The ride was a little more firm but overall not bad. No real difference on coasting or gas that I could tell.
    As I stated the car feels much "friendlier" to drive at freeway speeds now. Obviously wind is still going to push the car, any car, but my Prius doesn't feel like it's jumping from hash to hash and when the wind pushes on it, it's a more 'normal' push instead of jerk. Hopefully that makes sense - it does to me. :)
    I may do a chassis brace in the future but for now I'm pleased with how the car handles, rides, etc. Thank you all for the help and advice.
